Hello all,
i've tried to boot up beagleboard XM with MLO, u-boot.bin and uImage built by myself.
but it seemed not working properly.
after this message. "Loading u-boot.bin from mmc"
it is supposed to run u-boot code as far as I know.
xloader/lib/board.c
start_armboot() -> ((init_fnc_t *)CFG_LOADADDR)();
but the board got freezing after start_armboot().
it means there are no available instruction at CFG_LOADADDR.
how do I have to deal with it. I have no debugger using jtag.
please give me the way to solves it.
Hongwoo.
btw, I followed with guide http://elinux.org/BeagleBoard#Source
is there anyone to give me a bit of clue ??
when I use original u-boot.bin that is included in SD card, it works
fine with MLO and uImage made by myself.
Hongwoo.
Just copy MLO and u-boot.img, which are built from u-boot mainline
v2011.12, to the SD card and give it a try. Don't use a different
repository for u-boot and MLO.
Robert
Thanks Robert,
I built u-boot with below link. as you said
http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=commit;h=cba9a894fdb1cb49b60fcd1d1d6919cbd7995dd5
and then I got this …
U-Boot SPL 2011.12 (Mar 12 2012 - 23:01:25)
Texas Instruments Revision detection unimplemented
OMAP SD/MMC: 0
timed out in wait_for_bb: I2C_STAT=1000
reading u-boot.img
spl: error reading image u-boot.img, err - -1
ERROR ### Please RESET the board
any other suggestion ?
It tells you it can't find u-boot.img.
Did you copy u-boot.img (and __NOT__ u-boot.bin) to the same partition
with MLO?
..."As far as I know we never had an undetected error." - Anonymous
My public pgp key is available at:
http://pgp.mit.edu:11371/pks/lookup?op=get&search=0x90320BF1
Hi Robert,
I am getting the same error and I made sure to copy the u-boot.img from:
http://angstrom.s3.amazonaws.com/demo/beagleboard/index.html
I am still getting the same error.
Any help would be welcome.
-Kartik
