I have a problem with my beaglebone black A5C, it won’t reprogrammed the eMMC.
I made this several times with success but now it begin to blink the leds and stop after some seconds in the state ( D2:ON ; D3:OFF; D4:ON; D1:OFF).
I tried to load the BBB-eMMC-flasher-debian-7.4-2014-04-14-2gb and I record the log by the serial:
cpsw, usb_ether
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
1403 bytes read in 5 ms (273.4 KiB/s)
Checking if uenvcmd is set …
Running uenvcmd …
reading zImage
3717760 bytes read in 206 ms (17.2 MiB/s)
reading initrd.img
2868661 bytes read in 160 ms (17.1 MiB/s)
reading /dtbs/am335x-boneblack.dtb
25080 bytes read in 8 ms (3 MiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x38ba80 ]
Using Device Tree in place at 88000000, end 880091f7
Starting kernel …
[ 0.381717] omap2_mbox_probe: platform not supported
[ 0.548646] tps65217-bl tps65217-bl: no platform data provided
[ 0.612540] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.649646] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.686754] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.723864] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.739996] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.749599] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.756351] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.772859] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 0.835475] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.847140] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.854429] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
Loading, please wait…
Scanning for Btrfs filesystems
systemd-fsck[217]: eMMC-Flasher: clean, 75708/102752 files, 355271/410368 blocks
Debian GNU/Linux 7 beaglebone ttyO0
default username:password is [debian:temppwd]
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
beaglebone login: [ 38.328662] libphy: PHY 4a101000.mdio:01 not found
[ 38.333745] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 58.155995] Unable to handle kernel paging request at virtual address b6f36fa0
[ 58.163634] pgd = de790000
[ 58.166470] [b6f36fa0] *pgd=9e798831, *pte=00000000, *ppte=00000000
[ 58.173074] Internal error: Oops: 17 [#1] SMP THUMB2
[ 58.178246] Modules linked in: g_multi libcomposite mt7601Usta(O)
[ 58.184619] CPU: 0 Tainted: G O (3.8.13-bone47 #1)
[ 58.190880] PC is at 0xdf79d5e8
[ 58.194166] LR is at unmap_single_vma+0x2f5/0x316
[ 58.199071] pc : [] lr : [] psr: 20000013
[ 58.199071] sp : df4afed8 ip : 00000000 fp : 00010101
[ 58.211026] r10: 464c457f r9 : df4aff00 r8 : b6f2a000
[ 58.216472] r7 : b6f36fa0 r6 : de35e968 r5 : c0cb137c r4 : 00000000
[ 58.223273] r3 : de7984f0 r2 : 0000c18e r1 : de7984d8 r0 : ffffffff
[ 58.230083] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 58.237516] Control: 50c5387d Table: 9e790019 DAC: 00000015
[ 58.243504] Process sed (pid: 2034, stack limit = 0xdf4ae240)
[ 58.249497] Stack: (0xdf4afed8 to 0xdf4b0000)
[ 58.256342] fec0: de77b584 c0098c23
[ 58.265511] fee0: 00000000 de35e968 de77b580 df2a88b8 df79d548 de35e968 b6f2a000 c009aa99
[ 58.274587] ff00: de77b580 00000001 de35e968 b6f2a000 df4ae001 0000000b 00000400 de799000
[ 58.283616] ff20: de77b5cc b6f55000 00000001 c045b6cb de77b5c8 c021fd01 de77b580 de35e968
[ 58.292645] ff40: de77b580 de35e968 df79d548 de35e968 b6f2a000 c009b955 b6f37000 c045b699
[ 58.301640] ff60: de77b5c8 df2a88b8 c07e13c0 de77b5c8 0000cbf1 b6f2a000 de77b580 c000c1c4
[ 58.310637] ff80: df4ae000 00000000 b6f5556c c009b9e3 b6f2a002 b6f558b8 00000000 00000001
[ 58.319670] ffa0: 0000005b c000c021 b6f558b8 00000000 b6f2a000 0000cbf1 b6f55000 b6f2a002
[ 58.328663] ffc0: b6f558b8 00000000 00000001 0000005b b6f54dc8 b6f55560 0000010c b6f5556c
[ 58.337660] ffe0: bef26980 bef26968 b6f3df19 b6f470dc 80000010 b6f2a000 00000000 00000000
[ 58.346265] [] (unmap_single_vma+0x2f5/0x316) from [] (_raw_spin_lock_irqsave+0xd/0x10)
[ 58.356464] [] (_raw_spin_lock_irqsave+0xd/0x10) from [] (__up_write+0x11/0xf4)
[ 58.365928] [] (__up_write+0x11/0xf4) from [] (0xdf2a88b8)
[ 58.378173] Code: 00000015 df79d5dc df79d5dc 00000000 (c047a6d0)
[ 58.384573] —[ end trace 4981c6f16a13d905 ]—
[ 108.032416] Unable to handle kernel paging request at virtual address e6fefddb
[ 108.040075] pgd = df4f0000
[ 108.042946] [e6fefddb] *pgd=00000000
[ 108.046753] Internal error: Oops: 5 [#2] SMP THUMB2
[ 108.051909] Modules linked in: g_multi libcomposite mt7601Usta(O)
[ 108.058418] CPU: 0 Tainted: G D O (3.8.13-bone47 #1)
[ 108.064784] PC is at check_preempt_wakeup+0x76/0x128
[ 108.070047] LR is at check_preempt_curr+0x1d/0x4c
[ 108.075030] pc : [] lr : [] psr: a00000b3
[ 108.075030] sp : df2d7c20 ip : 00000000 fp : 00513000
[ 108.087142] r10: df317940 r9 : 00000000 r8 : 00000000
[ 108.092666] r7 : de652b40 r6 : df317978 r5 : c004c55c r4 : c0cb1fc0
[ 108.099559] r3 : 00000002 r2 : e6fefcbb r1 : ec000000 r0 : 00000000
[ 108.106456] Flags: NzCv IRQs off FIQs on Mode SVC_32 ISA Thumb Segment user
[ 108.114267] Control: 50c5387d Table: 9f4f0019 DAC: 00000015
[ 108.120339] Process dbus-daemon (pid: 709, stack limit = 0xdf2d6240)
[ 108.127049] Stack: (0xdf2d7c20 to 0xdf2d8000)
[ 108.131676] 7c20: c0cb1fc0 c0464ef4 c0464ef4 df2d7c40 df317d54 00000000 00000000 c0048361
[ 108.140325] 7c40: c0825544 c0cb1fc0 df317940 c0cb1fc0 df2d7c58 c00483d7 df317940 00000001
[ 108.148972] 7c60: c0cb1fc0 df2d7c78 df317d54 00000000 c07a9890 c0049c59 000001c0 00000093
[ 108.157617] 7c80: 00000000 00000001 00000001 000000c3 df49dbf4 00000001 00000000 00000001
[ 108.166262] 7ca0: 00000001 c00b3d21 df2d7cb7 00000000 df317940 c0049c91 00000000 00000000
[ 108.174909] 7cc0: 00000000 df5652c4 df5652d0 c00b3ce1 df2d7cd8 c00451d7 00000001 df5652c0
[ 108.183555] 7ce0: 00000013 00000001 df2d7d08 00000001 000000c3 00000001 de685904 c0045e3d
[ 108.192203] 7d00: 000000c3 df2be600 de29d2c0 de6856c0 de6856c0 000000c5 df2d7f74 df2be600
[ 108.200850] 7d20: de29d2c0 c03b33ef 000000c5 c0410845 00000000 df2d7e08 dea9b740 000000c5
[ 108.209492] 7d40: ffffffff 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 108.218138] 7d60: deeec900 c04106e5 dea9b740 000000c5 df2d7f74 00000000 df2d7f20 df2d7ee0
[ 108.226783] 7d80: 00004000 c03b14cd 00000000 00000000 00000000 00000001 ffffffff 00000000
[ 108.235424] 7da0: 00000000 00000000 00000000 00000000 de652b40 00000000 00000000 00000000
[ 108.244068] 7dc0: 00000000 00000000 df2d7e08 00000000 00000000 00000000 00000000 00000000
[ 108.252709] 7de0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 108.261351] 7e00: 00000000 00000000 00000000 00000000 00000000 000000c5 dea9b740 00000000
[ 108.269999] 7e20: df2d7d44 df2d7f74 df2d7e60 00000128 c000c1c4 df2d7ee0 00000010 00000000
[ 108.278646] 7e40: df2d7f74 c03b8cf1 00000000 df2d7f74 00000000 dea9b740 000000c5 c03b17df
[ 108.287292] 7e60: 001ca267 de652b40 00000000 c004bcb3 00000000 c03b1647 1a43e9d6 00000000
[ 108.295939] 7e80: 00000019 0000004e de5b1400 de652de0 c0cb2018 0000004e de5b1400 0000004e
[ 108.304585] 7ea0: de5b1400 c004d5fd 00000000 00000000 2720691f 00000019 c0cb2018 c0cb2018
[ 108.313233] 7ec0: c0cb1fc0 7e437e42 00000002 de59b300 00000000 c045b6a5 de652b40 c004709f
[ 108.321879] 7ee0: 0008b348 00000000 00090565 00000000 df2d7f10 00000000 df080080 c045acb5
[ 108.330527] 7f00: deeec920 deeec920 defc8710 deeec920 00000000 deeec920 2720691f 00000019
[ 108.339174] 7f20: c000e947 c079efc0 00000000 00000000 defc8764 c00b5d13 00002710 df39f600
[ 108.347821] 7f40: 00000000 dea9b740 00004000 bebc7750 00000128 c000c1c4 df2d6000 00000000
[ 108.356465] 7f60: 00000000 c03b2873 00000000 de652b40 de652f2c 00000000 00000000 df2d7ee0
[ 108.365108] 7f80: 00000002 00000000 00000000 00004040 00000000 fffffff7 0000000e bebc7750
[ 108.373754] 7fa0: 00000000 c000c021 0000000e bebc7750 0000000e bebc7750 00004000 00000002
[ 108.382398] 7fc0: 0000000e bebc7750 00000000 00000128 00000000 00049428 00000000 00000000
[ 108.391045] 7fe0: bebc7750 bebc7750 0002a12f b6f5ba4c 60000010 0000000e 9fefe821 9fefec21
[ 108.399714] [] (check_preempt_wakeup+0x76/0x128) from [] (check_preempt_curr+0x1d/0x4c)
[ 108.410018] [] (check_preempt_curr+0x1d/0x4c) from [] (ttwu_do_wakeup+0x47/0xc0)
[ 108.419683] [] (ttwu_do_wakeup+0x47/0xc0) from [] (try_to_wake_up+0x1a9/0x1e0)
[ 108.429173] [] (try_to_wake_up+0x1a9/0x1e0) from [] (pollwake+0x41/0x48)
[ 108.438103] [] (pollwake+0x41/0x48) from [] (__wake_up_common+0x2b/0x4c)
[ 108.447029] [] (__wake_up_common+0x2b/0x4c) from [] (__wake_up_sync_key+0x2d/0x48)
[ 108.456876] [] (__wake_up_sync_key+0x2d/0x48) from [] (sock_def_readable+0x2d/0x46)
[ 108.466816] [] (sock_def_readable+0x2d/0x46) from [] (unix_stream_sendmsg+0x161/0x23c)
[ 108.477042] [] (unix_stream_sendmsg+0x161/0x23c) from [] (sock_sendmsg+0x49/0x5a)
[ 108.486798] [] (sock_sendmsg+0x49/0x5a) from [] (__sys_sendmsg+0x123/0x182)
[ 108.496000] [] (__sys_sendmsg+0x123/0x182) from [] (sys_sendmsg+0x23/0x34)
[ 108.505118] [] (sys_sendmsg+0x23/0x34) from [] (ret_fast_syscall+0x1/0x46)
[ 108.514221] Code: bf48 462a d403 e052 (f8d2) 2120
[ 108.519295] —[ end trace 4981c6f16a13d906 ]—
[ 121.433318] BUG: spinlock lockup suspected on CPU#0, dbus-daemon/709
[ 121.440050] lock: 0xc0cb1fc0, .magic: dead4ead, .owner: dbus-daemon/709, .owner_cpu: 0
[ 121.448545] [] (unwind_backtrace+0x1/0x8a) from [] (do_raw_spin_lock+0xa3/0xfc)
[ 121.458124] [] (do_raw_spin_lock+0xa3/0xfc) from [] (try_to_wake_up+0x1a1/0x1e0)
[ 121.467787] [] (try_to_wake_up+0x1a1/0x1e0) from [] (autoremove_wake_function+0x9/0x1c)
[ 121.478085] [] (autoremove_wake_function+0x9/0x1c) from [] (__wake_up_common+0x2b/0x4c)
[ 121.488381] [] (__wake_up_common+0x2b/0x4c) from [] (__wake_up+0x27/0x38)
[ 121.497406] [] (__wake_up+0x27/0x38) from [] (update_process_times+0x2b/0x48)
[ 121.506802] [] (update_process_times+0x2b/0x48) from [] (tick_sched_handle+0x37/0x40)
[ 121.516921] [] (tick_sched_handle+0x37/0x40) from [] (tick_sched_timer+0x2b/0x4c)
[ 121.526679] [] (tick_sched_timer+0x2b/0x4c) from [] (__run_hrtimer+0xb3/0x140)
[ 121.536159] [] (__run_hrtimer+0xb3/0x140) from [] (hrtimer_interrupt+0xd7/0x1c8)
[ 121.545832] [] (hrtimer_interrupt+0xd7/0x1c8) from [] (omap2_gp_timer_interrupt+0x11/0x1c)
[ 121.556416] [] (omap2_gp_timer_interrupt+0x11/0x1c) from [] (handle_irq_event_percpu+0x4d/0x174)
[ 121.567538] [] (handle_irq_event_percpu+0x4d/0x174) from [] (handle_irq_event+0x29/0x3c)
[ 121.577931] [] (handle_irq_event+0x29/0x3c) from [] (handle_level_irq+0x6f/0x84)
[ 121.587591] [] (handle_level_irq+0x6f/0x84) from [] (generic_handle_irq+0x13/0x1c)
[ 121.597434] [] (generic_handle_irq+0x13/0x1c) from [] (handle_IRQ+0x3b/0x5c)
[ 121.606726] [] (handle_IRQ+0x3b/0x5c) from [] (omap3_intc_handle_irq+0x39/0x58)
[ 121.616292] [] (omap3_intc_handle_irq+0x39/0x58) from [] (__irq_svc+0x3b/0x5c)
[ 121.625745] Exception stack(0xdf2d79f8 to 0xdf2d7a40)
[ 121.631088] 79e0: df2f7fc4 df2f7fc4
[ 121.639735] 7a00: 00af00ae 00000002 de652b40 0000000b df2d7abb 00000020 00000001 c066201f
[ 121.648382] 7a20: c0662017 00000004 00000000 df2d7a40 c045b6a5 c045b6a6 60000133 ffffffff
[ 121.657051] [] (__irq_svc+0x3b/0x5c) from [] (_raw_spin_unlock_irq+0x8/0xa)
[ 121.666266] [] (_raw_spin_unlock_irq+0x8/0xa) from [] (do_exit+0x165/0x618)
[ 121.675474] [] (do_exit+0x165/0x618) from [] (die+0x24d/0x298)
[ 121.683492] [] (die+0x24d/0x298) from [] (__do_kernel_fault.part.8+0x37/0x54)
[ 121.692885] [] (__do_kernel_fault.part.8+0x37/0x54) from [] (do_bad_area+0x43/0x48)
[ 121.702827] [] (do_bad_area+0x43/0x48) from [] (do_translation_fault+0x5b/0x64)
[ 121.712393] [] (do_translation_fault+0x5b/0x64) from [] (do_DataAbort+0x27/0x60)
[ 121.722046] [] (do_DataAbort+0x27/0x60) from [] (__dabt_svc+0x35/0x60)
[ 121.730768] Exception stack(0xdf2d7bd8 to 0xdf2d7c20)
[ 121.736110] 7bc0: 00000000 ec000000
[ 121.744755] 7be0: e6fefcbb 00000002 c0cb1fc0 c004c55c df317978 de652b40 00000000 00000000
[ 121.753401] 7c00: df317940 00513000 00000000 df2d7c20 c0048361 c004c586 a00000b3 ffffffff
[ 121.762052] [] (__dabt_svc+0x35/0x60) from [] (check_preempt_wakeup+0x76/0x128)
[ 121.771621] [] (check_preempt_wakeup+0x76/0x128) from [] (check_preempt_curr+0x1d/0x4c)
[ 121.781920] [] (check_preempt_curr+0x1d/0x4c) from [] (ttwu_do_wakeup+0x47/0xc0)
[ 121.791580] [] (ttwu_do_wakeup+0x47/0xc0) from [] (try_to_wake_up+0x1a9/0x1e0)
[ 121.801062] [] (try_to_wake_up+0x1a9/0x1e0) from [] (pollwake+0x41/0x48)
[ 121.809988] [] (pollwake+0x41/0x48) from [] (__wake_up_common+0x2b/0x4c)
[ 121.818913] [] (__wake_up_common+0x2b/0x4c) from [] (__wake_up_sync_key+0x2d/0x48)
[ 121.828754] [] (__wake_up_sync_key+0x2d/0x48) from [] (sock_def_readable+0x2d/0x46)
[ 121.838689] [] (sock_def_readable+0x2d/0x46) from [] (unix_stream_sendmsg+0x161/0x23c)
[ 121.848903] [] (unix_stream_sendmsg+0x161/0x23c) from [] (sock_sendmsg+0x49/0x5a)
[ 121.858658] [] (sock_sendmsg+0x49/0x5a) from [] (__sys_sendmsg+0x123/0x182)
[ 121.867860] [] (__sys_sendmsg+0x123/0x182) from [] (sys_sendmsg+0x23/0x34)
[ 121.876969] [] (sys_sendmsg+0x23/0x34) from [] (ret_fast_syscall+0x1/0x46)
I don’t know what I can make, i think it’s an hardware problem.
Has anybody an idea that I can try?
