Hi I’m having trouble getting my 4.3" LCD to work with Debian 9.x (Stretch). The LCD works with the Debian 8.x image (jessie) provided by element14, so I know the hardware is good and connected correctly.
I’ve tried both the IOT image and the full desktop image, neither one activates the LCD.
Below are my uEnv.txt and syslog files
syslog:
Mar 9 22:11:00 beaglebone kernel: [ 1.821695] bone_capemgr bone_capemgr: slot #3: ‘BB-CAPE-DISP-CT43,00A0,Embest,BB-CAPE-DISP-CT4’
Mar 9 22:11:00 beaglebone kernel: [ 1.830940] bone_capemgr bone_capemgr: initialized OK.
Mar 9 22:11:00 beaglebone kernel: [ 1.833495] PM: bootloader does not support rtc-only!
Mar 9 22:11:00 beaglebone kernel: [ 1.834546] omap_rtc 44e3e000.rtc: setting system clock to 2018-03-09 22:10:49 UTC (1520633449)
Mar 9 22:11:00 beaglebone kernel: [ 1.834560] of_cfs_init
Mar 9 22:11:00 beaglebone kernel: [ 1.834697] of_cfs_init: OK
Mar 9 22:11:00 beaglebone kernel: [ 1.835448] PM: Hibernation image not present or could not be loaded.
Mar 9 22:11:00 beaglebone kernel: [ 1.835590] ALSA device list:
Mar 9 22:11:00 beaglebone kernel: [ 1.835596] No soundcards found.
Mar 9 22:11:00 beaglebone kernel: [ 1.837749] Freeing unused kernel memory: 1024K
Mar 9 22:11:00 beaglebone kernel: [ 1.855591] tilcdc 4830e000.lcdc: no encoders/connectors found
Mar 9 22:11:00 beaglebone kernel: [ 1.991337] usb 1-1: new high-speed USB device number 2 using musb-hdrc
Mar 9 22:11:00 beaglebone kernel: [ 2.143004] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
Mar 9 22:11:00 beaglebone kernel: [ 2.143023] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Mar 9 22:11:00 beaglebone kernel: [ 2.143031] usb 1-1: Product: USB2.0 Hub
Mar 9 22:11:00 beaglebone kernel: [ 2.143038] usb 1-1: Manufacturer: GenesysLogic
Mar 9 22:11:00 beaglebone kernel: [ 2.147406] hub 1-1:1.0: USB hub found
Mar 9 22:11:00 beaglebone kernel: [ 2.148016] hub 1-1:1.0: 4 ports detected
Mar 9 22:11:00 beaglebone kernel: [ 2.195974] input: EP0510M09 as /devices/platform/ocp/4819c000.i2c/i2c-2/2-0038/input/input1
Mar 9 22:11:00 beaglebone kernel: [ 2.196919] backlight supply power not found, using dummy regulator
Mar 9 22:11:00 beaglebone kernel: [ 2.198432] bone_capemgr bone_capemgr: slot #3: dtbo ‘BB-CAPE-DISP-CT4-00A0.dtbo’ loaded; overlay id #0
I added to the top of the /boot/uEnv.txt file:
dtb=am335x-boneblack-overlay.dtb
which according to https://elinux.org/Beagleboard:BeagleBone_Debian_Image_Migration#Disabling_eMMC_or_HDM should turn off HDMI. But maybe it’s turning off too much? See syslog below.
All virtual overlay commands are commented out.
/boot/uEnv.txt:
uname_r=4.9.45-ti-r57
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
enable_uboot_overlays=1
