hi,
I let this run for sometime & got this message:
[ 1.665527] Waiting for root device /dev/mmcblk0p2…
[ 1.754058] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 1.767089] mmc0: new high speed SDHC card at address aaaa
[ 1.773529] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[ 1.780181] mmcblk0: p1 p2 p3
[ 1.858001] mmc1: host does not support reading read-only switch. assuming write-enable.
[ 1.868286] mmc1: new high speed SDHC card at address 0001
[ 1.874694] mmcblk1: mmc1:0001 00000 3.79 GiB
[ 240.151611] INFO: task kworker/u:1:36 blocked for more than 120 seconds.
[ 240.158721] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 240.167083] kworker/u:1 D c0261211 0 36 2 0x00000000
[ 240.173889] INFO: task mmcqd/1:42 blocked for more than 120 seconds.
[ 240.180633] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 240.188964] mmcqd/1 D c0261211 0 42 2 0x00000000
[ 360.191619] INFO: task kworker/u:1:36 blocked for more than 120 seconds.
[ 360.198730] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 360.207092] kworker/u:1 D c0261211 0 36 2 0x00000000
[ 360.213897] INFO: task mmcqd/1:42 blocked for more than 120 seconds.
[ 360.220642] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 360.228973] mmcqd/1 D c0261211 0 42 2 0x00000000
[ 480.231628] INFO: task kworker/u:1:36 blocked for more than 120 seconds.
[ 480.238739] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 480.247070] kworker/u:1 D c0261211 0 36 2 0x00000000
[ 480.253875] INFO: task mmcqd/1:42 blocked for more than 120 seconds.
[ 480.260620] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 480.268951] mmcqd/1 D c0261211 0 42 2 0x00000000
[ 600.271606] INFO: task kworker/u:1:36 blocked for more than 120 seconds.
[ 600.278717] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 600.287078] kworker/u:1 D c0261211 0 36 2 0x00000000
[ 600.293884] INFO: task mmcqd/1:42 blocked for more than 120 seconds.
[ 600.300628] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 600.308959] mmcqd/1 D c0261211 0 42 2 0x00000000
[ 720.311645] INFO: task kworker/u:1:36 blocked for more than 120 seconds.
[ 720.318756] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 720.327117] kworker/u:1 D c0261211 0 36 2 0x00000000
[ 720.333923] INFO: task mmcqd/1:42 blocked for more than 120 seconds.
[ 720.340667] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 720.348999] mmcqd/1 D c0261211 0 42 2 0x00000000
<7>[ 1472.531585] driver_probe_done: probe_count = 1
I googled a bit, seems like a known issue with mmc detection in omap/am335x. (Someone talked about a kernel hang up)
Any ideas? Anyone recollects any solution to this?
-Pj
