Beaglebone Black and TLV320AIC3254 codec
I’m using a BeagleBone Black running under the latest available Debian and a TLV320AIC3254 evaluation board. I’m struggling to make this codec as an ALSA sound card.
I used the BB-BONE-AUDI-02 DTS file (with a little bit of modification to suit my hardware), the device is found and mounted as an ALSA sound card. I know that the AIC3x is not compatible with the AIC3254.
So I drifted this .dts file to suit my application by replacing tlv320aic3x by tlv320aic32x4 (as the driver seems already available in this linux core). See below.
```* Copyright © 2012 Texas Instruments Incorporated - http://www.ti.com/`
```* This program is free software; you can redistribute it and/or modify`
```* it under the terms of the GNU General Public License version 2 as`
```* published by the Free Software Foundation.`
/dts-v1/;
/plugin/;
```compatible = “ti,beaglebone”, “ti,beaglebone-black”;`
```/* identification */`
```part-number = “BB-BONE-AUDI-02”;`
```version = “00A0”, “A0”;`
```/* state the resources this cape uses */`
```exclusive-use =`
```/* the pin header uses */`
```“P9.31”, /* mcasp0: mcasp0_aclkx */`
```“P9.29”, /* mcasp0: mcasp0_fsx */`
```“P9.28”, /* mcasp0: mcasp0_axr2 */`
```“P9.25”, /* mcasp0: mcasp0_ahclkx */`
```/* the hardware ip uses */`
```“gpio1_18”, “gpio1_19”,`
```“mcasp0”;`
```fragment@0 {`
```target = <&am33xx_pinmux>;`
```overlay {`
```i2c2_pins: pinmux_i2c2_pins {`
```pinctrl-single,pins = <`
```0x17c 0x73 /spi0_scl.i2c2_sda,SLEWCTRL_SLOW | INPUT_PULLUP |MODE2/`
```0x178 0x73 /spi0_d0.i2c2_scl,SLEWCTRL_SLOW | INPUT_PULLUP | MODE2/`
```bone_audio_cape_audio_pins: pinmux_bone_audio_cape_audio_pins {`
```0x1ac 0x00 /* mcasp0_ahclkx, MODE0 | INPUT */`
```0x19c 0x22 /* mcasp0_ahclkr, */`
```0x194 0x20 /* mcasp0_fsx, MODE0 | OUTPUT */`
```0x190 0x20 /* mcasp0_aclkr.mcasp0_aclkx, MODE0 | OUTPUT_PULLDOWN */`
```0x198 0x20`
```fragment@1 {`
```target = <&i2c2>;`
```overlay {`
```#address-cells = <1>;`
```#size-cells = <0>;`
```clock-frequency = <100000>;`
```status = “okay”;`
```pinctrl-names = “default”;`
```pinctrl-0 = <&i2c2_pins>;`
```tlv320aic32x4: tlv320aic32x4@18 {`
```compatible = “ti,tlv320aic32x4”;`
```reg = <0x18>;`
```fragment@2 {`
```target = <&mcasp0>;`
```overlay {`
```pinctrl-0 = <&bone_audio_cape_audio_pins>;`
```op-mode = <0>; /* MCASP_IIS_MODE */`
```tdm-slots = <2>;`
```num-serializer = <16>;`
```serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */`
```2 0 1 0`
```0 0 0 0`
```0 0 0 0`
```0 0 0 0`
```tx-num-evt = <1>;`
```rx-num-evt = <1>;`
```fragment@3 {`
```target = <&ocp>;`
```overlay {`
```sound {`
```compatible = “ti,da830-evm-audio”;`
```ti,model = “DA830 EVM”;`
```ti,audio-codec = <&tlv320aic32x4>;`
```ti,mcasp-controller = <&mcasp0>;`
```ti,codec-clock-rate = <24000000>;`
```ti,audio-routing =`
```“Headphone Jack”, “HPLOUT”,`
```“Headphone Jack”, “HPROUT”,`
```“LINE1L”, “Line In”,`
```“LINE1R”, “Line In”;`
After loading this device tree file, the dmesg differs from the previously pseudo-working file:
[ 249.639414] davinci_evm sound.12: ASoC: CODEC (null) not registered
[ 249.647617] davinci_evm sound.12: snd_soc_register_card failed (-517)
[ 249.662908] platform sound.12: Driver davinci_evm requests probe deferral
When trying to use the ALSA sound card, I get multiple errors such as ALSA lib confmisc.c:768:(parse_card) cannot find card ‘0’.
I’ve been looking every relevent forum or website but I couldn’t find any applicable or working suggestion. I’m a beginner in beaglebone/linux programming so please be indulgent.
I don’t know what can be wrong, any help would be very appreciated.
