Beaglebone AI64 is not booting
Hi All,
I have purchased new beagleboneblack AI-64, I was updating firmware. During the updation board turned off automatically. I am not sure about the reason.
Board was not much heated up when I checked.
After this board is not getting booted up. I am not sure what to do.
Can anyone suggest regarding this issue?
Is the board is damaged?
Is it possible to recover it.
Now once I connect the power none of the LED is blinking and I can hear a small beap sound immediately I connect power source.
Please help…
Abhishek
Hi Abhishek,
How are you providing power to the board? Through the barrel connector, usb-c plug, header? What is the current rating for your transformer? I had an issue a few months ago that the board wouldn’t boot, I thought the board was toast but it was due to a high voltage drop on the cable I was using to connect to the barrel connector. Replacing with a raspberry Pi usb-c power supply solved it!
Good luck,
Xtof
Hello
Here are some steps you can try to troubleshoot and potentially recover the board:
  1. Power Cycle: Disconnect and reconnect the power supply.
  2. Check Power Supply: Ensure it meets specifications.
  3. Reflash Firmware: Follow instructions to reflash firmware.
  4. Serial Console: Connect and check for error messages.
  5. Recovery Mode: Check for a recovery or safe mode.
  6. Inspect for Damage: Look for physical damage on the board.
  7. Contact Support: Reach out to the manufacturer’s support.
  8. Community Forums: Check online forums for advice.
    you can check https://forum.beagleboard.org/c/general/8/click here
Thnk you
