So, this might be a really long shot… But:
are there any users here using the BBB to stream via the Roon Bridge by roonlabs?
I get the following error when starting this bridge:
00:00:00.039 Warn: get lock file path: /tmp/.rnbgem0-
00:00:01.437 Trace: [childprocess] using unix child process
Initializing
00:00:01.997 Info: ConnectOrStartAndWaitForExit RAATServer, path: /saDbase/local/bin/RoonBridge/Bridge/RAATServer
00:00:02.373 Info: Starting /saDbase/local/bin/RoonBridge/Bridge/RoonBridgeHelper
Not Running (.o)
00:00:00.198 Warn: get lock file path: /tmp/.rnbhgem0-
Running
00:00:16.625 Warn: exception starting raatserver: System.Net.Sockets.SocketException (0x80004005): Connection refused
at System.Net.Sockets.TcpClient…ctor (System.String hostname, System.Int32 port) [0x0006d] in <4e9ef3a58c61422a955a39996454b958>:0
at Sooloos.RAATServer.ConnectOrStartAndWaitForExit (System.String path, System.String args, System.Action`1[T] status, Base.ChildProcess& p) [0x00165] in <b708d17b5bf34394b8a413f43b329e70>:0 Not Running (.o) 00:00:19.029 Info: ConnectOrStartAndWaitForExit RAATServer, path: /saDbase/local/bin/RoonBridge/Bridge/RAATServer Running 00:00:25.068 Warn: exception starting raatserver: System.Net.Sockets.SocketException (0x80004005): Connection refused at System.Net.Sockets.TcpClient..ctor (System.String hostname, System.Int32 port) [0x0006d] in <4e9ef3a58c61422a955a39996454b958>:0 at Sooloos.RAATServer.ConnectOrStartAndWaitForExit (System.String path, System.String args, System.Action` 1[T] status, Base.ChildProcess& p) [0x00165] in :0
Not Running (.o)
Although most of you probably do not use this software, is there anyone who can might think of a fix? At first I thought it would be some network TLS error. As they changed to encrypted protocol in the last update which was when it stopped working. I enabled CONFIG_TLS in the kernel, but that did not do the trick. Anyone who might have any pointers?
