I have somewhat bricked the BeagleBone Black. When I boot it, when connected using the serial port, it does write the ‘C’ character continuously. Looking through the board I have seen the a post (https://groups.google.com/forum/#!topic/beagleboard/pDr_rLDYqy4) where it has a similar problem. I have tried reflashing the eMMC using several images but no luck at the moment.
Using the flasher images, this is the output using the serial port:
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
Phy not found
PHY reset timed out
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
14 bytes read in 2 ms (6.8 KiB/s)
4270840 bytes read in 742 ms (5.5 MiB/s)
24125 bytes read in 37 ms (636.7 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4270776 Bytes = 4.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f88e3c
Starting kernel …
[ 0.194258] omap2_mbox_probe: platform not supported
[ 0.204902] tps65217-bl tps65217-bl: no platform data provided
[ 0.281411] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.318516] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.355625] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.392734] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.412204] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.421850] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.428623] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.451158] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 0.516302] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.528015] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.535329] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 0.756933] Unhandled fault: external abort on non-linefetch (0x1008) at 0xe09fe000
[ 0.764946] Internal error: : 1008 [#1] SMP THUMB2
[ 0.769950] Modules linked in:
[ 0.773154] CPU: 0 Not tainted (3.8.13 #1)
[ 0.777817] PC is at cpsw_probe+0x3fc/0x8a2
[ 0.782197] LR is at ioremap_page_range+0xc3/0x100
[ 0.787208] pc : [] lr : [] psr: 80000133
[ 0.787208] sp : df051e18 ip : df04d7f8 fp : 00000001
[ 0.799198] r10: df3dace0 r9 : df3d9590 r8 : 00000000
[ 0.804658] r7 : e09fe000 r6 : df10d600 r5 : df10d610 r4 : df3d9000
[ 0.811477] r3 : 00000000 r2 : 00000800 r1 : c023f73d r0 : e09fe000
[ 0.818299] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment kernel
[ 0.826116] Control: 50c5387d Table: 80004019 DAC: 00000015
[ 0.832119] Process swapper/0 (pid: 1, stack limit = 0xdf050240)
[ 0.838394] Stack: (0xdf051e18 to 0xdf052000)
[ 0.842949] 1e00: 00000000 df2a88c0
[ 0.851500] 1e20: c0659c40 df2a88c0 df3d9298 c036f873 df04cac0 00000000 df051e4c 00000020
[ 0.860052] 1e40: 00000008 c00ce4c1 df051e90 df5fc248 df051e78 df04cac0 df5fc2c8 df5fc248
[ 0.868603] 1e60: df5fc248 c00ce403 00000000 df5fc248 df10c148 df3d00c0 00000000 c00cebdf
[ 0.877155] 1e80: df0464b8 c0040449 00000000 00000003 df10c148 00000000 c0672990 df10d610
[ 0.885706] 1ea0: df10d644 c0672990 c01f234d 000000e8 c05edf81 00000000 00000000 c01f2cb9
[ 0.894259] 1ec0: c01f2cad c01f226f 00000000 df10d610 df10d644 c0672990 c01f234d c01f2381
[ 0.902810] 1ee0: 00000000 df051ef0 c0672990 c01f139d df046478 df109880 c0672990 c0672990
[ 0.911361] 1f00: df3d00c0 c06691f8 00000000 c01f1d33 c04ff0a7 df001348 c0672990 c05f62f0
[ 0.919912] 1f20: c061458c c0689cc0 000000e8 c01f2661 00000007 c05f62f0 c061458c c0689cc0
[ 0.928463] 1f40: 000000e8 c000868d c05edf81 13000000 c06145b8 00000008 00000007 c05f62f0
[ 0.937013] 1f60: c061458c c0689cc0 000000e8 c05f62f8 c05d61d5 c05d6691 00000007 00000007
[ 0.945563] 1f80: c05d61d5 00000000 00000000 c0369129 00000000 00000000 00000000 00000000
[ 0.954113] 1fa0: 00000000 c036912f 00000000 c000c6fd 00000000 00000000 00000000 00000000
[ 0.962663] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.971212] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 7fdf55ff 7df57ddd
[ 0.979791] [] (cpsw_probe+0x3fc/0x8a2) from [] (platform_drv_probe+0xd/0xe)
[ 0.988986] [] (platform_drv_probe+0xd/0xe) from [] (driver_probe_device+0x67/0x144)
[ 0.998903] [] (driver_probe_device+0x67/0x144) from [] (__driver_attach+0x35/0x48)
[ 1.008729] [] (__driver_attach+0x35/0x48) from [] (bus_for_each_dev+0x29/0x48)
[ 1.018191] [] (bus_for_each_dev+0x29/0x48) from [] (bus_add_driver+0x83/0x158)
[ 1.027652] [] (bus_add_driver+0x83/0x158) from [] (driver_register+0x4d/0xa4)
[ 1.037024] [] (driver_register+0x4d/0xa4) from [] (do_one_initcall+0x61/0xec)
[ 1.046405] [] (do_one_initcall+0x61/0xec) from [] (kernel_init_freeable+0xb9/0x14c)
[ 1.056327] [] (kernel_init_freeable+0xb9/0x14c) from [] (kernel_init+0x7/0x90)
[ 1.065796] [] (kernel_init+0x7/0x90) from [] (ret_from_fork+0x11/0x34)
[ 1.074529] Code: ff6c e200 f8c4 05c0 (6803) f44f
[ 1.079539] —[ end trace 4f887ca3f0928b01 ]—
[ 1.084817] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 1.084817]
[ 1.094373] drm_kms_helper: panic occurred, switching back to text console
Looks like the flasher in the uSD isn’t able even to boot. Is there any way to solve this problem ?
Thank you,
Best regards,
