Beaglebone Black boot order
I thought the boot order was: eMMC, uSD, UART0, USB. But it seems to boot from uSD as long as one is present, S2 pressed or not. What’s going on here?
BBB uses MLO and u-boot from eMMC and then loads uEnv.txt file from the SDCard and then boots the kernel from the SDCard. If you press the boot button, then MLO and u-boot on the SDCard are used.
John
Ok, so no uEnv.txt and it will boot to eMMC. Thanks.
Best regards,
Sherman Boyd
I'll still have a picture online which might explain what happens:
http://ahsoftware.de/Beaglebone_Black_Boot_explained.svg
Alexander Holler
i'm not sure that diagram is complete ... as i recall from a
previous edification from RCN, the MLO and u-boot.img files might
exist *outside* of a partition, at specific offsets on the SD card
(128K and 384K, respectively, if memory serves). and those
possibilities don't seem to be mentioned in your diagram.
rday
> > MLO
You are correct, but the physical location of MLO and u-boot doesn¹t
change the boot sequence. Alex, nice work.
John
