Beagleboard Xm watchdog problems
I am using the stock 2.6.32 kernel on Beagleboard xM. When I attempt to trigger the watchdog my system hangs rather than reboots. My simple test is as follows:
# cat > /dev/watchdog
The system then hangs ~60 seconds later, I would presume that it should reboot. Are there any board settings that would cause this behavior?
TIA,
Dave.
