In trying to test my code for the PRUs is there a good way to check and see if binary is being loaded into the PRU properly and check whether or not it is executing. I have a simple LED circuit running some basic blink code but nothing seems to be occurring. Also with everything activated, the pru_rproc running and the devices showing up as they should I still sometimes get “no such device” when I try to bind pru0, have you ever run into this issue?
When attempting to bind pru0 I get the following outpur from dmesg:
[ 697.537395] remoteproc1: 4a334000.pru0 is available
[ 697.537435] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 697.537450] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn’t yet guaranteed.
[ 697.537926] remoteproc1: Unsupported class: 254
[ 697.546973] pru-rproc 4a334000.pru0: booting the PRU core manually
[ 697.547013] remoteproc1: powering up 4a334000.pru0
[ 697.547250] pru-rproc 4a334000.pru0: rproc_boot failed
[ 697.557946] remoteproc1: releasing 4a334000.pru0
[ 697.559696] pru-rproc: probe of 4a334000.pru0 failed with error -12
does this mean it’s an error in the code I am trying to load into it?
Below is a copy of the assembly code that I am attempting to load if it helps
Enter code here…; blink.p: demonstration of PRU on the BeagleBone Black
; blink LED connected to P8_11 ten times
.origin 0
.entrypoint TOP
TOP:
MOV r1, 10 ; blink counter
BLINK:
SET r30, r30, 15 ; set GPIO output 15
MOV r0, 0x00a00000 ; delay counter
DELAY:
SUB r0, r0, 1
QBNE DELAY, r0, 0 ; loop until r0 == 0 (delay)
CLR r30, r30, 15 ; clear GPIO output 15
DELAY2:
SUB r0, r0, 1
QBNE DELAY2, r0, 0 ; loop until r0 == 0 (delay)
SUB r1, r1, 1
QBNE BLINK, r1, 0 ; loop until r1 = 0 (blink counter)
MOV r31.b0, 32 + 3
HALT
Zach
(Deleted the old one because I forgot to include the error messages)
