BeagleBone Black Kernel 3.14 & LCD7 Cap
I’m trying to make the LCD 7 working on my machine under the Kernel 3.14 :
Linux beaglebone 3.14.25-ti-r37 #1 SMP PREEMPT Fri Nov 21 23:20:50 UTC 2014 armv7l GNU/Linux
I saw this link :
http://elinux.org/Beagleboard:Capes_3.8_to_3.14
I’ve done :
git clone -b 3.14-ti [https://github.com/RobertCNelson/dtb-rebuilder.git](https://github.com/RobertCNelson/dtb-rebuilder.git)
cd dtb-rebuilder/
nano src/arm/am335x-boneblack.dts
I don’t want the eMMC and other stuff ;
/* #include “am335x-boneblack-emmc.dtsi” /
HDMI: with audio /
#include “am335x-boneblack-nxp-hdmi-audio.dtsi” /
HDMI: without audio /
#include “am335x-boneblack-nxp-hdmi-no-audio.dtsi” */
/* can1: P9_24, P9_26 /
#include “am335x-can1.dtsi” /
#include “am335x-bone-can1.dtsi” */
/* spi0: /
P9.17 spi0_cs0 /
P9.18 spi0_d1 /
P9.21 spi0_d0 /
P9.22 spi0_sclk /
#include “am335x-bone-spi0-spidev.dtsi” */
/* spi1: /
P9.31 spi1_sclk /
P9.29 spi1_d0 /
P9.30 spi1_d1 /
P9.28 spi1_cs0 /
#include “am335x-bone-spi1-spidev.dtsi” */
/* spi1a: /
P9.42 spi1_sclk /
P9.29 spi1_d0 /
P9.30 spi1_d1 /
P9.20 spi1_cs0 /
#include “am335x-bone-spi1a-spidev.dtsi” */
/* uart1: P9.24, P9.26 /
#include “am335x-ttyO1.dtsi” /
#include “am335x-bone-ttyO1.dtsi” /
uart2: P9.21, P9.22 /
#include “am335x-ttyO2.dtsi” /
#include “am335x-bone-ttyO2.dtsi” /
uart4: P9.11, P9.13 /
#include “am335x-ttyO4.dtsi” /
#include “am335x-bone-ttyO4.dtsi” /
uart5: P8.37, P8.38 boneblack: hdmi has to be disabled for ttyO5 /
#include “am335x-ttyO5.dtsi” /
#include “am335x-bone-ttyO5.dtsi” */
( uart, mmc, can, disabled )
and i’ve only this cap enabled :
#include “am335x-bone-lcd7-01-00a3.dtsi” */
then sudo make install
the interesting line for me is :
src/arm/am335x-boneblack.dtb' -> /boot/dtbs/3.14.25-ti-r37/am335x-boneblack.dtb’
and sudo reboot
The problem is that when i look at the dmesg :
I’ve :
[ 3.633516] bone-pinmux-helper P8_27_pinmux.18: Set initial pinmux mode to hdmi
[ 3.634739] bone-pinmux-helper P8_28_pinmux.19: Set initial pinmux mode to hdmi
[ 3.635965] bone-pinmux-helper P8_29_pinmux.20: Set initial pinmux mode to hdmi
[ 3.637247] bone-pinmux-helper P8_30_pinmux.21: Set initial pinmux mode to hdmi
[ 3.638392] bone-pinmux-helper P8_31_pinmux.22: Set initial pinmux mode to hdmi
[ 3.639392] bone-pinmux-helper P8_32_pinmux.23: Set initial pinmux mode to hdmi
[ 3.640462] bone-pinmux-helper P8_33_pinmux.24: Set initial pinmux mode to hdmi
[ 3.641706] bone-pinmux-helper P8_34_pinmux.25: Set initial pinmux mode to hdmi
[ 3.642973] bone-pinmux-helper P8_35_pinmux.26: Set initial pinmux mode to hdmi
[ 3.644274] bone-pinmux-helper P8_36_pinmux.27: Set initial pinmux mode to hdmi
[ 3.645772] bone-pinmux-helper P8_37_pinmux.28: Set initial pinmux mode to hdmi
[ 3.647305] bone-pinmux-helper P8_38_pinmux.29: Set initial pinmux mode to hdmi
[ 3.648872] bone-pinmux-helper P8_39_pinmux.30: Set initial pinmux mode to hdmi
[ 3.650459] bone-pinmux-helper P8_40_pinmux.31: Set initial pinmux mode to hdmi
[ 3.652269] bone-pinmux-helper P8_41_pinmux.32: Set initial pinmux mode to hdmi
[ 3.653979] bone-pinmux-helper P8_42_pinmux.33: Set initial pinmux mode to hdmi
[ 3.655943] bone-pinmux-helper P8_43_pinmux.34: Set initial pinmux mode to hdmi
[ 3.657991] bone-pinmux-helper P8_44_pinmux.35: Set initial pinmux mode to hdmi
[ 3.660028] bone-pinmux-helper P8_45_pinmux.36: Set initial pinmux mode to hdmi
[ 3.662290] bone-pinmux-helper P8_46_pinmux.37: Set initial pinmux mode to hdmi
[ 3.686084] bone-pinmux-helper P9_25_pinmux.50: Set initial pinmux mode to audio
[ 3.694572] bone-pinmux-helper P9_28_pinmux.53: Set initial pinmux mode to audio
[ 3.697737] bone-pinmux-helper P9_29_pinmux.54: Set initial pinmux mode to audio
[ 3.703990] bone-pinmux-helper P9_31_pinmux.56: Set initial pinmux mode to audio
My question is why ?
I went to kernel 3.14 with :
sudo sh update_kernel.sh --ti-kernel
Any idea ?
Let's see your serial boot log (if you don't have the cape adapter,
you'll have to remove the lcd7 to get the actual log)
When the kernel start, I have :
U-Boot 2013.04-dirty (Jul 10 2013 - 14:02:53)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
1697 bytes read in 4 ms (414.1 KiB/s)
Running uenvcmd …
reading zImage
7264176 bytes read in 828 ms (8.4 MiB/s)
reading initrd.img
2402116 bytes read in 278 ms (8.2 MiB/s)
reading /dtbs/am335x-boneblack.dtb
85190 bytes read in 21 ms (3.9 MiB/s)
Using Device Tree in place at 88000000, end 88017cc5
Starting kernel …
[ 3.716557] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 3.891310] remoteproc1: failed to load rproc-pru0-fw
[ 3.902842] remoteproc1: request_firmware failed: -2
[ 3.914350] pru-rproc 4a334000.pru0: rproc_boot failed
[ 3.926371] remoteproc2: failed to load rproc-pru1-fw
[ 3.932846] remoteproc2: request_firmware failed: -2
[ 3.938315] pru-rproc 4a338000.pru1: rproc_boot failed
[ 3.991344] cpu cpu0: cpu0 clock notifier not ready, retry
[ 4.027790] slave hdmi.63: could not get i2c
Loading, please wait…
Scanning for Btrfs filesystems
systemd-fsck[264]: rootfs: clean, 87770/932672 files, 517688/3864576 blocks
[ 16.553700] libphy: PHY 4a101000.mdio:01 not found
[ 16.558846] net eth0: phy 4a101000.mdio:01 not found on slave 1
( ethernet working, but I thought that this problem was resolved with the kernel 3.14 ? But if you say it works better, it’s cool)
Micka,
Do you see that ^... It's loading "/dtbs/am335x-boneblack.dtb" but the
file you modified is stored under:
"/boot/dtbs/3.14.25-ti-r37/am335x-boneblack.dtb'"
HINT: your hitting a brick wall because you refuse to update the
eMMC.. the "--bbb-old-bootloader-in-emmc" should have been a hint,
it's time to upgrade..
Use the small "console" flasher here, it'll take less then 5 minutes,
then you'll stop running into problems with upgrading
kernel/dtb-rebuilder/etc..
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#BBW.2FBBB_.28All_Revs.29
Yes I just saw it ^^ .
I found it where it is in your Makefile :
install_arch: $(ARCH_DTB)
mkdir -p /boot/dtbs/uname -r/
cp -v $(obj)/*.dtb /boot/dtbs/uname -r/
Just need to replace the line cp with cp -v $(obj)/*.dtb /dtbs/
But I will follow your instruction about the MMC .
One more question because this part I don’t understand :
the am335x when it boot it looks at the SDCard the file uEnv.txt .
So why do I need to upgrade the eMMC ? If I read what you are saying, I should update the mmc because it looks first at the mmc and the mmc tell where to look at the sdCard ?
Micka,
Just from the fact it's loading:
reading zImage
reading initrd.img
vs:
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-3.14.25-ti-r37 ...
7148440 bytes read in 422 ms (16.2 MiB/s)
loading /boot/dtbs/3.14.25-ti-r37/am335x-boneblack.dtb ...
85190 bytes read in 146 ms (569.3 KiB/s)
loading /boot/initrd.img-3.14.25-ti-r37 ...
2298206 bytes read in 158 ms (13.9 MiB/s)
debug: [console=ttyO0,115200n8
root=UUID=cffb3725-c125-4a51-ac5e-8d4ed50aa113 ro rootfstype=ext4
rootwait fixrtc quiet] ...
debug: [bootz 0x82000000 0x88080000:23115e 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x6d1398 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8fdce000, end 8ffff15e ... OK
   Loading Device Tree to 8fdb6000, end 8fdcdcc5 ... OK
It's that 100x better! :wink: Specially for developers!
It’s that 100x better! :wink: Specially for developers!
Care to elaborate ?
It's just more verbose... So we can actually see what it's doing..
(console variable...)
It’s just more verbose… So we can actually see what it’s doing…
(console variable…)
Oh heh, I thought you were telling him the eMMC was better for development . . and of course I was curious . . .
