Dear all,
i am having issues with my beagleboard xm Rev C (C1 says sticker on the board). When board came at the first time, everything worked fine. Then, i was foolish enough not to backup my original working Angstrom SD image and i tried to install ubuntu (of course unsuccessfully - usb power problem). Now i am having issues with usb all the time. D14 LED is not litting, but i can boot into OS fine.
I have tried:
1)angstrom-distribution.org/narcissus - with/without its bootloader options on fat partition
2)http://downloads.angstrom-distribution.org/demo/beagleboard/ - all images with all combinations of MLO and uBoot.img
3)http://treyweaver.blogspot.com/2010/10/installing-angstrom-on-beagleboard-xm.html
4)circuitco images - both 3_30 and 4_25.
netinstall ubuntu with precise, natty and maverick. Other ubuntu images, cannot really remeber which ones…
android gingerbread 2_3 arm build for beagleboard (red screen appears, but it boots fine, only without usb)
For installation i used win32 disk imaginer tool, and sh scripts on linux. Every installation had same problem with usb. It seems that not enough power is coming to usb hub ?
I searched all over, but was unable to find right solution. Hope someone can jump in and help me on this one. Thank you.
My dmesg on Angstrom BeagleBoard-xM xMTEST_Beta_4_25 - circuitco image:
pfb.vram=0:8M,1:4M,2:4M omapdss.def_disp=dvi root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000]
[ 0.000000] Beagle expansionboard: none
[ 0.000000] Beagle cameraboard: lbcm3m1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 256MB 256MB = 512MB total
[ 0.000000] Memory: 496256KB available (5884K code, 671K data, 204K init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000000] Calibrating delay loop… 518.82 BogoMIPS (lpj=2023424)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option ‘mode’
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP3 Beagle Rev: xM C
[ 0.000000] Beagle cameraboard: registering i2c2 bus for lbcm3m1
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 0.000000] omap_init_mbox: platform not supported
[ 0.000000] Target VDD1 OPP = 4, VDD2 OPP = 2
[ 8.957702] OMAP DMA hardware revision 5.0
[ 8.963928] bio: create slab at 0
[ 8.965179] SCSI subsystem initialized
[ 8.966491] usbcore: registered new interface driver usbfs
[ 8.966674] usbcore: registered new interface driver hub
[ 8.966827] usbcore: registered new device driver usb
[ 8.967254] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[ 8.969940] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 8.970001] twl4030: power (irq 373) chaining IRQs 376…383
[ 8.970306] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 8.972015] regulator: VUSB1V5: 1500 mV normal standby
[ 8.972259] regulator: VUSB1V8: 1800 mV normal standby
[ 8.972503] regulator: VUSB3V1: 3100 mV normal standby
[ 8.973785] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 8.974243] regulator: VMMC1: 1850 <–> 3150 mV normal standby
[ 8.974517] regulator: VDAC: 1800 mV normal standby
[ 8.974761] regulator: VPLL2: 1800 mV normal standby
[ 8.975036] regulator: VSIM: 1800 <–> 3000 mV normal standby
[ 8.975402] regulator: VAUX3: 1800 mV normal standby
[ 8.975769] regulator: VAUX4: 1800 mV normal standby
[ 8.975982] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[ 8.987335] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 8.988525] Switching to clocksource 32k_counter
[ 8.997619] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 9.001342] musb_hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine (X), bulk split (X), HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 9.001373] musb_hdrc: MHDRC RTL version 1.800
[ 9.001373] musb_hdrc: setup fifo_mode 4
[ 9.001403] musb_hdrc: 28/31 max ep, 16384/16384 memory
[ 9.001434] musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 9.001495] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 9.001617] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 9.001800] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.001831] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.001892] usb usb1: Product: MUSB HDRC host driver
[ 9.001922] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 9.001953] usb usb1: SerialNumber: musb_hdrc
[ 9.002563] hub 1-0:1.0: USB hub found
[ 9.002624] hub 1-0:1.0: 1 port detected
[ 9.003662] NET: Registered protocol family 2
[ 9.003936] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 9.004577] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 9.005004] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 9.005218] TCP: Hash tables configured (established 16384 bind 16384)
[ 9.005249] TCP reno registered
[ 9.005279] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 9.005340] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 9.005584] NET: Registered protocol family 1
[ 9.006042] RPC: Registered udp transport module.
[ 9.006103] RPC: Registered tcp transport module.
[ 9.006134] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 9.007019] omap-iommu omap-iommu.0: isp registered
[ 9.008758] VFS: Disk quotas dquot_6.5.2
[ 9.008880] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 9.009948] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 9.010772] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 9.011657] msgmni has been set to 969
[ 9.015411] alg: No test for stdrng (krng)
[ 9.015716] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 9.015777] io scheduler noop registered
[ 9.015808] io scheduler deadline registered
[ 9.015960] io scheduler cfq registered (default)
[ 9.074768] OMAP DSS rev 2.0
[ 9.074859] OMAP DISPC rev 3.0
[ 9.074920] OMAP VENC rev 2
[ 9.075164] OMAP DSI rev 1.0
[ 9.411712] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 9.430206] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 9.448120] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 9.465972] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 10.048034] console [ttyS2] enabled
[ 10.058166] brd: module loaded
[ 10.064514] loop: module loaded
[ 10.069091] omap2-nand driver initializing
[ 10.073516] No NAND device found!!!
[ 10.077239] No NAND device found!!!
[ 10.081787] usbcore: registered new interface driver catc
[ 10.087310] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 10.093383] usbcore: registered new interface driver kaweth
[ 10.099029] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 10.106689] usbcore: registered new interface driver pegasus
[ 10.112426] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 10.119445] usbcore: registered new interface driver rtl8150
[ 10.125274] usbcore: registered new interface driver asix
[ 10.130828] usbcore: registered new interface driver cdc_ether
[ 10.136779] usbcore: registered new interface driver dm9601
[ 10.142517] usbcore: registered new interface driver smsc95xx
[ 10.148437] usbcore: registered new interface driver gl620a
[ 10.154174] usbcore: registered new interface driver net1080
[ 10.159973] usbcore: registered new interface driver plusb
[ 10.165588] usbcore: registered new interface driver rndis_host
[ 10.171691] usbcore: registered new interface driver cdc_subset
[ 10.177764] usbcore: registered new interface driver zaurus
[ 10.183471] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 10.191558] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 10.198425] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 10.204467] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[ 10.212097] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 10.230926] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 10.236846] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 10.243743] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.251068] usb usb2: Product: OMAP-EHCI Host Controller
[ 10.256469] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 10.261901] usb usb2: SerialNumber: ehci-omap.0
[ 10.267181] hub 2-0:1.0: USB hub found
[ 10.271057] hub 2-0:1.0: 3 ports detected
[ 10.301330] Initializing USB Mass Storage driver…
[ 10.306427] usbcore: registered new interface driver usb-storage
[ 10.312530] USB Mass Storage support registered.
[ 10.317596] mice: PS/2 mouse device common for all mice
[ 10.323242] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 10.331115] input: twl4030_pwrbutton as /devices/platform/i2c_omap.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 10.341888] i2c /dev entries driver
[ 10.345977] Linux video capture interface: v2.00
[ 10.350982] omap-iommu omap-iommu.0: isp: version 1.1
[ 10.356201] Saving csi2 context
[ 10.356323] Restoring csi2 context
[ 10.356384] Saving csi2 context
[ 10.357391] vpfe_init
[ 10.360260] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 10.473388] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card detect
[ 10.480438] Registered led device: beagleboard::usr0
[ 10.485626] Registered led device: beagleboard::usr1
[ 10.492248] Registered led device: beagleboard::pmu_stat
[ 10.499359] usbcore: registered new interface driver usbhid
[ 10.505035] usbhid: USB HID core driver
[ 10.509094] Advanced Linux Sound Architecture Driver Version 1.0.21.
[ 10.516021] usbcore: registered new interface driver snd-usb-audio
[ 10.585693] No device for DAI omap-mcbsp-dai-0
[ 10.590240] No device for DAI omap-mcbsp-dai-1
[ 10.594726] No device for DAI omap-mcbsp-dai-2
[ 10.599243] No device for DAI omap-mcbsp-dai-3
[ 10.603729] No device for DAI omap-mcbsp-dai-4
[ 10.608245] OMAP3 Beagle SoC init
[ 10.612396] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 10.623901] ALSA device list:
[ 10.626922] #0: omap3beagle (twl4030)
[ 10.630950] oprofile: using arm/armv7
[ 10.634857] TCP cubic registered
[ 10.638183] NET: Registered protocol family 17
[ 10.642700] NET: Registered protocol family 15
[ 10.647308] lib80211: common routines for IEEE802.11 drivers
[ 10.653045] lib80211_crypt: registered algorithm ‘NULL’
[ 10.653076] ThumbEE CPU extension supported.
[ 10.657379] Power Management for TI OMAP3.
[ 10.662811] Unable to set L3 frequency (400000000)
[ 10.667724] Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/1000 MHz
[ 10.675109] IVA2 clocking rate: 800 MHz
[ 10.847961] SmartReflex driver initialized
[ 10.852233] omap3beaglelmb: Driver registration complete
[ 10.861694] Disabling unused clock “sr2_fck”
[ 10.861724] Disabling unused clock “sr1_fck”
[ 10.861724] Disabling unused clock “mcbsp_fck”
[ 10.861755] Disabling unused clock “mcbsp_fck”
[ 10.861785] Disabling unused clock “mcbsp_ick”
[ 10.861816] Disabling unused clock “gpt2_ick”
[ 10.861816] Disabling unused clock “gpt3_ick”
[ 10.861816] Disabling unused clock “gpt4_ick”
[ 10.861846] Disabling unused clock “gpt5_ick”
[ 10.861846] Disabling unused clock “gpt6_ick”
[ 10.861877] Disabling unused clock “gpt7_ick”
[ 10.861877] Disabling unused clock “gpt8_ick”
[ 10.861877] Disabling unused clock “gpt9_ick”
[ 10.861907] Disabling unused clock “wdt3_ick”
[ 10.861907] Disabling unused clock “wdt3_fck”
[ 10.861938] Disabling unused clock “gpio2_dbck”
[ 10.861938] Disabling unused clock “gpio3_dbck”
[ 10.861938] Disabling unused clock “gpio4_dbck”
[ 10.861968] Disabling unused clock “gpio5_dbck”
[ 10.861968] Disabling unused clock “gpio6_dbck”
[ 10.861999] Disabling unused clock “gpt9_fck”
[ 10.861999] Disabling unused clock “gpt8_fck”
[ 10.861999] Disabling unused clock “gpt7_fck”
[ 10.862030] Disabling unused clock “gpt6_fck”
[ 10.862030] Disabling unused clock “gpt5_fck”
[ 10.862030] Disabling unused clock “gpt4_fck”
[ 10.862060] Disabling unused clock “gpt3_fck”
[ 10.862060] Disabling unused clock “gpt2_fck”
[ 10.862091] Disabling unused clock “gpt1_ick”
[ 10.862091] Disabling unused clock “wdt1_ick”
[ 10.862091] Disabling unused clock “gpio1_dbck”
[ 10.862121] Disabling unused clock “gpt1_fck”
[ 10.862121] Disabling unused clock “cam_mclk”
[ 10.862182] Disabling unused clock “des1_ick”
[ 10.862182] Disabling unused clock “sha11_ick”
[ 10.862213] Disabling unused clock “rng_ick”
[ 10.862213] Disabling unused clock “aes1_ick”
[ 10.862213] Disabling unused clock “ssi_ick”
[ 10.862243] Disabling unused clock “mailboxes_ick”
[ 10.862243] Disabling unused clock “mcbsp_ick”
[ 10.862274] Disabling unused clock “gpt10_ick”
[ 10.862274] Disabling unused clock “gpt11_ick”
[ 10.862304] Disabling unused clock “hdq_ick”
[ 10.862304] Disabling unused clock “mspro_ick”
[ 10.862304] Disabling unused clock “des2_ick”
[ 10.862335] Disabling unused clock “sha12_ick”
[ 10.862335] Disabling unused clock “aes2_ick”
[ 10.862365] Disabling unused clock “icr_ick”
[ 10.862365] Disabling unused clock “pka_ick”
[ 10.862365] Disabling unused clock “ssi_ssr_fck”
[ 10.862396] Disabling unused clock “hdq_fck”
[ 10.862396] Disabling unused clock “mcbsp_fck”
[ 10.862426] Disabling unused clock “mspro_fck”
[ 10.862426] Disabling unused clock “gpt11_fck”
[ 10.862457] Disabling unused clock “gpt10_fck”
[ 10.862457] Disabling unused clock “sad2d_ick”
[ 10.862487] Disabling unused clock “dpll4_m6x2_ck”
[ 10.862487] Disabling unused clock “dpll3_m3x2_ck”
[ 10.862518] Disabling unused clock “sys_clkout1”
[ 10.863037] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 10.871337] registered taskstats version 1
[ 10.999359] Console: switching to colour frame buffer device 160x45
[ 11.021697] regulator_init_complete: incomplete constraints, leaving VAUX3 on
[ 11.029541] regulator_init_complete: incomplete constraints, leaving VDAC on
[ 11.037536] omap_vout omap_vout: probed for an unknown device
[ 11.043853] Waiting for root device /dev/mmcblk0p2…
[ 11.066925] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 11.075286] mmc0: new high speed SDHC card at address aaaa
[ 11.081237] mmcblk0: mmc0:aaaa SU04G 3.69 GiB
[ 11.086120] mmcblk0: p1 p2
[ 11.162170] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 11.171691] kjournald starting. Commit interval 5 seconds
[ 11.183929] EXT3-fs (mmcblk0p2): using internal journal
[ 11.193115] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
[ 11.204071] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 11.221343] devtmpfs: mounted
[ 11.228179] Freeing init memory: 204K
[ 12.218109] Restoring csi2 context
[ 13.932373] Saving csi2 context
[ 15.908111] Bluetooth: Core ver 2.15
[ 15.916656] NET: Registered protocol family 31
[ 15.925048] Bluetooth: HCI device and connection manager initialized
[ 15.935394] Bluetooth: HCI socket layer initialized
[ 15.959167] Bluetooth: L2CAP ver 2.14
[ 15.966979] Bluetooth: L2CAP socket layer initialized
[ 15.990203] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 16.102355] NET: Registered protocol family 10
[ 16.137481] Bluetooth: RFCOMM TTY layer initialized
[ 16.146636] Bluetooth: RFCOMM socket layer initialized
[ 16.155822] Bluetooth: RFCOMM ver 1.11
