Since I've had problems getting all the software on the BeagleBone
running correctly, I've done a set of experiments, trying 3 different
images and evaluating the differences. Interestingly, the behavior of
each image is different. The image Angstrom-Cloud9-IDE-eglibc-ipk-
v2012.01-core-beaglebone-2012.01.11.img comes the closest to operating
as advertised, but not quite. I'd like any insight anyone may have as
to:
1) Why the images behave differently
2) What I can do to get all the software running as advertised
Below is the information from my experiments. Thanks for your help.
John
BeagleBone Startup Behavior
Base Platform
Windows XP SP 3
Intel Pentium M 2 GHz
2 Gb RAM
Browser – Chrome
Console Terminal - PuTTY
Wireless Ethernet connection shared with services turned on.
BeagleBone Rev A3
Image 1
Angstrom-Cloud9-IDE-eglibc-ipk-v2011.11-core-beaglebone-2011.11.16.img
Configuration
1. USB cable
2. Crossover Ethernet cable
3. 5V Power Adapter
Process
1. Plug in Ethernet cable
2. Power up card
3. Plug in USB cable once in normal blinking mode
Result
1. BeagleBone shows up as “BeagleBone Getting Started (E:)”
2. Can read files on E drive
3. Unable to connect serial console to BeagleBone
4. Web server inaccessible
Next Step
1. Eject E drive
2. Still Unable to connect serial console to BeagleBone
3. Web server inaccessible
Next Step
1. With the BeagleBone powered externally, unplug the USB cable
2. Reconnect the USB cable
3. Connect serial console and login
Result
1. BeagleBone 101 presentation runs at 192.168.7.2
2. GateOne DOES NOT RUN at https://192.168.7.2. First message –
Security certificate not trusted. Select “Proceed Anyway”. Error
message: “This webpage has a redirect loop”
3. Cloud9 IDE runs at http://192.168.7.2:3000
4. Console command “ifconfig” SHOWS NO inet addr for eth0.
Image 2
Angstrom-Cloud9-IDE-eglibc-ipk-v2012.01-core-beaglebone-2012.01.11.img
Configuration
1. USB cable
3. 5V Power Adapter
Process
2. Power up card
Result
Next Step
1. Eject E drive
2. Connect serial console and login
Result
1. BeagleBone 101 presentation DOES NOT RUN at 192.168.7.2
2. GateOne eventually runs at https://192.168.7.2. First message –
Security certificate not trusted. Select “Proceed Anyway”. GateOne
begins to run.
4. Console command “ifconfig” shows inet addr 192.168.0.193 for eth0.
5. PuTTY can connect for SSH session to 192.168.0.193
Image 3
Angstrom-Cloud9-IDE-eglibc-ipk-v2012.01-core-beaglebone-2012.01.27.img
Configuration
1. USB cable
3. 5V Power Adapter
Process
2. Power up card
Result
Next Step
1. Eject E drive
3. GateOne eventually runs at https://192.168.7.2. First message –
begins to run.
Next Step
Result
2. GateOne still runs at https://192.168.7.2.
3. Cloud9 IDE DOES NOT RUN at http://192.168.7.2:3000
4. Console command “ifconfig” shows inet addr 192.168.0.146 for eth0.
5. PuTTY can connect for SSH session to 192.168.0.146
