We are facing a strange issue in Beaglebone black. Ethernet LEDs (Green and Yellow ones in Ethernet port) are always on when connected to power even without connecting the ethernet cable. Board cannot get connected to network when ethernet is connected. Rebooting or Power reset didn’t fix it.
What BeagleBoard image are you running on the BB?
The output of the following is usually helpful
Printing the output of the command sudo /opt/scripts/tools/version.sh
git:/opt/scripts/:[1aa73453b2c980b75e31e83dab7dd8b6696f10c7]
eeprom:[A335BNLT00C04219BBBK0297]
dogtag:[BeagleBoard.org Debian Image 2018-10-07]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2018.09-00002-g0b54a51eee]:[location: dd MBR]
kernel:[4.14.71-ti-r80]
nodejs:[v10.21.0]
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.4.20180928.0-0rcnee0~stretch+20180928]
pkg:[bb-wl18xx-firmware]:[1.20180517-0rcnee0~stretch+20180517]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
pkg:[librobotcontrol]:[1.0.3-git20181005.0-0rcnee0~stretch+20181005]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee1~stretch+20180328]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c bluetooth netdev cloud9ide gpio pwm eqep admin spi tisdk weston-launch xenomai]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet]
dmesg | grep pinctrl-single
[ 1.123760] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
dmesg | grep gpio-of-helper
[ 1.135771] gpio-of-helper ocp:cape-universal: ready
END
it is an old image, according to my recent experiences building the latest device, if you want to have the most stable and tested system, you should run with the image recommended in the BeagleBoard website, which now is the 2020-04-06. This will save you a lot of time ! HTH
Hi @nmingotti,
The same image is being used across multiple boards. We see this problem only in two devices with us. These devices also developed this issue in recent past. So I am looking forward to understand what might cause this. This is haunting as other boards with same image may also get to this state after few days, not sure.
Thanks and Regards,
Raajeshwar Elangovan.
