Hi Gerald,
we have now a log file. The only things connected to the BBB is the power supply, the serial debug FTDI and an ethernet cable. One issue we found is the following (PHY not found (line 39)):
[Thu Aug 01 16:25:35.316 2013] U-Boot SPL 2013.04-00017-g5c4fa11 (May 03 2013 - 10:48:32)
[Thu Aug 01 16:25:35.443 2013] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
[Thu Aug 01 16:25:35.498 2013] musb-hdrc: MHDRC RTL version 2.0
[Thu Aug 01 16:25:35.498 2013] musb-hdrc: setup fifo_mode 4
[Thu Aug 01 16:25:35.498 2013] musb-hdrc: 28/31 max ep, 16384/16384 memory
[Thu Aug 01 16:25:35.498 2013] USB Peripheral mode controller at 47401000 using PIO, IRQ 0
[Thu Aug 01 16:25:35.498 2013] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
[Thu Aug 01 16:25:35.499 2013] musb-hdrc: 28/31 max ep, 16384/16384 memory
[Thu Aug 01 16:25:35.499 2013] USB Host mode controller at 47401800 using PIO, IRQ 0
[Thu Aug 01 16:25:35.499 2013] OMAP SD/MMC: 0
[Thu Aug 01 16:25:36.489 2013] mmc_send_cmd : timeout: No status update
[Thu Aug 01 16:25:36.553 2013] reading u-boot.img
[Thu Aug 01 16:25:36.612 2013]
[Thu Aug 01 16:25:36.612 2013] U-Boot 2013.04-00017-g5c4fa11 (May 03 2013 - 10:48:32)
[Thu Aug 01 16:25:36.612 2013] I2C: ready
[Thu Aug 01 16:25:36.660 2013] DRAM: 512 MiB
[Thu Aug 01 16:25:37.268 2013] WARNING: Caches not enabled
[Thu Aug 01 16:25:37.780 2013] NAND: No NAND device found!!!
[Thu Aug 01 16:25:38.034 2013] 0 MiB
[Thu Aug 01 16:25:38.034 2013] MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
[Thu Aug 01 16:25:38.034 2013] *** Warning - readenv() failed, using default environment
[Thu Aug 01 16:25:38.819 2013] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
[Thu Aug 01 16:25:38.819 2013] musb-hdrc: MHDRC RTL version 2.0
[Thu Aug 01 16:25:38.819 2013] musb-hdrc: setup fifo_mode 4
[Thu Aug 01 16:25:38.819 2013] musb-hdrc: 28/31 max ep, 16384/16384 memory
[Thu Aug 01 16:25:38.820 2013] USB Peripheral mode controller at 47401000 using PIO, IRQ 0
[Thu Aug 01 16:25:38.820 2013] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
[Thu Aug 01 16:25:38.820 2013] musb-hdrc: MHDRC RTL version 2.0
[Thu Aug 01 16:25:38.820 2013] musb-hdrc: setup fifo_mode 4
[Thu Aug 01 16:25:38.820 2013] musb-hdrc: 28/31 max ep, 16384/16384 memory
[Thu Aug 01 16:25:38.820 2013] USB Host mode controller at 47401800 using PIO, IRQ 0
[Thu Aug 01 16:25:38.820 2013] Net: not set. Validating first E-fuse MAC
[Thu Aug 01 16:25:38.835 2013] Phy not found
[Thu Aug 01 16:25:39.453 2013] PHY reset timed out
[Thu Aug 01 16:25:39.453 2013] cpsw, usb_ether
[Thu Aug 01 16:25:39.453 2013] Hit any key to stop autoboot: 1 0
[Thu Aug 01 16:25:40.460 2013] gpio: pin 53 (gpio 53) value is 1
[Thu Aug 01 16:25:40.500 2013] Card did not respond to voltage select!
[Thu Aug 01 16:25:40.501 2013] mmc0(part 0) is current device
[Thu Aug 01 16:25:41.492 2013] mmc_send_cmd : timeout: No status update
[Thu Aug 01 16:25:41.508 2013] Card did not respond to voltage select!
[Thu Aug 01 16:25:42.516 2013] mmc_send_cmd : timeout: No status update
[Thu Aug 01 16:25:42.564 2013] mmc1(part 0) is current device
[Thu Aug 01 16:25:43.572 2013] mmc_send_cmd : timeout: No status update
[Thu Aug 01 16:25:43.620 2013] gpio: pin 54 (gpio 54) value is 1
[Thu Aug 01 16:25:43.620 2013] SD/MMC found on device 1
[Thu Aug 01 16:25:43.665 2013] reading uEnv.txt
[Thu Aug 01 16:25:43.665 2013] 1314 bytes read in 5 ms (255.9 KiB/s)
[Thu Aug 01 16:25:43.665 2013] Importing environment from mmc …
[Thu Aug 01 16:25:43.665 2013] gpio: pin 55 (gpio 55) value is 1
[Thu Aug 01 16:25:43.665 2013] gpio: pin 56 (gpio 56) value is 1
[Thu Aug 01 16:25:43.665 2013] Running uenvcmd …
[Thu Aug 01 16:25:43.665 2013] reading zImage
[Thu Aug 01 16:25:44.033 2013] 3252888 bytes read in 373 ms (8.3 MiB/s)
[Thu Aug 01 16:25:44.049 2013] reading uInitrd
[Thu Aug 01 16:25:44.352 2013] 2709355 bytes read in 312 ms (8.3 MiB/s)
[Thu Aug 01 16:25:44.422 2013] reading /dtbs/am335x-boneblack.dtb
[Thu Aug 01 16:25:44.423 2013] 24125 bytes read in 9 ms (2.6 MiB/s)
[Thu Aug 01 16:25:44.423 2013] ## Loading init Ramdisk from Legacy Image at 81000000 …
[Thu Aug 01 16:25:44.423 2013] Image Name: initramfs
[Thu Aug 01 16:25:44.423 2013] Image Type: ARM Linux RAMDisk Image (uncompressed)
[Thu Aug 01 16:25:44.423 2013] Data Size: 2709291 Bytes = 2.6 MiB
[Thu Aug 01 16:25:44.423 2013] Load Address: 00000000
[Thu Aug 01 16:25:44.423 2013] Entry Point: 00000000
[Thu Aug 01 16:25:44.423 2013] ## Flattened Device Tree blob at 815f0000
[Thu Aug 01 16:25:44.423 2013] Booting using the fdt blob at 0x815f0000
[Thu Aug 01 16:25:44.423 2013] Using Device Tree in place at 815f0000, end 815f8e3c
[Thu Aug 01 16:25:44.470 2013]
[Thu Aug 01 16:25:44.470 2013] Starting kernel …
[Thu Aug 01 16:25:44.486 2013] Uncompressing Linux… done, booting the kernel.
[Thu Aug 01 16:25:48.468 2013] [ 0.000000] Booting Linux on physical CPU 0x0
[Thu Aug 01 16:25:48.468 2013] [ 0.000000] Initializing cgroup subsys cpu
[Thu Aug 01 16:25:48.468 2013] [ 0.000000] Linux version 3.8.13-bone21 (root@imx6q-sabrelite-1gb-0) (gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1) ) #1 SMP Fri Jun 14 03:10:29 UTC 2013
[Thu Aug 01 16:25:48.468 2013] [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[Thu Aug 01 16:25:48.469 2013] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[Thu Aug 01 16:25:48.469 2013] [ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[Thu Aug 01 16:25:48.469 2013] [ 0.000000] Memory policy: ECC disabled, Data cache writeback
[Thu Aug 01 16:25:48.469 2013] [ 0.000000] AM335X ES1.0 (neon )
[Thu Aug 01 16:25:48.469 2013] [ 0.000000] PERCPU: Embedded 9 pages/cpu @c0df4000 s14080 r8192 d14592 u36864
[Thu Aug 01 16:25:48.469 2013] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[Thu Aug 01 16:25:48.469 2013] [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc ip=
[Thu Aug 01 16:25:48.470 2013] [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[Thu Aug 01 16:25:48.470 2013] [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[Thu Aug 01 16:25:48.473 2013] [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[Thu Aug 01 16:25:48.473 2013] [ 0.000000] __ex_table already sorted, skipping sort
[Thu Aug 01 16:25:48.474 2013] [ 0.000000] allocated 1048576 bytes of page_cgroup
[Thu Aug 01 16:25:48.474 2013] [ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[Thu Aug 01 16:25:48.474 2013] [ 0.000000] Memory: 511MB = 511MB total
[Thu Aug 01 16:25:48.474 2013] [ 0.000000] Memory: 504832k/504832k available, 19456k reserved, 0K highmem
[Thu Aug 01 16:25:48.474 2013] [ 0.000000] Virtual kernel memory layout:
[Thu Aug 01 16:25:48.474 2013] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[Thu Aug 01 16:25:48.474 2013] [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[Thu Aug 01 16:25:48.475 2013] [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[Thu Aug 01 16:25:48.475 2013] [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[Thu Aug 01 16:25:48.475 2013] [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[Thu Aug 01 16:25:48.475 2013] [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[Thu Aug 01 16:25:48.475 2013] [ 0.000000] .text : 0xc0008000 - 0xc08a3248 (8813 kB)
[Thu Aug 01 16:25:48.475 2013] [ 0.000000] .init : 0xc08a4000 - 0xc08ec700 ( 290 kB)
[Thu Aug 01 16:25:48.478 2013] [ 0.000000] .data : 0xc08ee000 - 0xc096e970 ( 515 kB)
[Thu Aug 01 16:25:48.478 2013] [ 0.000000] .bss : 0xc096e970 - 0xc09e49fc ( 473 kB)
[Thu Aug 01 16:25:48.478 2013] [ 0.000000] Hierarchical RCU implementation.
[Thu Aug 01 16:25:48.479 2013] [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[Thu Aug 01 16:25:48.479 2013] [ 0.000000] NR_IRQS:16 nr_irqs:16 16
[Thu Aug 01 16:25:48.479 2013] [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[Thu Aug 01 16:25:48.479 2013] [ 0.000000] Total of 128 interrupts on 1 active controller
[Thu Aug 01 16:25:48.479 2013] [ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[Thu Aug 01 16:25:48.479 2013] [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[Thu Aug 01 16:25:48.480 2013] [ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[Thu Aug 01 16:25:48.480 2013] [ 0.000000] Console: colour dummy device 80x30
[Thu Aug 01 16:25:48.480 2013] [ 0.000384] Calibrating delay loop… 363.67 BogoMIPS (lpj=354304)
[Thu Aug 01 16:25:48.480 2013] [ 0.017384] pid_max: default: 32768 minimum: 301
[Thu Aug 01 16:25:48.480 2013] [ 0.017632] Security Framework initialized
[Thu Aug 01 16:25:48.480 2013] [ 0.017733] Mount-cache hash table entries: 512
[Thu Aug 01 16:25:48.480 2013] [ 0.027563] Initializing cgroup subsys cpuacct
[Thu Aug 01 16:25:48.480 2013] [ 0.027602] Initializing cgroup subsys memory
[Thu Aug 01 16:25:48.486 2013] [ 0.027673] Initializing cgroup subsys blkio
[Thu Aug 01 16:25:48.486 2013] [ 0.027828] CPU: Testing write buffer coherency: ok
[Thu Aug 01 16:25:48.486 2013] [ 0.028422] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[Thu Aug 01 16:25:48.486 2013] [ 0.028499] Setting up static identity map for 0x805f2c70 - 0x805f2cc8
[Thu Aug 01 16:25:48.486 2013] [ 0.030192] Brought up 1 CPUs
[Thu Aug 01 16:25:48.486 2013] [ 0.030217] SMP: Total of 1 processors activated (363.67 BogoMIPS).
[Thu Aug 01 16:25:48.487 2013] [ 0.031637] devtmpfs: initialized
[Thu Aug 01 16:25:48.487 2013] [ 0.096758] pinctrl core: initialized pinctrl subsystem
[Thu Aug 01 16:25:48.487 2013] [ 0.097003] rstctl core: initialized rstctl subsystem
[Thu Aug 01 16:25:48.487 2013] [ 0.097594] regulator-dummy: no parameters
[Thu Aug 01 16:25:48.487 2013] [ 0.098154] NET: Registered protocol family 16
[Thu Aug 01 16:25:48.487 2013] [ 0.099065] DMA: preallocated 256 KiB pool for atomic coherent allocations
[Thu Aug 01 16:25:48.487 2013] [ 0.109035] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[Thu Aug 01 16:25:48.488 2013] [ 0.109866] platform 49000000.edma: alias fck already exists
[Thu Aug 01 16:25:48.488 2013] [ 0.109898] platform 49000000.edma: alias fck already exists
[Thu Aug 01 16:25:48.488 2013] [ 0.109924] platform 49000000.edma: alias fck already exists
[Thu Aug 01 16:25:48.831 2013] [ 0.111300] OMAP GPIO hardware version 0.1
[Thu Aug 01 16:25:48.831 2013] [ 0.116212] gpio-rctrl rstctl.3: loaded OK
[Thu Aug 01 16:25:48.832 2013] [ 0.121593] hw-breakpoint: debug architecture 0x4 unsupported.
[Thu Aug 01 16:25:48.832 2013] [ 0.123782] cpsw.0: No hwaddr in dt. Using 90:59:af:54:40:30 from efuse
[Thu Aug 01 16:25:48.832 2013] [ 0.123818] cpsw.1: No hwaddr in dt. Using 90:59:af:54:40:32 from efuse
[Thu Aug 01 16:25:48.832 2013] [ 0.137623] bio: create slab at 0
[Thu Aug 01 16:25:48.832 2013] [ 0.149292] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[Thu Aug 01 16:25:48.832 2013] [ 0.149753] vmmcsd_fixed: 3300 mV
[Thu Aug 01 16:25:48.832 2013] [ 0.152601] SCSI subsystem initialized
[Thu Aug 01 16:25:48.832 2013] [ 0.153021] usbcore: registered new interface driver usbfs
[Thu Aug 01 16:25:48.833 2013] [ 0.153153] usbcore: registered new interface driver hub
[Thu Aug 01 16:25:48.833 2013] [ 0.153479] usbcore: registered new device driver usb
[Thu Aug 01 16:25:48.833 2013] [ 0.155603] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[Thu Aug 01 16:25:48.833 2013] [ 0.157199] input: tps65217_pwr_but as /devices/ocp.2/44e0b000.i2c/i2c-0/0-0024/input/input0
[Thu Aug 01 16:25:48.833 2013] [ 0.159496] DCDC1: at 1500 mV
[Thu Aug 01 16:25:48.833 2013] [ 0.160791] vdd_mpu: 925 <–> 1325 mV at 1100 mV
[Thu Aug 01 16:25:48.833 2013] [ 0.162000] vdd_core: 925 <–> 1150 mV at 1100 mV
[Thu Aug 01 16:25:48.836 2013] [ 0.163140] LDO1: at 1800 mV
[Thu Aug 01 16:25:48.836 2013] [ 0.164256] LDO2: at 3300 mV
[Thu Aug 01 16:25:48.837 2013] [ 0.166237] LDO3: 1800 mV
[Thu Aug 01 16:25:48.837 2013] [ 0.167375] LDO4: at 3300 mV
[Thu Aug 01 16:25:48.837 2013] [ 0.168442] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[Thu Aug 01 16:25:48.837 2013] [ 0.169221] omap_i2c 44e0b000.i2c: unable to select pin group
[Thu Aug 01 16:25:48.837 2013] [ 0.170099] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[Thu Aug 01 16:25:48.837 2013] [ 0.172668] omap_i2c 4819c000.i2c: unable to select pin group
[Thu Aug 01 16:25:48.837 2013] [ 0.172902] media: Linux media interface: v0.10
[Thu Aug 01 16:25:48.837 2013] [ 0.173005] Linux video capture interface: v2.00
[Thu Aug 01 16:25:48.838 2013] [ 0.173870] Advanced Linux Sound Architecture Driver Initialized.
[Thu Aug 01 16:25:48.838 2013] [ 0.174879] NetLabel: Initializing
[Thu Aug 01 16:25:48.838 2013] [ 0.174901] NetLabel: domain hash size = 128
[Thu Aug 01 16:25:48.838 2013] [ 0.174913] NetLabel: protocols = UNLABELED CIPSOv4
[Thu Aug 01 16:25:48.838 2013] [ 0.175027] NetLabel: unlabeled traffic allowed by default
[Thu Aug 01 16:25:48.838 2013] [ 0.175368] Switching to clocksource gp_timer
[Thu Aug 01 16:25:48.838 2013] [ 0.229831] NET: Registered protocol family 2
[Thu Aug 01 16:25:48.838 2013] [ 0.231045] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[Thu Aug 01 16:25:48.839 2013] [ 0.231190] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[Thu Aug 01 16:25:48.842 2013] [ 0.231352] TCP: Hash tables configured (established 4096 bind 4096)
[Thu Aug 01 16:25:48.842 2013] [ 0.231451] TCP: reno registered
[Thu Aug 01 16:25:48.842 2013] [ 0.231480] UDP hash table entries: 256 (order: 1, 12288 bytes)
[Thu Aug 01 16:25:48.842 2013] [ 0.231527] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[Thu Aug 01 16:25:48.842 2013] [ 0.231963] NET: Registered protocol family 1
[Thu Aug 01 16:25:48.842 2013] [ 0.232686] RPC: Registered named UNIX socket transport module.
[Thu Aug 01 16:25:48.843 2013] [ 0.232710] RPC: Registered udp transport module.
[Thu Aug 01 16:25:48.843 2013] [ 0.232723] RPC: Registered tcp transport module.
[Thu Aug 01 16:25:48.843 2013] [ 0.232736] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Thu Aug 01 16:25:48.843 2013] [ 0.233155] Trying to unpack rootfs image as initramfs…
[Thu Aug 01 16:25:48.843 2013] [ 0.543983] Freeing initrd memory: 2644K
[Thu Aug 01 16:25:48.843 2013] [ 0.544874] CPU PMU: probing PMU on CPU 0
[Thu Aug 01 16:25:48.843 2013] [ 0.544910] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[Thu Aug 01 16:25:48.844 2013] [ 0.545470] omap2_mbox_probe: platform not supported
[Thu Aug 01 16:25:48.844 2013] [ 0.814354] VFS: Disk quotas dquot_6.5.2
[Thu Aug 01 16:25:48.844 2013] [ 0.814621] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[Thu Aug 01 16:25:48.848 2013] [ 0.815901] NFS: Registering the id_resolver key type
[Thu Aug 01 16:25:48.849 2013] [ 0.816027] Key type id_resolver registered
[Thu Aug 01 16:25:48.849 2013] [ 0.816043] Key type id_legacy registered
[Thu Aug 01 16:25:48.849 2013] [ 0.816230] fuse init (API version 7.20)
[Thu Aug 01 16:25:48.849 2013] [ 0.817142] Btrfs loaded
[Thu Aug 01 16:25:48.849 2013] [ 0.817314] msgmni has been set to 991
[Thu Aug 01 16:25:48.849 2013] [ 0.820477] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[Thu Aug 01 16:25:48.849 2013] [ 0.820508] io scheduler noop registered
[Thu Aug 01 16:25:48.849 2013] [ 0.820523] io scheduler deadline registered
[Thu Aug 01 16:25:48.850 2013] [ 0.820576] io scheduler cfq registered (default)
[Thu Aug 01 16:25:48.850 2013] [ 0.822462] tps65217-bl tps65217-bl: no platform data provided
[Thu Aug 01 16:25:48.850 2013] [ 0.822508] tps65217-bl: probe of tps65217-bl failed with error -22
[Thu Aug 01 16:25:48.850 2013] [ 0.823354] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[Thu Aug 01 16:25:48.850 2013] [ 0.826099] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[Thu Aug 01 16:25:48.850 2013] [ 0.826430] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[Thu Aug 01 16:25:48.851 2013] [ 1.548019] console [ttyO0] enabled
[Thu Aug 01 16:25:48.852 2013] [ 1.552821] [drm] Initialized drm 1.1.0 20060810
[Thu Aug 01 16:25:48.852 2013] [ 1.571339] brd: module loaded
[Thu Aug 01 16:25:48.937 2013] [ 1.581557] loop: module loaded
[Thu Aug 01 16:25:48.938 2013] [ 1.585042] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Thu Aug 01 16:25:48.938 2013] [ 1.592352] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Thu Aug 01 16:25:48.938 2013] [ 1.599638] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Thu Aug 01 16:25:48.938 2013] [ 1.606925] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Thu Aug 01 16:25:48.938 2013] [ 1.614222] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[Thu Aug 01 16:25:48.938 2013] [ 1.628270] bone-capemgr bone_capemgr.9: Baseboard: ‘A335BNLT,0A5C,2513BBBK3061’
[Thu Aug 01 16:25:48.939 2013] [ 1.636076] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-black
[Thu Aug 01 16:25:48.953 2013] [ 1.671593] bone-capemgr bone_capemgr.9: slot #0: No cape found
[Thu Aug 01 16:25:49.008 2013] [ 1.708701] bone-capemgr bone_capemgr.9: slot #1: No cape found
[Thu Aug 01 16:25:49.045 2013] [ 1.745808] bone-capemgr bone_capemgr.9: slot #2: No cape found
[Thu Aug 01 16:25:49.439 2013] [ 1.782919] bone-capemgr bone_capemgr.9: slot #3: No cape found
[Thu Aug 01 16:25:49.439 2013] [ 1.789186] bone-capemgr bone_capemgr.9: slot #4: specific override
[Thu Aug 01 16:25:49.439 2013] [ 1.795798] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[Thu Aug 01 16:25:49.440 2013] [ 1.803846] bone-capemgr bone_capemgr.9: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[Thu Aug 01 16:25:49.440 2013] [ 1.814006] bone-capemgr bone_capemgr.9: slot #5: specific override
[Thu Aug 01 16:25:49.440 2013] [ 1.820614] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[Thu Aug 01 16:25:49.440 2013] [ 1.828659] bone-capemgr bone_capemgr.9: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[Thu Aug 01 16:25:49.441 2013] [ 1.838711] bone-capemgr bone_capemgr.9: slot #6: specific override
[Thu Aug 01 16:25:49.441 2013] [ 1.845319] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[Thu Aug 01 16:25:49.441 2013] [ 1.853368] bone-capemgr bone_capemgr.9: slot #6: ‘Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN’
[Thu Aug 01 16:25:49.441 2013] [ 1.864032] bone-capemgr bone_capemgr.9: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[Thu Aug 01 16:25:49.441 2013] [ 1.872924] bone-capemgr bone_capemgr.9: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[Thu Aug 01 16:25:49.444 2013] [ 1.881823] bone-capemgr bone_capemgr.9: loader: before slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[Thu Aug 01 16:25:49.444 2013] [ 1.890605] bone-capemgr bone_capemgr.9: loader: check slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[Thu Aug 01 16:25:49.444 2013] [ 1.899320] bone-capemgr bone_capemgr.9: initialized OK.
[Thu Aug 01 16:25:49.444 2013] [ 1.904931] bone-capemgr bone_capemgr.9: loader: before slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[Thu Aug 01 16:25:49.445 2013] [ 1.913792] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[Thu Aug 01 16:25:49.445 2013] [ 1.924559] OneNAND driver initializing
[Thu Aug 01 16:25:49.445 2013] [ 1.930004] usbcore: registered new interface driver cdc_ether
[Thu Aug 01 16:25:49.445 2013] [ 1.936197] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[Thu Aug 01 16:25:49.445 2013] [ 1.945014] bone-capemgr bone_capemgr.9: loader: after slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[Thu Aug 01 16:25:49.446 2013] [ 1.953777] usbcore: registered new interface driver rndis_host
[Thu Aug 01 16:25:49.446 2013] [ 1.960090] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[Thu Aug 01 16:25:49.446 2013] [ 1.968983] usbcore: registered new interface driver cdc_ncm
[Thu Aug 01 16:25:49.449 2013] [ 1.974975] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware ‘cape-bone-2g-emmc1.dtbo’ for board-name ‘Bone-LT-eMMC-2G’, version ‘00A0’
[Thu Aug 01 16:25:49.449 2013] [ 1.989309] Initializing USB Mass Storage driver…
[Thu Aug 01 16:25:49.449 2013] [ 1.994603] usbcore: registered new interface driver usb-storage
[Thu Aug 01 16:25:49.449 2013] [ 2.000923] USB Mass Storage support registered.
[Thu Aug 01 16:25:49.450 2013] [ 2.006097] bone-capemgr bone_capemgr.9: slot #4: dtbo ‘cape-bone-2g-emmc1.dtbo’ loaded; converting to live tree
[Thu Aug 01 16:25:49.450 2013] [ 2.016875] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware ‘cape-boneblack-hdmi-00A0.dtbo’ for board-name ‘Bone-Black-HDMI’, version ‘00A0’
[Thu Aug 01 16:25:49.450 2013] [ 2.031219] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[Thu Aug 01 16:25:49.450 2013] [ 2.037870] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[Thu Aug 01 16:25:49.450 2013] [ 2.044339] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[Thu Aug 01 16:25:49.451 2013] [ 2.049601] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[Thu Aug 01 16:25:49.451 2013] [ 2.058673] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[Thu Aug 01 16:25:49.451 2013] [ 2.065557] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[Thu Aug 01 16:25:49.456 2013] [ 2.074277] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[Thu Aug 01 16:25:49.456 2013] [ 2.083077] bone-capemgr bone_capemgr.9: slot #5: dtbo ‘cape-boneblack-hdmi-00A0.dtbo’ loaded; converting to live tree
[Thu Aug 01 16:25:49.456 2013] [ 2.094596] musb-hdrc musb-hdrc.0.auto: *** mode=3
[Thu Aug 01 16:25:49.457 2013] [ 2.099668] musb-hdrc musb-hdrc.0.auto: *** power=250
[Thu Aug 01 16:25:49.457 2013] [ 2.106057] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[Thu Aug 01 16:25:49.457 2013] [ 2.114604] platform 4830e000.fb: alias fck already exists
[Thu Aug 01 16:25:49.457 2013] [ 2.121381] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[Thu Aug 01 16:25:49.457 2013] [ 2.126692] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[Thu Aug 01 16:25:49.457 2013] [ 2.135724] musb-hdrc musb-hdrc.1.auto: *** mode=1
[Thu Aug 01 16:25:49.458 2013] [ 2.140803] musb-hdrc musb-hdrc.1.auto: *** power=250
[Thu Aug 01 16:25:49.458 2013] [ 2.146124] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[Thu Aug 01 16:25:49.458 2013] [ 2.153807] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[Thu Aug 01 16:25:49.677 2013] [ 2.160731] bone-capemgr bone_capemgr.9: loader: done slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[Thu Aug 01 16:25:49.677 2013] [ 2.169367] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[Thu Aug 01 16:25:49.677 2013] [ 2.178562] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[Thu Aug 01 16:25:49.677 2013] [ 2.186852] bone-capemgr bone_capemgr.9: loader: after slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[Thu Aug 01 16:25:49.678 2013] [ 2.195878] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[Thu Aug 01 16:25:49.678 2013] [ 2.203029] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Thu Aug 01 16:25:49.678 2013] [ 2.210633] usb usb1: Product: MUSB HDRC host driver
[Thu Aug 01 16:25:49.678 2013] [ 2.215859] usb usb1: Manufacturer: Linux 3.8.13-bone21 musb-hcd
[Thu Aug 01 16:25:49.678 2013] [ 2.222173] usb usb1: SerialNumber: musb-hdrc.1.auto
[Thu Aug 01 16:25:49.678 2013] [ 2.227459] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware ‘cape-boneblack-hdmin-00A0.dtbo’ for board-name ‘Bone-Black-HDMIN’, version ‘00A0’
[Thu Aug 01 16:25:49.679 2013] [ 2.241939] bone-capemgr bone_capemgr.9: slot #6: dtbo ‘cape-boneblack-hdmin-00A0.dtbo’ loaded; converting to live tree
[Thu Aug 01 16:25:49.679 2013] [ 2.254814] hub 1-0:1.0: USB hub found
[Thu Aug 01 16:25:49.682 2013] [ 2.258946] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[Thu Aug 01 16:25:49.682 2013] [ 2.268565] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[Thu Aug 01 16:25:49.683 2013] [ 2.275343] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[Thu Aug 01 16:25:49.683 2013] [ 2.284981] hub 1-0:1.0: 1 port detected
[Thu Aug 01 16:25:49.683 2013] [ 2.290862] mousedev: PS/2 mouse device common for all mice
[Thu Aug 01 16:25:49.683 2013] [ 2.299143] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[Thu Aug 01 16:25:49.683 2013] [ 2.307002] i2c /dev entries driver
[Thu Aug 01 16:25:49.683 2013] [ 2.312099] Driver for 1-wire Dallas network protocol.
[Thu Aug 01 16:25:49.684 2013] [ 2.319140] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[Thu Aug 01 16:25:49.684 2013] [ 2.326808] cpuidle: using governor ladder
[Thu Aug 01 16:25:49.684 2013] [ 2.331197] cpuidle: using governor menu
[Thu Aug 01 16:25:49.684 2013] [ 2.335844] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[Thu Aug 01 16:25:49.684 2013] [ 2.343097] omap_hsmmc mmc.4: Failed to get rstctl; not using any
[Thu Aug 01 16:25:49.684 2013] [ 2.349539] omap_hsmmc mmc.4: unable to select pin group
[Thu Aug 01 16:25:49.684 2013] [ 2.355447] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[Thu Aug 01 16:25:49.686 2013] [ 2.362681] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[Thu Aug 01 16:25:49.686 2013] [ 2.370049] mmc.4 supply vmmc_aux not found, using dummy regulator
[Thu Aug 01 16:25:49.686 2013] [ 2.376731] omap_hsmmc mmc.4: pins are not configured from the driver
[Thu Aug 01 16:25:49.692 2013] [ 2.410145] gpio-rctrl rstctl.3: gpio_rctrl_request eMMC_RSTn
[Thu Aug 01 16:25:49.749 2013] [ 2.416388] omap_hsmmc mmc.5: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[Thu Aug 01 16:25:49.750 2013] [ 2.424310] gpio-rctrl rstctl.3: gpio_rctrl_deassert eMMC_RSTn
[Thu Aug 01 16:25:49.750 2013] [ 2.430805] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[Thu Aug 01 16:25:49.750 2013] [ 2.437993] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[Thu Aug 01 16:25:49.750 2013] [ 2.445592] mmc.5 supply vmmc_aux not found, using dummy regulator
[Thu Aug 01 16:25:49.750 2013] [ 2.452282] omap_hsmmc mmc.5: pins are not configured from the driver
[Thu Aug 01 16:25:49.964 2013] [ 2.486644] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[Thu Aug 01 16:25:49.964 2013] [ 2.498406] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[Thu Aug 01 16:25:49.965 2013] [ 2.505724] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[Thu Aug 01 16:25:49.965 2013] [ 2.514726] leds-gpio gpio-leds.8: pins are not configured from the driver
[Thu Aug 01 16:25:49.965 2013] [ 2.523158] ledtrig-cpu: registered to indicate activity on CPUs
[Thu Aug 01 16:25:49.965 2013] [ 2.530015] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[Thu Aug 01 16:25:49.965 2013] [ 2.537319] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[Thu Aug 01 16:25:49.966 2013] [ 2.546128] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[Thu Aug 01 16:25:49.966 2013] [ 2.552675] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[Thu Aug 01 16:25:49.966 2013] [ 2.559895] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[Thu Aug 01 16:25:49.966 2013] [ 2.568344] usbcore: registered new interface driver usbhid
[Thu Aug 01 16:25:49.966 2013] [ 2.574231] usbhid: USB HID core driver
[Thu Aug 01 16:25:49.966 2013] [ 2.582746] davinci_evm sound.13: nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[Thu Aug 01 16:25:49.966 2013] [ 2.594429] TCP: cubic registered
[Thu Aug 01 16:25:49.969 2013] [ 2.598076] NET: Registered protocol family 10
[Thu Aug 01 16:25:49.969 2013] [ 2.604085] NET: Registered protocol family 17
[Thu Aug 01 16:25:49.969 2013] [ 2.609368] Key type dns_resolver registered
[Thu Aug 01 16:25:49.969 2013] [ 2.614212] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[Thu Aug 01 16:25:49.969 2013] [ 2.622408] ThumbEE CPU extension supported.
[Thu Aug 01 16:25:49.969 2013] [ 2.626984] Registering SWP/SWPB emulation handler
[Thu Aug 01 16:25:49.969 2013] [ 2.633348] registered taskstats version 1
[Thu Aug 01 16:25:49.970 2013] [ 2.638458] slave hdmi.12: modes-blacklisted #0 → 1920x1080@25
[Thu Aug 01 16:25:49.970 2013] [ 2.644796] mmc1: BKOPS_EN bit is not set
[Thu Aug 01 16:25:49.970 2013] [ 2.649068] slave hdmi.12: modes-blacklisted #1 → 832x624@75
[Thu Aug 01 16:25:49.970 2013] [ 2.657099] tilcdc 4830e000.fb: No power control GPIO
[Thu Aug 01 16:25:49.970 2013] [ 2.663668] mmc1: new high speed MMC card at address 0001
[Thu Aug 01 16:25:49.970 2013] [ 2.677645] mmcblk0: mmc1:0001 MMC02G 1.78 GiB
[Thu Aug 01 16:25:50.013 2013] [ 2.688071] mmcblk0boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[Thu Aug 01 16:25:50.013 2013] [ 2.694783] mmcblk0boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[Thu Aug 01 16:25:50.013 2013] [ 2.703515] mmcblk0: p1 p2
[Thu Aug 01 16:25:50.013 2013] [ 2.709493] mmcblk0boot1: unknown partition table
[Thu Aug 01 16:25:50.014 2013] [ 2.716768] mmcblk0boot0: unknown partition table
[Thu Aug 01 16:25:50.077 2013] [ 2.795776] tilcdc 4830e000.fb: found TDA19988
[Thu Aug 01 16:25:50.122 2013] [ 2.801274] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[Thu Aug 01 16:25:50.122 2013] [ 2.808244] [drm] No driver support for vblank timestamp query.
[Thu Aug 01 16:25:50.122 2013] [ 2.814880] tilcdc 4830e000.fb: No connectors reported connected with modes
[Thu Aug 01 16:25:50.123 2013] [ 2.822219] [drm] Cannot find any crtc or sizes - going 1024x768
[Thu Aug 01 16:25:50.169 2013] [ 2.843078] Console: switching to colour frame buffer device 128x48
[Thu Aug 01 16:25:50.169 2013] [ 2.859176] tilcdc 4830e000.fb: fb0: frame buffer device
[Thu Aug 01 16:25:50.169 2013] [ 2.864857] tilcdc 4830e000.fb: registered panic notifier
[Thu Aug 01 16:25:50.169 2013] [ 2.870559] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[Thu Aug 01 16:25:50.233 2013] [ 2.927480] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[Thu Aug 01 16:25:50.233 2013] [ 2.933918] davinci_mdio 4a101000.mdio: detected phy mask fffffffb
[Thu Aug 01 16:25:50.233 2013] [ 2.951696] libphy: 4a101000.mdio: probed
[Thu Aug 01 16:25:50.295 2013] [ 2.956029] davinci_mdio 4a101000.mdio: phy[2]: device 4a101000.mdio:02, driver SMSC LAN8710/LAN8720
[Thu Aug 01 16:25:50.295 2013] [ 2.965931] Detected MACID = 90:59:af:54:40:30
[Thu Aug 01 16:25:50.295 2013] [ 2.970662] cpsw 4a100000.ethernet: NAPI disabled
[Thu Aug 01 16:25:50.296 2013] [ 2.977773] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[Thu Aug 01 16:25:50.296 2013] [ 2.990243] ALSA device list:
[Thu Aug 01 16:25:50.296 2013] [ 2.993403] #0: TI BeagleBone Black
[Thu Aug 01 16:25:50.296 2013] [ 2.998069] Freeing init memory: 288K
[Thu Aug 01 16:25:50.311 2013] Loading, please wait…
[Thu Aug 01 16:25:50.375 2013] [ 3.093296] udevd[101]: starting version 175
[Thu Aug 01 16:25:50.391 2013] Begin: Loading essential drivers … done.
[Thu Aug 01 16:25:50.407 2013] Begin: Running /scripts/init-premount … done.
[Thu Aug 01 16:25:50.423 2013] Begin: Mounting root file system … Begin: Running /scripts/local-top … done.
[Thu Aug 01 16:25:51.078 2013] Begin: Running /scripts/local-premount … Scanning for Btrfs filesystems
[Thu Aug 01 16:25:51.607 2013] done.
[Thu Aug 01 16:25:51.638 2013] [ 4.358863] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[Thu Aug 01 16:25:51.666 2013] [ 4.366630] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[Thu Aug 01 16:25:52.514 2013] [ 5.229516] EXT4-fs (mmcblk0p2): recovery complete
[Thu Aug 01 16:25:52.552 2013] [ 5.238475] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[Thu Aug 01 16:25:52.553 2013] Begin: Running /scripts/local-bottom … done.
[Thu Aug 01 16:25:52.553 2013] done.
[Thu Aug 01 16:25:52.553 2013] Begin: Running /scripts/init-bottom … done.
[Thu Aug 01 16:25:53.238 2013] [ 5.938633] init: ureadahead main process (223) terminated with status 5
[Thu Aug 01 16:25:54.081 2013] [ 6.781888] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[Thu Aug 01 16:25:56.939 2013] [ 9.626461] libphy: PHY 4a101000.mdio:00 not found
[Thu Aug 01 16:25:56.939 2013] [ 9.631558] net eth0: phy 4a101000.mdio:00 not found on slave 0
[Thu Aug 01 16:25:56.939 2013] [ 9.637786] libphy: PHY 4a101000.mdio:01 not found
[Thu Aug 01 16:25:56.939 2013] [ 9.642822] net eth0: phy 4a101000.mdio:01 not found on slave 1
[Thu Aug 01 16:26:01.433 2013] * Loading cpufreq kernel modules… [ OK ]
[Thu Aug 01 16:26:02.601 2013] * Starting virtual private network daemon(s)… * Autostart disabled, no VPN will be started.
[Thu Aug 01 16:26:02.708 2013] * CPUFreq Utilities: Setting ondemand CPUFreq governor… * CPU0… [ OK ]
[Thu Aug 01 16:26:02.788 2013] Starting very small Busybox based DHCP server: Starting /usr/sbin/udhcpd…
[Thu Aug 01 16:26:02.836 2013] udhcpd.
[Thu Aug 01 16:26:02.916 2013] * Starting NTP server ntpd [ OK ]
[Thu Aug 01 16:26:03.108 2013] No apache MPM package installed
[Thu Aug 01 16:26:04.324 2013]
[Thu Aug 01 16:26:04.324 2013] Ubuntu 13.04 arm ttyO0
Can we solve this problem somehow?
We will do further tests…
