BeagleBoardAndOpenEmbeddedGit: packages missing
Hi:
  I'm following the instructions in http://elinux.org/BeagleBoardAndOpenEmbeddedGit
and have gotten stuck. When running:
bitbake console-image
I get:
http://cgit.openembedded.net/cgit.cgi?url=openembedded/commit/&id=709c4d66e0b107ca606941b988bad717c0b45d9b
regards,
koen
That fixed it. I just did
ln -s recipes packages
and it's doing something now.
Thanks for the quick response....
--Mark
And now a new problem. Running bitbake console-image I get the
following:
The problem might have been from an earlier install. When running yum
install I got:
sudo yum install gtk-doc-tools g++ python-psyco build-essential
Loaded plugins: refresh-packagekit
Setting up Install Process
Parsing package install arguments
No package gtk-doc-tools available.
No package g++ available.
No package python-psyco available.
No package build-essential available.
Nothing to do
How do I get these to install?
--Mark
Hello Mark,
make: GNUmakefile: Too many levels of symbolic links
Very likely, your softlink from packages/ to recipes/ is probably
recursively followed by one of the recipes.
Remove the softlink.
Also, maybe you are just running into a remaining issues (dangling
references) with the rename from "packages" to "recipes".
I have seen some commits to fix that, so I suggest you pull / update
again and retry.
I had the same error. I manualy removed GNUmakefile and did manually a make.
Do you use directly the git from openembedded or a mirror?
Robert
Thanks for the suggestions.
I got rid of the symbolic link and my mv'ed packages to recipes. Then
I did
git pull
git checkout
The pull updated some things, but got the same symbolic link error.
Any other suggestions?
--Mark
packages was renamed to recipes. Look for BBPATH and BBFILES and
change the references from packages to recipes.
Hopefully the docs are getting updated.
Philip
Robert:
  I see GNUmakefile was symlinked to itself. I removed it from the m4-
native-1.4.12-r0 directory and typed 'make'.
Now I'm running 'bitbake console-image' and it seems to be running
fine.
Thanks for the tip.
The instructions said:
git clone git://git.openembedded.net/openembedded
which I assume isn't a mirror.
--Mark
It isn't. But I did see this failure only when using
http://repo.or.cz/r/openembedded.git
This night I did a full installation from openembedded.net and
everything was okay. Two ours ago installation from repo.or.cz failed
with this failure (and a few more).
Robert
