It seems that when running beaglebone-black-make-microSD-flasher-from-eMMC.sh (am33x-v3.8) that it utilized the entire SD card size when creating image. Is there a convenient way to limit the size of partitions to smaller size (say 4GB) as opposed to entire SD card.
This is no biggie but was wondering.
~C
A user did merge in a conf_rootfs_partition_size variable…
LC_ALL=C sfdisk ${sfdisk_options} "${destination}" <<-__EOF__
${sfdisk_boot_startmb},${conf_rootfs_partition_size},${sfdisk_fstype},*
__EOF__
So you could specify conf_rootfs_partition_size in /boot/SOC.sh
Thanks, I assume this is with a much newer image as I don’t see any function.sh
I will check if apt-get update works or not, thanks
This is a git repo under /opt/scripts/
Careful, do not do a full git pull… there are a lot of things in there for newer Distro’s and has not been tested on 3.8.x
