I acquired a BeagleBone Black Wireless 6 months ago.
Since, I have never been able to do anything because of freeze issue.
The heartbeat LED stops and it drops off the network.
I tried different setting up :
- power supply by USB cable
- Power supply by the 5V barrel connector (5V 1A adaptater)
- USB + 5V barrel connector
- Power on with SD card into the board
- Power on with no SD card into the board
Today, as soon as I connect my PC to the BBB wifi in order to access to the Cloud9 web page, the heartbeat LED stop flickering and a complete reboot is required.
I can’t access to the Cloud9 page.
Nothing is plugged on the USB plug.
It could also happen at random moment and this is unpredictable, so the device is unusable.
I’m using the latest software image.
Does someone has a solution about this issue ?
Thank you in advance
Benoît.
