before doing something wrong...
There is a DVI/Audio-Cape which occupies the same
LCD data lines as the LCD7 Cape as inputs (CPU out, LCD7/DVI in).
Two questions:
Is it possible to switch between both (they do have different
resolutions) via software and therefore prevent the CPU from driving
two input ports at the same time?
And:
The DVI/Audio Cape seems to have von Boot-Eeprom with the first
release and uses I2C2 for other purposes...this seems contradictionary
to me to what is said about cape design by the same source as those,
who have built the DVI/Audio Cape...? Will it work non the less?
Sources:
http://beagleboardtoys.com/wiki/index.php?title=BeagleBone_DVI-D_with_Audio
and
http://beagleboardtoys.com/wiki/index.php?title=BeagleBone_LCD7
Thank you very much in advance for any help!
Best regards,
mcc
