Hi!
I have a BeagleBone Black with Debian Wheezy and want to cross-compile
the kernel (need some additional modules not in the default kernel).
So far, I succeeded compiling the kernel and running it on the BBB, but
then I get no HDMI output.
For building on my Debian Wheezy x86_64 I did:
sudo echo "deb http://emdebian.org/~thibg/repo/ sid main" >>
/etc/apt/sources.list
sudo apt-get install emdebian-archive-keyring
sudo dpkg --add-architecture armhf
sudo apt-get update
sudp apt-get install gcc-4.7-arm-linux-gnueabihf lzop libncurses5-dev
cd /usr/bin
sudo ln -s arm-linux-gnueabihf-cpp-4.7 arm-linux-gnueabihf-cpp
sudo ln -s arm-linux-gnueabihf-gcc-4.7 arm-linux-gnueabihf-gcc
sudo ln -s arm-linux-gnueabihf-gcc-ar-4.7 arm-linux-gnueabihf-gcc-ar
sudo ln -s arm-linux-gnueabihf-gcc-nm-4.7 arm-linux-gnueabihf-gcc-nm
sudo ln -s arm-linux-gnueabihf-gcc-ranlib-4.7 arm-linux-gnueabihf-gcc-ranlib
sudo ln -s arm-linux-gnueabihf-gcov-4.7 arm-linux-gnueabihf-gcov
git clone git://git.denx.de/u-boot.git
cd u-boot/
git checkout v2014.07 -b tmp
wget -c
https://raw.githubusercontent.com/eewiki/u-boot-patches/master/v2014.07/0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
patch -p1 < 0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- distclean
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- am335x_evm_config
make -j4 ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-
cd ..
git clone git://github.com/beagleboard/kernel
cd kernel
git checkout 3.8
./patch.sh
cd kernel
wget
http://arago-project.org/git/projects/?p=am33x-cm3.git\;a=blob_plain\;f=bin/am335x-pm-firmware.bin\;hb=HEAD
-O firmware/am335x-pm-firmware.bin
cp ../configs/beaglebone .config
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- menuconfig
# change nothing for testing; save .config
PATH="/path/to/u-boot/tools:$PATH" make -j4 ARCH=arm
CROSS_COMPILE=arm-linux-gnueabihf- uImage dtbs modules
mkdir -p ../../deploy/{modules,firmware,dtbs}
PATH="/path/to/u-boot/tools:$PATH" make ARCH=arm
CROSS_COMPILE=arm-linux-gnueabihf- modules_install
INSTALL_MOD_PATH=../../deploy/modules
CROSS_COMPILE=arm-linux-gnueabihf- firmware_install
INSTALL_FW_PATH=../../deploy/firmware
find . -iname "*.dtb" -exec cp -v '{}' ../../deploy/dtbs
cp ./arch/arm/boot/zImage ../../deploy/
cd ../../deploy
# mount mmcblk0p1 "BOOT"
sudo cp --recursive dtbs /media/BOOT
sudo cp zImage /media/BOOT
# mount mmcblkp5 "rootfs"
sudo cp --recursive modules/lib/* /media/rootfs/lib
sudo cp --recursive firmware/* /media/rootfs/lib/firmware
# umount & eject mmcblk0
If I then boot it, I see the new kernel beeing loaded, but when the
display is enabled, it fails. (system continues running, just no HDMI
display output); See the output on the debug serial:
reading zImage
4416440 bytes read in 504 ms (8.4 MiB/s)
reading initrd.img
2606277 bytes read in 299 ms (8.3 MiB/s)
reading /dtbs/am335x-boneblack.dtb
25814 bytes read in 9 ms (2.7 MiB/s)
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 9efbb000, end 9f2374c5 ... OK
Using Device Tree in place at 88000000, end 880094d5
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-00770-g917d12b (XXXX@localhost) (gcc
version 4.7.1 (Debian 4.7.1-7) ) #1 SMP Fri Aug 8 00:10:10 CEST 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=50c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing
instruction cache
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model:
TI AM335x BeagleBone
[ 2.395598] mmc1: BKOPS_EN bit is not set
[ 2.402845] mmc1: new high speed MMC card at address 0001
[ 2.409338] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[ 2.414514] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 2.421408] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 2.430001] mmcblk1: p1 p2
[ 2.435746] mmcblk1boot1: unknown partition table
[ 2.442937] mmcblk1boot0: unknown partition table
[ 2.475101] tilcdc 4830e000.fb: found TDA19988
[ 2.480588] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.487616] [drm] No driver support for vblank timestamp query.
[ 2.548691] ------------[ cut here ]------------
[ 2.548733] WARNING: at drivers/gpu/drm/tilcdc/tilcdc_crtc.c:251
tilcdc_crtc_mode_set+0x3b/0x468()
[ 2.548743] Modules linked in:
[ 2.548791] [<c0010569>] (unwind_backtrace+0x1/0x8c) from
[<c002b713>] (warn_slowpath_common+0x33/0x48)
[ 2.548814] [<c002b713>] (warn_slowpath_common+0x33/0x48) from
[<c002b737>] (warn_slowpath_null+0xf/0x10)
[ 2.548836] [<c002b737>] (warn_slowpath_null+0xf/0x10) from
[<c01f0247>] (tilcdc_crtc_mode_set+0x3b/0x468)
[ 2.548877] [<c01f0247>] (tilcdc_crtc_mode_set+0x3b/0x468) from
[<c01e06f9>] (drm_crtc_helper_set_mode+0x147/0x22e)
[ 2.548904] [<c01e06f9>] (drm_crtc_helper_set_mode+0x147/0x22e) from
[<c01e0ca3>] (drm_crtc_helper_set_config+0x423/0x5e8)
[ 2.548929] [<c01e0ca3>] (drm_crtc_helper_set_config+0x423/0x5e8)
from [<c01dfee9>] (drm_fb_helper_set_par+0x39/0x74)
[ 2.548963] [<c01dfee9>] (drm_fb_helper_set_par+0x39/0x74) from
[<c01b1903>] (fbcon_init+0x233/0x30c)
[ 2.548989] [<c01b1903>] (fbcon_init+0x233/0x30c) from [<c01d06b5>]
(visual_init+0x71/0xb4)
[ 2.549014] [<c01d06b5>] (visual_init+0x71/0xb4) from [<c01d188f>]
(do_bind_con_driver+0x121/0x20e)
[ 2.549037] [<c01d188f>] (do_bind_con_driver+0x121/0x20e) from
[<c01d19cd>] (do_take_over_console+0x23/0x26)
[ 2.549060] [<c01d19cd>] (do_take_over_console+0x23/0x26) from
[<c01b1a13>] (do_fbcon_takeover+0x37/0x78)
[ 2.549091] [<c01b1a13>] (do_fbcon_takeover+0x37/0x78) from
[<c004068d>] (notifier_call_chain+0x21/0x3a)
[ 2.549117] [<c004068d>] (notifier_call_chain+0x21/0x3a) from
[<c0040751>] (__blocking_notifier_call_chain+0x27/0x34)
[ 2.549141] [<c0040751>] (__blocking_notifier_call_chain+0x27/0x34)
from [<c004076d>] (blocking_notifier_call_chain+0xf/0x10)
[ 2.549164] [<c004076d>] (blocking_notifier_call_chain+0xf/0x10) from
[<c01ac9cf>] (register_framebuffer+0x133/0x174)
[ 2.549190] [<c01ac9cf>] (register_framebuffer+0x133/0x174) from
[<c01e002d>] (drm_fb_helper_single_fb_probe+0x109/0x184)
[ 2.549216] [<c01e002d>] (drm_fb_helper_single_fb_probe+0x109/0x184)
from [<c01e01a5>] (drm_fb_helper_initial_config+0xfd/0x134)
[ 2.549245] [<c01e01a5>] (drm_fb_helper_initial_config+0xfd/0x134)
from [<c01f17a1>] (tilcdc_fbdev_cma_init+0x71/0x94)
[ 2.549270] [<c01f17a1>] (tilcdc_fbdev_cma_init+0x71/0x94) from
[<c01f22fd>] (tilcdc_load+0x46b/0x4be)
[ 2.549299] [<c01f22fd>] (tilcdc_load+0x46b/0x4be) from [<c01e7ad5>]
(drm_get_platform_dev+0x9f/0x14a)
[ 2.549334] [<c01e7ad5>] (drm_get_platform_dev+0x9f/0x14a) from
[<c01f68bd>] (platform_drv_probe+0xd/0xe)
[ 2.549361] [<c01f68bd>] (platform_drv_probe+0xd/0xe) from
[<c01f5e6f>] (driver_probe_device+0x67/0x144)
[ 2.549386] [<c01f5e6f>] (driver_probe_device+0x67/0x144) from
[<c01f5f81>] (__driver_attach+0x35/0x48)
[ 2.549408] [<c01f5f81>] (__driver_attach+0x35/0x48) from
[<c01f4f99>] (bus_for_each_dev+0x29/0x48)
[ 2.549432] [<c01f4f99>] (bus_for_each_dev+0x29/0x48) from
[<c01f5931>] (bus_add_driver+0x85/0x15c)
[ 2.549454] [<c01f5931>] (bus_add_driver+0x85/0x15c) from
[<c01f6261>] (driver_register+0x4d/0xa4)
[ 2.549478] [<c01f6261>] (driver_register+0x4d/0xa4) from
[<c000868d>] (do_one_initcall+0x61/0xec)
[ 2.549507] [<c000868d>] (do_one_initcall+0x61/0xec) from
[<c0649691>] (kernel_init_freeable+0xb9/0x14c)
[ 2.549535] [<c0649691>] (kernel_init_freeable+0xb9/0x14c) from
[<c038709f>] (kernel_init+0x7/0x90)
[ 2.549564] [<c038709f>] (kernel_init+0x7/0x90) from [<c000c73d>]
(ret_from_fork+0x11/0x34)
[ 2.549574] ---[ end trace db2e1923d881a249 ]---
[ 2.549595] [drm:drm_crtc_helper_set_config] *ERROR* failed to set
mode on [CRTC:3]
[ 2.549612] fbcon_init: detected unhandled fb_set_par error, error
code -22
[ 2.549905] ------------[ cut here ]------------
... # repeats several times and other modules get loaded/started
[ 11.359302] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
[ 12.334853] EXT4-fs (mmcblk0p5): re-mounted. Opts: errors=remount-ro
[ 18.390179] net eth0: initializing cpsw version 1.12 (0)
[ 18.414139] net eth0: phy found : id is : 0x7c0f1
[ 18.435109] libphy: PHY 4a101000.mdio:01 not found
[ 18.445140] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 19.029224] ------------[ cut here ]------------
[ 19.029257] WARNING: at drivers/gpu/drm/tilcdc/tilcdc_crtc.c:251
[ 19.029264] Modules linked in:
[ 19.029295] [<c0010569>] (unwind_backtrace+0x1/0x8c) from
[ 19.029308] [<c002b713>] (warn_slowpath_common+0x33/0x48) from
[ 19.029321] [<c002b737>] (warn_slowpath_null+0xf/0x10) from
[ 19.029348] [<c01f0247>] (tilcdc_crtc_mode_set+0x3b/0x468) from
[ 19.029363] [<c01e06f9>] (drm_crtc_helper_set_mode+0x147/0x22e) from
[ 19.029377] [<c01e0ca3>] (drm_crtc_helper_set_config+0x423/0x5e8)
from [<c01df379>] (drm_fb_helper_pan_display+0x3f/0x60)
[ 19.029393] [<c01df379>] (drm_fb_helper_pan_display+0x3f/0x60) from
[<c01abaff>] (fb_pan_display+0x8b/0xba)
[ 19.029412] [<c01abaff>] (fb_pan_display+0x8b/0xba) from [<c01b3ef5>]
(bit_update_start+0x11/0x22)
[ 19.029426] [<c01b3ef5>] (bit_update_start+0x11/0x22) from
[<c01b281f>] (fbcon_switch+0x2f3/0x2fa)
[ 19.029441] [<c01b281f>] (fbcon_switch+0x2f3/0x2fa) from [<c01d1465>]
(redraw_screen+0xab/0x156)
[ 19.029455] [<c01d1465>] (redraw_screen+0xab/0x156) from [<c01b22ef>]
(fbcon_do_set_font+0x20b/0x234)
[ 19.029469] [<c01b22ef>] (fbcon_do_set_font+0x20b/0x234) from
[<c01b24e7>] (fbcon_set_font+0x13f/0x184)
[ 19.029482] [<c01b24e7>] (fbcon_set_font+0x13f/0x184) from
[<c01d3d99>] (con_font_op+0xe5/0x2a8)
[ 19.029501] [<c01d3d99>] (con_font_op+0xe5/0x2a8) from [<c01cc5d7>]
(vt_ioctl+0xb33/0xcf8)
[ 19.029526] [<c01cc5d7>] (vt_ioctl+0xb33/0xcf8) from [<c01c6991>]
(tty_ioctl+0x763/0x7a6)
[ 19.029541] [<c01c6991>] (tty_ioctl+0x763/0x7a6) from [<c009de9d>]
(vfs_ioctl+0x15/0x20)
[ 19.029555] [<c009de9d>] (vfs_ioctl+0x15/0x20) from [<c009e63b>]
(do_vfs_ioctl+0x3ad/0x3e2)
[ 19.029565] [<c009e63b>] (do_vfs_ioctl+0x3ad/0x3e2) from [<c009e6a1>]
(sys_ioctl+0x31/0x4c)
[ 19.029582] [<c009e6a1>] (sys_ioctl+0x31/0x4c) from [<c000c681>]
(ret_fast_syscall+0x1/0x46)
[ 19.029588] ---[ end trace db2e1923d881a24c ]---
[ 19.029603] [drm:drm_crtc_helper_set_config] *ERROR* failed to set
mode on [CRTC:3]
[ 21.490263] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
Debian GNU/Linux 7 debian ttyO0
debian login: XX
Password:
Last login: Thu Aug 7 23:18:41 CEST 2014 on ttyO0
Linux debian 3.8.13-00770-g917d12b #1 SMP Fri Aug 8 00:10:10 CEST 2014
armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
XX@debian:~$
Is this just a problem on my setup, or are the repos broken?
How could I fix that?
It's the first time for me to compile a kernel, so I'm unsure how to
proceed from here...
cheers,
~flapflap
