my Beagleboard has trouble booting. I tried it with Debian 7.0 and
Ubuntu 12.04, but both fail during booting. I then tried the shipped
image, which also fails. As I understand the serial output, my boot.scr
or uEnv.txt is never read. When I enter the boot commands at the u-boot
prompt, it starts like it should. I also tried switching the sd-card,
which didn't helped.
serial output:
Texas Instruments X-Loader 1.5.0 (Mar 27 2011 - 17:37:56)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 01 2011 - 17:41:42)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev A
No EEPROM on expansion board
Die ID #59da00011ff00000015739eb0c019006
mmc - MMC sub system
Usage:
mmc read <device num> addr blk# cnt
mmc write <device num> addr blk# cnt
mmc rescan <device num>
mmc part <device num> - lists available partition on mmc
mmc list - lists available devices
Booting from nand ...
NAND read: device 0 offset 0x280000, size 0x400000
4194304 bytes read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
OMAP3 beagleboard.org #
Any ideas?
