Hello Beagleboard Community,
I want to check with people on here on my suspicion that I may have killed my beaglebone’s usb hub.
It had been working perfectly fine over the past weekend. I put it in it’s altoid’s tin and was keeping it with me for study breaks. On my last one I noticed that I was no longer able to access ttyUSB0, in fact no serial console was being displayed. At first I thought that a recent kernel upgrade (on my laptop) had caused this, so I rolled back to the previous kernel with no change. My dmesg outputs are below:
[ 1236.313314] usb 8-1: device descriptor read/64, error -71
[ 1236.533285] usb 8-1: device descriptor read/64, error -71
[ 1236.743339] usb 8-1: new full-speed USB device number 11 using uhci_hcd
[ 1236.859976] usb 8-1: device descriptor read/64, error -71
[ 1237.079984] usb 8-1: device descriptor read/64, error -71
[ 1237.290009] usb 8-1: new full-speed USB device number 12 using uhci_hcd
[ 1237.703338] usb 8-1: device not accepting address 12, error -71
[ 1237.809974] usb 8-1: new full-speed USB device number 13 using uhci_hcd
[ 1238.223309] usb 8-1: device not accepting address 13, error -71
[ 1238.223337] hub 8-0:1.0: unable to enumerate USB device on port 1
When googling around with this I found a few posts saying that the problem was with uhci_hcd and the I could remove that module and use the usb port as usb1.1. I’m afraid I haven’t been able to reproduce those dmesg logs, as it was a couple hours ago that I did that, but it didn’t work. Now what makes me think that I some how damaged the beaglebone’s usb is the following dmesg output when plugged into a different usb port on my system:
[ 1485.256623] usb 6-1: device descriptor read/64, error -71
[ 1485.476618] usb 6-1: device descriptor read/64, error -71
[ 1485.686629] usb 6-1: new full-speed USB device number 5 using uhci_hcd
[ 1485.713649] usb 6-1: not running at top speed; connect to a high speed hub
[ 1485.723756] hub 6-1:1.0: USB hub found
[ 1485.725654] hub 6-1:1.0: 2 ports detected
[ 1485.828671] hub 6-1:1.0: hub_port_status failed (err = -71)
[ 1485.829650] hub 6-1:1.0: hub_port_status failed (err = -71)
[ 1488.357662] hub 6-1:1.0: hub_port_status failed (err = -71)
[ 1488.358645] hub 6-1:1.0: hub_port_status failed (err = -71)
It’s the device descriptor read/64, error -71 and hub_port_status failed (err = -71) that really concern me. The first output suggests I can keep poking around with uhci_hcd to fix it, but the second suggests to me that the hub is not communicating.
I have been able to reproduce this on three seperate linux machines (all the same distro, but I can load up another distro if that is worth testing). A windows 7 x64 machine with the 64bit drivers from the beaglebone getting started page installed reports an Unknown Devices when the beaglebone is plugged in.
When connected via the ethernet conection I was able to ssh into the beaglebone (while connected via usb). Once I tried to enable the ethernet over usb the beaglebone stopped responding, and would not accept another ssh season.
I’m hoping someone can suggest another software thing I can try, or if this seems like a hardware problem?
Thank you all for your time.
Have a good one,
magyarm
