Someone tried this cape Audio Cape??
I was reading the Wiki and it says that works with i2c interface: i was wondering if this is a quality limitation (for audio recording for example) because the i2c port on the BB can go as fast as 400kbps??
Am i thinking wrong?
Not sure where you got the i2c part. The description is quite clear:
The BeagleBone Audio Cape provides stereo audio input and output for the BeagleBone by using the TLV320AIC3106 codec. Audio data is sampled at up to 96 kHz during recording or playback. The codec interfaces with the Multichannel Audio Serial Port of the AM335x via audio serial bus. The BeagleBone Audio Cape also features two standard 3.5mm audio jacks as audio input and output connectors.
I have it and the audio is transmitted though McASP0 in PCM burst mode. The i2c is for codec config as already stated.
BTW the audio quality is good, much better than a lot of those cheap MP3 players. Havent studied the PCB but it has little digital noise on the analog side on the schematics I just see a choke between the digital and analog ground but surely it may have different ground planes connected by the choke on a single point.
Haven´t tried the capture side of it. Actually haven´t checked the input or output impedance either. My tests its based on a Senheinser and those hyped Beats Headphones and my cheap Panasonics
Thanks everyone for your answers. I decided to order this board PCM1803A, according what i was reading in ALSA website it should be “easy” to read data from this ADC using the “arecord” command. But here is my doubt: do i need an especial driver for I2S so ALSA can recognize the ADC? or the current drivers in Angstrom can do the trick??
Thanks again.
First, check if that Sparkfun module uses 3.3V levels on I2S at least. Or you´ll need a level translator like a TXB0104 or TXS0104 (if under 20Mbps I think).
Those are the modules used on BB Audio Cape and basically the last one is the CODEC one, so you´ll need to make a driver for your CODEC (PCM1803) or maybe is already done on ALSA.
The first driver is the I2S part, I´m just starting to dig on that code to see if it actually generic to attach another CODEC to it or it needs some tweaking. As I told you at least when working with the Audio Cape the signal between McASP and the TLV320 is actually PCM not real I2S (there are some differences) with the McASP working as a master, but the McASP do support PCM mode and also slave mode but I’m not sure if the snd_soc_davinci_mcasp code has those features enabled or is just a PCM/Master implementation.
Well, i can´t wait having the board to start testing, i would like to set up the beaglebone properly with the drivers/codec defined.
According to what i being reading i put these command:
Some updates:
I finally bought de Audio Cape, I tested it in Angstron and it works really good.
But, I cant make it work under Ubuntu!
In Angstrom works right out the box…
Is there any way to access the Cape’s EEPROM???
