I have a BeagleBoard -xM rev B with Maverick - (Ubuntu 10.10)
installed following the instructions on http://elinux.org/BeagleBoardUbuntu
.I also installed the standard gnome desktop using 'sudo apt-get
install ubuntu-desktop'.
However when I restart or in cases where there have been an improper
shutdown, the board refuses to give a display - no boot screen. I
tried switching cards and putting my Angstorm installation - that
works - so the board is not at fault.
This has happened for almost the fifth time now, and I always have to
reinstall the OS and other softwares; could you please advise me-
a. Whether there is an inherent instability issue with BeagleBoard xM
B with Ubuntu 10.10 with gnome desktop.
b. Any tips to recover from such a crash? Instead of reinstalling the
OS?
installed following the instructions on BeagleBoardUbuntu - eLinux.org
OS?
Couple things first.. which kernel? (uname -r)
Do you by luck have a serial log when it crashes?
A common one on the xM is:
smsc95xx 1-2.1:1.0: usb1: kevent 2 may have been dropped
Which is currently worked around by adding:
vm.min_free_kbytes = 8192
But it depend's on your kernel...
Otherwise without any swap or using a fast external usb drive as root,
"ubuntu-desktop" is just way to bloated for the beagle..
"xubuntu-desktop" is saner, but still big..
And yes, I get several lines of 'smsc95xx 1-2.1:1.0: usb1: kevent 2 may have
been dropped' .
Additionally, I found
here https://bugs.launchpad.net/ubuntu/maverick/+source/linux/+bug/663642
that the no DVI output bug was fixed in the 2.6.35 - 23.40 kernel update.
And since I downgraded my kernel below that version to get the audio
running, I missed up on the DVI-D patch!
Yeah, that got fixed late in my 2.6.35 release's..
-Reinstalled the Ubuntu (Maverick). The one on your site ubuntu-10.10-r3-minimal-armel
-Installed ‘ubuntu-desktop’.
-Installed the 2.7.37.1-x2 kernel which seemed to be the latest stable one.
After rebooting, I again lost my DVI-D output.
Could you suggest anyway I can at least roll back the changes instead of reinstalling the OS?
Also which kernel version would you advise to install for the audio and display both to work?
-Installed 'ubuntu-desktop'.
Look in /boot/uboot/
If you used my "install-me.sh" script to install 2.6.37.1-x2, the old
uImage and uInitrd are saved as uImage_old and uInitrd_old..
Since r3 was a 2.6.35 based demo image, it looks like you hit the
latest 2.6.37 regression i'm currently bisecting.. Some monitors..
(in my case 1 old hp i have at home, but not ANY of the 4 i have at
work or the other 2 at home.. ) don't seem to work with 2.6.37...
I checked my /boot/uboot, I found it empty! Is this normal? However I found the uImage, uInitrd, uImage_old and uInitrd_old in the /rootfs/ partition. I did restore the old uImage and uInitrd - but still, it refuses to show up display…
On connecting over minicom to the beagle, I get this-
display..
little odd, it should be there with my demo images... anywho..
since your board doesn't boot.. mount the card on a development pc..
mount the small fat partition.. you should see all the uImage/uInitrd's..
