Hello everyone,
A BeagleBone black of mine seemingly crashes (syslogs have NULL filled areas) so I tried activating the kernel crash dump functionality so I can debug it/find the root cause. However when I test it and panic the kernel (via sudo sync; echo c | sudo tee /proc/sysrq-trigger
), the crashdump kernel loaded also panics! So no dump is actually created.
I attaching the relevant kernel logs showing the panic but it seems it’s something related to udev:
[ 1.645589] r3 : c80f0030 r2 : 00000001 r1 : 00000030 r0 : c80f0000
[ 1.652143] Flags: Nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[ 1.659394] Control: 10c5387d Table: 92878019 DAC: 00000051
[ 1.665162] Process systemd-udevd (pid: 117, stack limit = 0xc2876210)
[ 1.671715] Stack: (0xc2877b38 to 0xc2878000)
[ 1.676091] 7b20: 00000004 40070193
[ 1.684306] 7b40: c0d9fb04 c281a040 c14425c8 00000010 c80f0000 c281a324 c2877bb4 c2877b68
does someone have some pointers towards what should I be looking at to fix it?
The kernel used is: 4.14.256-bone53 Sorry I’m not using the latest but it brakes some stuff and I’m not ready to make the jump.
Thank you!
kernelPanicLogs.log (21.3 KB)
