Beaglebone black does not stop at autoboot
Hi all,
I have a couple of questions before I start asking any specific questions.
  1. Does BBB is made keeping in mind windows users?
  2. I wanted to boot from my sd card, after compiling u-boot, kernel, and android . Is there any step by step instructions that tells how to do it? I am using ubuntu 14.04.
    3)What is the use of tftp? How can I flash my uImage from pc to BBB? Does BBB identify my pc via ip of my pc? can I get a uenv.txt file where I can know which place I have to put my pc’s ip so that BBB can fetch uImage.
  3. While booting, it doesn’t stop at autoboot if I presses a key. I have 115200 baud rate, no flow control, 8 bits. I used gtkterm, minicom but none took my key presses. What can be the problem?
If you press “enter” as soon as u power on the board it will stop at uboot prompt.
Once it reaches there, you can issue tftp commands to load the binaries.
Bellow commands worked for me, I am loading kernel/dts via tftp & mounting file system via nfs mount.
setenv ipaddr
setenv serverip
tftpboot 0x88000000
tftpboot 0x82000000
setenv bootargs console=ttyO0,115200n8 root=/dev/nfs rw nfsroot=:/path/to/root_file_sys ip=:::::eth0
bootm 0x82000000 - 0x88000000
