I am using ubuntu 10.04 OS to build the following:
git clone git://github.com/Angstrom-distribution/setup-scripts.git
MACHINE=beaglebone ./oebb.sh config beaglebone
MACHINE=beaglebone ./oebb.sh update
MACHINE=beaglebone ./oebb.sh bitbake virtual/kernel
following is error that i am encountering…
Using /home/kamran/.oe/environment-angstromv2012.05 to setup needed variables. It is recommended to do ‘. /home/kamran/.oe/environment-angstromv2012.05’ and run ‘bitbake something’ without using ./oebb.sh as wrapper
Executing: MACHINE=beaglebone bitbake virtual/kernel
Pseudo is not present but is required, building this first before the main build
DEBUG: Removed the following variables from the environment: GDM_KEYBOARD_LAYOUT, OE_BUILD_DIR, DISTRO_DIRNAME, OE_SOURCE_DIR, GNOME_DESKTOP_SESSION_ID, LESSOPEN, GNOME_KEYRING_CONTROL, SHLVL, LESSCLOSE, MANDATORY_PATH, WINDOWID, BBFETCH2, USERNAME, OE_BUILD_TMPDIR, OE_BASE, ORBIT_SOCKETDIR, GTK_MODULES, GDMSESSION, XDG_CONFIG_DIRS, DEFAULTS_PATH, GDM_LANG, SPEECHD_PORT, BUILDDIR, LS_COLORS, SCRIPTS_BASE_VERSION
ERROR: OE-core’s config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Failed to create a file with a long name in TMPDIR. Please use a filesystem that does not unreasonably limit filename length.
Failed to create a file with a long name in SSTATE_DIR. Please use a filesystem that does not unreasonably limit filename length.
Any help or guide how to overcome thee problems?
