Beaglebone Black: No HDMI output with latest Angstrom Master
Hi.
I have a Beaglebone Black rev A5C.
I get a proper desktop on my HDMI screen, when I boot the original flashed demo.
If I boot from a cloud9-gnome-image on a microSD card
built from the Angstrom distribution master the screen is not detected by the driver.
The Build machine is running Ubuntu-12.10 x86.
The Beaglebone is connected to
  • HDMI monitor
  • USB hub with keyboard and mouse
  • Ethernet (but have tried without)
  • FTDI cable for console port connected to a laptop.
The Beaglebone, HDMI monitor and laptop are all connected to the same power splitter.
Get the following error in the bootlog
[ 10.026375] ------------[ cut here ]------------
[ 10.031335] WARNING: at drivers/gpu/drm/tilcdc/tilcdc_crtc.c:251 tilcdc_crtc_mode_set+0x3b/0x464()
[ 10.040724] Modules linked in: ip_tables x_tables g_multi libcomposite rfcomm mtnet7601Usta(O) mt7601Usta(PO) mtutil7601Usta(O) 4
[ 10.058279] [] (unwind_backtrace+0x1/0x8c) from [] (warn_slowpath_common+0x33/0x48)
[ 10.068124] [] (warn_slowpath_common+0x33/0x48) from [] (warn_slowpath_null+0xf/0x10)
[ 10.078149] [] (warn_slowpath_null+0xf/0x10) from [] (tilcdc_crtc_mode_set+0x3b/0x464)
[ 10.088271] [] (tilcdc_crtc_mode_set+0x3b/0x464) from [] (drm_crtc_helper_set_mode+0x147/0x22e)
[ 10.099213] [] (drm_crtc_helper_set_mode+0x147/0x22e) from [] (drm_crtc_helper_set_config+0x423/0x5e8)
[ 10.110783] [] (drm_crtc_helper_set_config+0x423/0x5e8) from [] (drm_mode_setcrtc+0x24d/0x2c8)
[ 10.121629] [] (drm_mode_setcrtc+0x24d/0x2c8) from [] (drm_ioctl+0x1c9/0x286)
[ 10.130930] [] (drm_ioctl+0x1c9/0x286) from [] (vfs_ioctl+0x15/0x20)
[ 10.139416] [] (vfs_ioctl+0x15/0x20) from [] (do_vfs_ioctl+0x3ad/0x3e2)
[ 10.148168] [] (do_vfs_ioctl+0x3ad/0x3e2) from [] (sys_ioctl+0x31/0x4c)
[ 10.156927] [] (sys_ioctl+0x31/0x4c) from [] (ret_fast_syscall+0x1/0x46)
[ 10.165775] —[ end trace 8c3b4dba61de0ea3 ]—
[ 10.204395] [drm:drm_crtc_helper_set_config] ERROR failed to set mode on [CRTC:3]
Have looked through the kernel configuration, and tried adding the omap_drm from staging to no effect.
The boot above is with the CONFIG enabled.
I don’t think it is loaded anyway because lsmod gives:
Module Size Used by
fuse 51875 3
ip_tables 8294 0
x_tables 15072 1 ip_tables
g_multi 55905 2
libcomposite 15228 1 g_multi
rfcomm 25106 0
mtnet7601Usta 25709 0
mt7601Usta 754145 1 mtnet7601Usta
mtutil7601Usta 65918 2 mt7601Usta,mtnet7601Usta
ircomm_tty 14503 0
ircomm 8846 1 ircomm_tty
irda 89974 2 ircomm_tty,ircomm
ipv6 229989 16
hidp 10112 0
bluetooth 146100 4 hidp,rfcomm
rfkill 16510 3 bluetooth
autofs4 17432 2
modprobe omapfb
does not work so I go to:
cd /lib/modules/3.8.13/kernel/drivers/video/omap2/omapfb ; insmod omapfb.ko
I get
[ 217.103445] omapfb: Unknown symbol omap_dss_get_num_overlays (err 0)
[ 217.114312] omapfb: Unknown symbol omap_dss_get_device (err 0)
[ 217.123422] omapfb: Unknown symbol omapdss_compat_uninit (err 0)
[ 217.132669] omapfb: Unknown symbol omap_dss_ntsc_timings (err 0)
[ 217.142381] omapfb: Unknown symbol omap_dss_get_next_device (err 0)
[ 217.152126] omapfb: Unknown symbol omapdss_get_default_display_name (err 0)
[ 217.162265] omapfb: Unknown symbol omap_dss_put_device (err 0)
[ 217.171576] omapfb: Unknown symbol omap_dss_get_overlay (err 0)
[ 217.180662] omapfb: Unknown symbol omap_dss_pal_timings (err 0)
[ 217.189587] omapfb: Unknown symbol omap_dss_get_num_overlay_managers (err 0)
[ 217.199683] omapfb: Unknown symbol omap_dss_get_overlay_manager (err 0)
[ 217.209802] omapfb: Unknown symbol omapdss_compat_init (err 0)
depmod -a
does not work, since the image does not have modules.order or modules.builtin.
Tried adding
capemgr.disable_partno=BB-BONELT-HDMI
to uEnv.txt
The boot says:
uEnv.txt (1.08 KB)
Xorg.0.log (59.1 KB)
boot.log (51.7 KB)
If I add the following to “uEnv.txt” I do get a screen, but the upper and lower menus are not in
the visible part of the screen.
optargs=quiet
It sounds like the over scan feature of your display is getting in the way.
