Beaglebone black has not LAN
Hello!
I copy from an older beageblack the emmc to another newer. It has flashed and booting.
But the LAN is not working.
When the BBB start, the LEDs on the ethernet jack are on and blinking. then the go off.
I´m able to connect via USB. Maybe the ethernet driver is different, on newer BBB?
Attached the serial log:
BeagleBone Black:<\r><\n>
BeagleBone Cape EEPROM: no EEPROM at address: 0x54<\r><\n>
BeagleBone Cape EEPROM: no EEPROM at address: 0x55<\r><\n>
BeagleBone Cape EEPROM: no EEPROM at address: 0x56<\r><\n>
BeagleBone Cape EEPROM: no EEPROM at address: 0x57<\r><\n>
Net:   eth2: ethernet@4a100000, eth3: usb_ether<\r><\n>
Press SPACE to abort autoboot in 0 seconds<\r><\n>
board_name=[A335BNLT] ...<\r><\n>
board_rev=[00C0] ...<\r><\n>
gpio: pin 56 (gpio 56) value is 0<\r><\n>
gpio: pin 55 (gpio 55) value is 0<\r><\n>
gpio: pin 54 (gpio 54) value is 0<\r><\n>
gpio: pin 53 (gpio 53) value is 1<\r><\n>
switch to partitions #0, OK<\r><\n>
mmc1(part 0) is current device<\r><\n>
Scanning mmc 1:1...<\r><\n>
libfdt fdt_check_header(): FDT_ERR_BADMAGIC<\r><\n>
<27>7<27>[r<27>[999;999H<27>[6n<27>8Scanning disk mmc@48060000.blk...<\r><\n>
Disk mmc@48060000.blk not ready<\r><\n>
Scanning disk mmc@481d8000.blk...<\r><\n>
Found 2 disks<\r><\n>
No EFI system partition<\r><\n>
BootOrder not defined<\r><\n>
EFI boot manager: Cannot load any image<\r><\n>
gpio: pin 54 (gpio 54) value is 1<\r><\n>
Checking for: /uEnv.txt ...<\r><\n>
Checking for: /boot/uEnv.txt ...<\r><\n>
gpio: pin 55 (gpio 55) value is 1<\r><\n>
1834 bytes read in 2 ms (895.5 KiB/s)<\r><\n>
Loaded environment from /boot/uEnv.txt<\r><\n>
Checking if uname_r is set in /boot/uEnv.txt...<\r><\n>
gpio: pin 56 (gpio 56) value is 1<\r><\n>
Running uname_boot ...<\r><\n>
loading /boot/vmlinuz-5.10.168-ti-r77 ...<\r><\n>
11403776 bytes read in 719 ms (15.1 MiB/s)<\r><\n>
debug: [enable_uboot_overlays=1] ...<\r><\n>
debug: [enable_uboot_cape_universal=1] ...<\r><\n>
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...<\r><\n>
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...<\r><\n>
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...<\r><\n>
loading /boot/dtbs/5.10.168-ti-r77/am335x-boneblack-uboot-univ.dtb ...<\r><\n>
210706 bytes read in 17 ms (11.8 MiB/s)<\r><\n>
Found 0 extension board(s).<\r><\n>
uboot_overlays: [fdt_buffer=0x60000] ...<\r><\n>
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-ADC-00A0.dtbo ...<\r><\n>
645 bytes read in 5 ms (126 KiB/s)<\r><\n>
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-UART1-00A0.dtbo ...<\r><\n>
1017 bytes read in 5 ms (198.2 KiB/s)<\r><\n>
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-UART4-00A0.dtbo ...<\r><\n>
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-W1-P9.12-00A0.dtbo ...<\r><\n>
1085 bytes read in 5 ms (211.9 KiB/s)<\r><\n>
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...<\r><\n>
1605 bytes read in 5 ms (313.5 KiB/s)<\r><\n>
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-HDMI-TDA998x-00A0.dtbo ...<\r><\n>
5321 bytes read in 5 ms (1 MiB/s)<\r><\n>
loading /boot/initrd.img-5.10.168-ti-r77 ...<\r><\n>
6822869 bytes read in 436 ms (14.9 MiB/s)<\r><\n>
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] ...<\r><\n>
debug: [bootz 0x82000000 0x88080000:681bd5 88000000] ...<\r><\n>
Kernel image @ 0x82000000 [ 0x000000 - 0xae0200 ]<\r><\n>
## Flattened Device Tree blob at 88000000<\r><\n>
   Booting using the fdt blob at 0x88000000<\r><\n>
   Loading Ramdisk to 8f97e000, end 8ffffbd5 ... OK<\r><\n>
   Loading Device Tree to 8f8e6000, end 8f97dfff ... OK<\r><\n>
<\r><\n>
Starting kernel ...<\r><\n>
<\r><\n>
[    0.168946] l3-aon-clkctrl:0000:0: failed to disable<\r><\n>
[   10.153977] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!<\r><\n>
[   10.199541] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'<\r><\n>
[   10.199573] gpio-of-helper ocp:cape-universal: Failed to create gpio entry<\r><\n>
[   10.852474] omap_voltage_late_init: Voltage driver support not added<\r><\n>
rootfs: recovering journal<\r><\n>
rootfs: clean, 44328/231536 files, 566201/924672 blocks<\r><\n>
[   25.836569] cpsw 4a100000.ethernet: phy "/ocp/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000/ethernet-phy@0" not found on slave 0<\r><\n>
[   36.258172] davinci-mcasp 48038000.mcasp: IRQ common not found<\r><\n>
<\r><\r><\n>
Debian GNU/Linux 11 BeagleBone ttyS0<\r><\n>
<\r><\n>
BeagleBoard.org Debian Bullseye Minimal Image 2023-10-07<\r><\n>
Support: https://bbb.io/debian<\r><\n>
default username:password is [debian:temppwd]<\r><\n>
<\r><\n>
BeagleBone login:
attached also the dmesg:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.168-ti-r77 (voodoo@rpi4b4g-02) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP PREEMPT Wed Feb 28 21:05:58 UTC 2024
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9c800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] On node 0 totalpages: 130560
[    0.000000]   Normal zone: 1148 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 130560 pages, LIFO batch:31
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 21 pages/cpu s54604 r8192 d23220 u86016
[    0.000000] pcpu-alloc: s54604 r8192 d23220 u86016 alloc=21*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] Kernel command line: console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 438208K/522240K available (15360K kernel code, 1424K rwdata, 3912K rodata, 1024K init, 447K bss, 34880K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 47459 entries in 140 pages
[    0.000000] ftrace: allocated 140 pages with 3 groups
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000033] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000449] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.002814] Console: colour dummy device 80x30
[    0.002911] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[    0.002938] pid_max: default: 32768 minimum: 301
[    0.003577] LSM: Security Framework initializing
[    0.003702] Yama: becoming mindful.
[    0.004011] AppArmor: AppArmor initialized
[    0.004029] TOMOYO Linux initialized
[    0.004237] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.004254] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.006167] CPU: Testing write buffer coherency: ok
[    0.006255] CPU0: Spectre v2: using BPIALL workaround
[    0.029177] Setting up static identity map for 0x80100000 - 0x80100060
[    0.036528] rcu: Hierarchical SRCU implementation.
[    0.045814] EFI services will not be available.
[    0.056543] smp: Bringing up secondary CPUs ...
[    0.056560] smp: Brought up 1 node, 1 CPU
[    0.056573] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.056582] CPU: All CPU(s) started in SVC mode.
[    0.057640] devtmpfs: initialized
[    0.104976] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.105525] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.105568] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.109655] pinctrl core: initialized pinctrl subsystem
[    0.110989] DMI not present or invalid.
[    0.111985] NET: Registered protocol family 16
[    0.116789] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.169863] audit: initializing netlink subsys (disabled)
[    0.171516] thermal_sys: Registered thermal governor 'fair_share'
[    0.171532] thermal_sys: Registered thermal governor 'bang_bang'
[    0.171542] thermal_sys: Registered thermal governor 'step_wise'
[    0.171550] thermal_sys: Registered thermal governor 'user_space'
[    0.171557] thermal_sys: Registered thermal governor 'power_allocator'
[    0.172682] audit: type=2000 audit(0.156:1): state=initialized audit_enabled=0 res=1
[    0.172732] cpuidle: using governor ladder
[    0.172792] cpuidle: using governor menu
[    5.979633] hw-breakpoint: debug architecture 0x4 unsupported.
[    6.038858] Kprobes globally optimized
[    6.065000] raid6: skip pq benchmark and using algorithm neonx8
[    6.065024] raid6: using neon recovery algorithm
[    6.072654] iommu: Default domain type: Translated
[    6.077743] SCSI subsystem initialized
[    6.080787] libata version 3.00 loaded.
[    6.081227] usbcore: registered new interface driver usbfs
[    6.081295] usbcore: registered new interface driver hub
[    6.081360] usbcore: registered new device driver usb
[    6.082935] pps_core: LinuxPPS API ver. 1 registered
[    6.082951] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    6.082977] PTP clock support registered
[    6.085850] NetLabel: Initializing
[    6.085869] NetLabel:  domain hash size = 128
[    6.085876] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    6.085982] NetLabel:  unlabeled traffic allowed by default
[    6.087344] clocksource: Switched to clocksource dmtimer
[    7.142552] VFS: Disk quotas dquot_6.6.0
[    7.142730] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    7.143098] FS-Cache: Loaded
[    7.143666] CacheFiles: Loaded
[    7.144941] AppArmor: AppArmor Filesystem Enabled
[    7.160255] NET: Registered protocol family 2
[    7.160587] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    7.162286] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    7.162596] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    7.162666] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    7.162726] TCP: Hash tables configured (established 4096 bind 4096)
[    7.163505] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[    7.163621] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    7.163656] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    7.163963] NET: Registered protocol family 1
[    7.177596] RPC: Registered named UNIX socket transport module.
[    7.177613] RPC: Registered udp transport module.
[    7.177622] RPC: Registered tcp transport module.
[    7.177629] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    7.177649] NET: Registered protocol family 44
[    7.178638] Trying to unpack rootfs image as initramfs...
[    7.555670] Freeing initrd memory: 6664K
[    7.557045] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    7.563883] Initialise system trusted keyrings
[    7.564411] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    7.573944] zbud: loaded
[    7.582715] NFS: Registering the id_resolver key type
[    7.582826] Key type id_resolver registered
[    7.582836] Key type id_legacy registered
[    7.583027] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    7.583041] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    7.583096] jffs2: version 2.2. (NAND) (SUMMARY)  \xc2\xa9 2001-2006 Red Hat, Inc.
[    7.584467] fuse: init (API version 7.32)
[    7.679259] NET: Registered protocol family 38
[    7.679357] xor: measuring software checksum speed
[    7.687230]    arm4regs        :  1272 MB/sec
[    7.697286]    8regs           :   990 MB/sec
[    7.705465]    32regs          :  1222 MB/sec
[    7.711123]    neon            :  1762 MB/sec
[    7.711134] xor: using function: neon (1762 MB/sec)
[    7.711161] Key type asymmetric registered
[    7.711172] Asymmetric key parser 'x509' registered
[    7.711274] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    7.715775] io scheduler mq-deadline registered
[    8.693687] ti-sysc: probe of 44e31000.target-module failed with error -16
[    8.884689] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[    8.961698] ti-sysc: probe of 48040000.target-module failed with error -16
[    9.261180] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    9.435138] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[   10.154033] edma 49000000.dma: TI EDMA DMA engine driver
[   10.197764] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[   10.225662] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[   10.231296] printk: console [ttyS0] disabled
[   10.231603] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[   10.259898] printk: console [ttyS0] enabled
[   10.262392] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 27, base_baud = 3000000) is a 8250
[   10.264814] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 28, base_baud = 3000000) is a 8250
[   10.266934] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 43, base_baud = 3000000) is a 8250
[   10.268839] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 44, base_baud = 3000000) is a 8250
[   10.270802] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 45, base_baud = 3000000) is a 8250
[   10.276243] omap_rng 48310000.rng: Random Number Generator ver. 20
[   10.279853] random: crng init done
[   10.395576] loop: module loaded
[   10.395931] at24 2-0054: supply vcc not found, using dummy regulator
[   10.426977] at24 2-0055: supply vcc not found, using dummy regulator
[   10.458705] at24 2-0056: supply vcc not found, using dummy regulator
[   10.486690] at24 2-0057: supply vcc not found, using dummy regulator
[   10.623448] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[   10.643688] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[   10.643714] cpsw 4a100000.ethernet: ALE Table size 1024
[   10.643910] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[   10.643992] cpsw 4a100000.ethernet: Detected MACID = 18:2c:65:0b:72:70
[   10.648406] usbcore: registered new interface driver smsc95xx
[   10.651817] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[   10.652234] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[   10.661103] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[   10.661459] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[   10.664863] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.664942] ehci-platform: EHCI generic platform driver
[   10.665664] ehci-omap: OMAP-EHCI Host Controller driver
[   10.682329] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[   10.682386] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[   10.682818] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   10.682835] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.682845] usb usb1: Product: MUSB HDRC host driver
[   10.682855] usb usb1: Manufacturer: Linux 5.10.168-ti-r77 musb-hcd
[   10.682864] usb usb1: SerialNumber: musb-hdrc.1
[   10.684099] hub 1-0:1.0: USB hub found
[   10.684191] hub 1-0:1.0: 1 port detected
[   10.696519] omap_rtc 44e3e000.rtc: registered as rtc0
[   10.696601] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[   10.698909] i2c /dev entries driver
[   10.701362] Driver for 1-wire Dallas network protocol.
[   10.706703] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   10.707652] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[   10.707668] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
[   10.710136] cpuidle: enable-method property 'ti,am3352' found operations
[   10.712635] sdhci: Secure Digital Host Controller Interface driver
[   10.712652] sdhci: Copyright(c) Pierre Ossman
[   10.712661] sdhci-pltfm: SDHCI platform and OF driver helper
[   10.723966] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[   10.725384] ledtrig-cpu: registered to indicate activity on CPUs
[   10.727088] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[   10.727638] omap-aes 53500000.aes: will run requests pump with realtime priority
[   10.732321] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[   10.733441] omap-sham 53100000.sham: will run requests pump with realtime priority
[   10.739056] hid: raw HID events driver (C) Jiri Kosina
[   10.740489] usbcore: registered new interface driver usbhid
[   10.740506] usbhid: USB HID core driver
[   10.741097] remoteproc remoteproc0: wkup_m3 is available
[   10.752125] NET: Registered protocol family 10
[   10.757373] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[   10.816120] mmc1: new high speed MMC card at address 0001
[   10.823934] mmcblk1: mmc1:0001 MK2704 3.53 GiB
[   10.824565] mmcblk1boot0: mmc1:0001 MK2704 partition 1 2.00 MiB
[   10.825144] mmcblk1boot1: mmc1:0001 MK2704 partition 2 2.00 MiB
[   10.825656] mmcblk1rpmb: mmc1:0001 MK2704 partition 3 512 KiB, chardev (241:0)
[   10.833010]  mmcblk1: p1
[   10.846838] Segment Routing with IPv6
[   10.846999] mip6: Mobile IPv6
[   10.847021] NET: Registered protocol family 17
[   10.852071] Key type dns_resolver registered
[   10.852090] mpls_gso: MPLS GSO support
[   10.852432] ThumbEE CPU extension supported.
[   10.852460] Registering SWP/SWPB emulation handler
[   10.862498] registered taskstats version 1
[   10.862529] Loading compiled-in X.509 certificates
[   10.862706] zswap: loaded using pool lzo/zbud
[   10.867846] Key type .fscrypt registered
[   10.867865] Key type fscrypt-provisioning registered
[   10.876149] Btrfs loaded, crc32c=crc32c-generic
[   10.910588] Key type encrypted registered
[   10.910625] AppArmor: AppArmor sha1 policy hashing enabled
[   10.910706] ima: No TPM chip found, activating TPM-bypass!
[   10.910764] ima: Allocated hash algorithm: sha256
[   10.910857] ima: No architecture policies found
[   10.911014] evm: Initialising EVM extended attributes:
[   10.911025] evm: security.selinux
[   10.911032] evm: security.apparmor
[   10.911038] evm: security.ima
[   10.911045] evm: security.capability
[   10.911057] evm: HMAC attrs: 0x1
[   10.938969] OMAP GPIO hardware version 0.1
[   10.968264] tps65217-pmic: Failed to locate of_node [id: -1]
[   10.980466] tps65217-bl: Failed to locate of_node [id: -1]
[   10.984027] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[   10.985207] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[   10.985934] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[   10.988029] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[   10.988359] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[   10.997575] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[   10.997848] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[   10.998054] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[   10.998262] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[   10.998793] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[   10.999007] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[   10.999217] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[   10.999555] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[   10.999800] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[   11.000006] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[   11.000295] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[   11.000505] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[   11.000700] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[   11.000937] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[   11.001151] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[   11.001366] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[   11.001572] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[   11.001763] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[   11.001963] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[   11.002163] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[   11.002351] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[   11.002551] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[   11.002754] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[   11.002965] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[   11.003183] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[   11.003488] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[   11.003734] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[   11.003942] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[   11.004139] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[   11.004347] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[   11.004539] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[   11.004759] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[   11.004972] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[   11.005165] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[   11.005366] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[   11.005552] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[   11.005777] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[   11.005977] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[   11.006170] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[   11.006385] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[   11.006583] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[   11.006803] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[   11.007014] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[   11.007205] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[   11.007512] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[   11.007733] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[   11.007950] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[   11.008170] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[   11.008367] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[   11.008573] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[   11.008798] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[   11.008991] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[   11.009195] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[   11.009384] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[   11.009589] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[   11.009799] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[   11.010004] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[   11.010239] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[   11.010749] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[   11.011010] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[   11.011222] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[   11.011532] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[   11.011756] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[   11.011962] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[   11.012173] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[   11.012396] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[   11.012589] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[   11.012795] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[   11.013020] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[   11.013032] gpio-of-helper ocp:cape-universal: ready
[   11.055393] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[   11.096353] SMSC LAN8710/LAN8720: probe of 4a101000.mdio:00 failed with error -5
[   11.096437] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[   11.106546] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[   11.106571] sdhci-omap 48060000.mmc: Got CD GPIO
[   11.106825] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[   11.139900] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[   11.230369] tda998x 0-0070: found TDA19988
[   11.235102] tilcdc 4830e000.lcdc: bound 0-0070 (ops 0xc10ad3b4)
[   11.236838] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[   11.237240] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[   11.239215] of_cfs_init
[   11.239569] of_cfs_init: OK
[   11.244108] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[   11.249546] Freeing unused kernel memory: 1024K
[   11.250320] Run /init as init process
[   11.250334]   with arguments:
[   11.250342]     /init
[   11.250350]   with environment:
[   11.250357]     HOME=/
[   11.250365]     TERM=linux
[   19.047220] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[   19.260663] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   19.597527] systemd[1]: System time before build time, advancing clock.
[   19.684959] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[   19.686840] systemd[1]: Detected architecture arm.
[   19.690182] systemd[1]: Set hostname to <BeagleBone>.
[   21.414672] systemd[1]: Queued start job for default target Graphical Interface.
[   21.414787] systemd[1]: Unnecessary job for /sys/devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e09050.target-module/44e09000.serial/tty/ttyS0 was removed.
[   21.414877] systemd[1]: Unnecessary job for /dev/bone/uart/0 was removed.
[   21.427633] systemd[1]: Created slice system-getty.slice.
[   21.432138] systemd[1]: Created slice system-modprobe.slice.
[   21.436162] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   21.438915] systemd[1]: Created slice User and Session Slice.
[   21.440625] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   21.441389] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   21.443726] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   21.444349] systemd[1]: Reached target Local Encrypted Volumes.
[   21.444896] systemd[1]: Reached target Paths.
[   21.445089] systemd[1]: Reached target Remote File Systems.
[   21.445232] systemd[1]: Reached target Slices.
[   21.445499] systemd[1]: Reached target Swap.
[   21.451135] systemd[1]: Listening on Syslog Socket.
[   21.453283] systemd[1]: Listening on fsck to fsckd communication Socket.
[   21.454249] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   21.456505] systemd[1]: Listening on Journal Audit Socket.
[   21.457851] systemd[1]: Listening on Journal Socket (/dev/log).
[   21.459840] systemd[1]: Listening on Journal Socket.
[   21.461680] systemd[1]: Listening on Network Service Netlink Socket.
[   21.463778] systemd[1]: Listening on udev Control Socket.
[   21.465043] systemd[1]: Listening on udev Kernel Socket.
[   21.466589] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   21.476003] systemd[1]: Mounting POSIX Message Queue File System...
[   21.499825] systemd[1]: Mounting /sys/kernel/debug...
[   21.528027] systemd[1]: Mounting Kernel Trace File System...
[   21.587797] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   21.663795] systemd[1]: Starting Load Kernel Module configfs...
[   21.682540] systemd[1]: Starting Load Kernel Module drm...
[   21.728846] systemd[1]: Starting Load Kernel Module fuse...
[   21.735217] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   21.735862] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   21.777129] systemd[1]: Starting Journal Service...
[   21.809162] systemd[1]: Starting Load Kernel Modules...
[   21.845271] systemd[1]: Starting Remount Root and Kernel File Systems...
[   21.897207] systemd[1]: Starting Coldplug All udev Devices...
[   22.008439] systemd[1]: Mounted POSIX Message Queue File System.
[   22.010042] systemd[1]: Mounted /sys/kernel/debug.
[   22.031774] systemd[1]: Mounted Kernel Trace File System.
[   22.051818] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   22.085699] systemd[1]: modprobe@configfs.service: Succeeded.
[   22.108060] systemd[1]: Finished Load Kernel Module configfs.
[   22.128427] systemd[1]: modprobe@drm.service: Succeeded.
[   22.140825] systemd[1]: Finished Load Kernel Module drm.
[   22.157565] systemd[1]: modprobe@fuse.service: Succeeded.
[   22.177260] systemd[1]: Finished Load Kernel Module fuse.
[   22.199959] systemd[1]: Finished Load Kernel Modules.
[   22.245149] systemd[1]: Mounting FUSE Control File System...
[   22.255638] EXT4-fs (mmcblk1p1): re-mounted. Opts: errors=remount-ro
[   22.316479] systemd[1]: Mounting Kernel Configuration File System...
[   22.421514] systemd[1]: Starting Apply Kernel Variables...
[   22.556223] systemd[1]: Finished Remount Root and Kernel File Systems.
[   22.558515] systemd[1]: Mounted FUSE Control File System.
[   22.572455] systemd[1]: Mounted Kernel Configuration File System.
[   22.588447] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   22.588949] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   22.625105] systemd[1]: Starting Load/Save Random Seed...
[   22.685513] systemd[1]: Starting Create System Users...
[   22.776033] systemd[1]: Finished Apply Kernel Variables.
[   22.973210] systemd[1]: Finished Load/Save Random Seed.
[   22.974876] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[   23.073315] systemd[1]: Finished Create System Users.
[   23.097662] systemd[1]: Starting Create Static Device Nodes in /dev...
[   23.398833] systemd[1]: Finished Create Static Device Nodes in /dev.
[   23.400299] systemd[1]: Reached target Local File Systems (Pre).
[   23.400527] systemd[1]: Reached target Local File Systems.
[   23.401071] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   23.401499] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   23.453231] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   23.896548] systemd[1]: Started Journal Service.
[   24.228795] systemd-journald[498]: Received client request to flush runtime journal.
[   25.824145] cpsw 4a100000.ethernet: initializing cpsw version 1.12 (0)
[   29.434201] using random self ethernet address
[   29.434230] using random host ethernet address
[   29.799921] using random self ethernet address
[   29.799949] using random host ethernet address
[   30.031581] usb0: HOST MAC 60:b6:e1:17:cf:d0
[   30.031608] usb0: MAC 60:b6:e1:17:cf:d1
[   30.040710] usb1: HOST MAC 60:b6:e1:17:cf:d2
[   30.040734] usb1: MAC 60:b6:e1:17:cf:d3
[   33.623487] remoteproc remoteproc0: powering up wkup_m3
[   33.623529] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[   33.623829] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   33.623853] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[   37.680282] CAN device driver interface
[   37.941756] c_can_platform 481cc000.can: c_can_platform device registered (regs=5c4623dd, irq=48)
[   43.843159] PM: bootloader does not support rtc-only!
[   43.893284] gpio-60 (P9_12): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   46.776109] remoteproc remoteproc1: 4a334000.pru is available
[   46.805343] remoteproc remoteproc2: 4a338000.pru is available
It seems a GPIO problem? Are the Beaglebons black not the same over the years?
May someone could help? My skill are not high enough to get the ethernet working.
Thank you!
small update:
When I flash a new image to the new BBB, the ethernet ist working.
But when I made a “apt-get upgrade” I lose the ethernet again!
It seems the problem is from the current kernel:
5.10.168-ti-r73
I set this now to “hold” for apt-get and can now upgrade anytime without losing the ethernet.
