[beaglebone] Autostart application after boot and console login
Is there any way to autostart application after boot process and login?
In my beagleboard there was gnome desktop and when I add my program to startup applications via GUI, it was working.
In the beaglebone case there is no such option. How can I autostart my application after boot and after login?
Any suggestion would be great.
Regards
Ozkaya
system:
/etc/init.d/xxx/etc/rc.local
gnome:
~/.config/autostart
It’s about your OS. I accept you use Linux, If so, you will include to init.d and RcS. You can follow this link http://www.armadeus.com/wiki/index.php?title=Automatically_launch_your_application
If you are using Angstrom, then you probably need to figure out how to make systemd do this. The following may help to start apps on boot, but I’m not sure how to start apps after login.
http://bec-systems.com/site/tag/systemd
Cliff
