I am trying to manage power myself including battery backup, however if I have USB power and AC adapter power whenever I disconnect the AC power, the system shuts down shortly after. I would like to manage the shutdown myself.
Can anyone tell me how to disable the default control
The USB should provide power if the AC (+5v) is removed.
What else is connected to the BBB ?
I have a cape with a lithium battery, a serial port talking to a wireless gateway which is powered from the AC input also and an ethernet cable to the BBB nothing else, the battery is connected to the charging circuit of the PMIC.
I have two BBB which both do the same
I just tried the same thing without the cape and the same thing happens so all that is connected to the BBB is AC, USB and ethernet. uname -a gives “Linux beaglebone 3.8.13 #1 SMP Wed Sep 4 09:09:32 CEST 2013 armv7l GNU/Linux”
Yeah, I doubt its the ethernet jack being plugged in and used. I have a TEMPER USB thermometer plugged in and running, plus ethernet, and USB networking.
There could be a service on these new images that monitors AC power, so that it issues a shutdown when this occurs. I know threre is at least “CTRL + ALT + DEL” key press combo “event” in /etc/inittab, but have not looked to see if there is anything else. There could also a a conditional systemd service potentially doing this.
# What to do when the power fails/returns. pf::powerwait:/etc/init.d/powerfail start pn::powerfailnow:/etc/init.d/powerfail now po::powerokwait:/etc/init.d/powerfail stop
You need to do some google “research” and see if this is a potential issue for you.
There is a previous thread, several weeks ago about this same behavior. That thread involved an application that ran off mains but had battery backup and everytime mains failed, and 5V goes away, the BBB shutdown.
IIRC, this is a known software default behavior when the 5V goes away, it is programmable and needs to be set accordingly to how the end user whats it to behave.
In order to avoid any misunderstanding, I wrote “I had a similar problem”. But I didn’t use the USB connection.
Only 5V DC and battery were connected to the BBB.
As soon as 5V DC PS was off, the Debian LXDE version was shutting down but a warning was appearing telling the user the system was shutting down within 60s if this procedure wasn’t canceled.
Maybe David Hirst’s problem is related to the same software “mecanism”.
The fact that it powers down is a problem to me, if for instance a slight power interruption occurs ( lets say 5 seconds) during which time the CPU is powered by the battery backup I would like to carry on running, if its longer then I would like to make the decision when to shutdown.
As it stands now I have no option but to have the system power down.
With the current implementation In the event of a small interruption, the system will start to power down but if that the power has now returned prior to the shutdown occurring the system needs intervention to power back up, by power cycling either the USB or AC. I want to smooth out short power cycles and let the long power outages re-power the board when the power returns
I guess a rebuild is in order, I did the same test with Debian and saw the same result, except that with Debian a message is posted to the console explaining that shutdown is occurring due to loss of AC power
I like this behaviour and thought I could use it to cleanly shutdown the bbb. I therefore connected a ‘powerbar’ usb battery to the usb otg port. Now when I remove the 5V (strangely called ac) I expect a clean shutdown on power delivered by my cheap ‘ups’. Only I find out that in /this/ case the bbb shutdown immediate instead of a clean shutdown!
So there seams to be a difference in connecting the otg usb to a pc or just to a powerbar.
Anyone who can explain this behaviour? In my quest to shutdown a bbb simple, cheap and clean.
Yes indeed, and that is a perfect way to shut down our baby. It’s another way of pressing the power button. Thing is you need another 10 sec. of shutdown power (to cleanly shutdown).
So I’m looking for the use case where somebody stupid (talking 'bout me) yanks the 5V and I still get a clean shutdown. We need external ‘ups’ power for that last 10 sec. of shutdown. Now I keep 5V always on. Till power company screws up. 64 million dollar question: how many times can power company screw up before bbb screws up?
Question remains why I get a unclean shutdow with me (the stupid one) feeding 5v to otg usb with powerbar and getting clean shutdown when connected to regular pc.
Call me stupid but the correct answer awaits tickets for the next frank zappa concert!
Yes indeed, and that is a perfect way to shut down our baby. It's another
That's possible with a backup supply, NIMH/NICD with a resistor to
charge and a diode to prevent overcharge, if you have a cutoff when
the batteries reach 1.1 volts, you're fine. I'd suggest a 1 farad
capacitor, but the BBB wants several hundred mills when running, and I
suspect that's a bit much.
So I'm looking for the use case where somebody stupid (talking 'bout me)
yanks the 5V and I still get a clean shutdown. We need external 'ups' power
Ok, comparator and you shut down (gracefully) when the DC power goes
away. Problem is to determine that (if you're also battery
powered.... this is good....)
May have to do with how the power is actually disconnected, clean off
vs make/break/make/break by disconnecting
zappa concert!
