I want to use Wi-Fi Cape and Audio Cape with BeagleBone black.
Will there be any issue with this combination, such as conflict between WiFi cape and audio cape pins, pinmux, etc?
Thanks and Regards,
Pankaj Bharadiya
Thanks and Regards,
Pankaj Bharadiya
Did you check compatibility of the WIFI cape with the BBB? http://circuitco.com/support/index.php?title=BeagleBone_Capes
Look under the compatibility matrix.
You would probably save a bit of money using commodity usb wifi and audio.
I’m currently using the Audio Cape and a usb wifi dongle on the BBB, no issues so far.
Hi Eze_rg,
Can you please share the wifi dongle you are using?
Thanks!
The dongle has a "rtl8192cu" chip. The driver was downloaded from realtek webpage.
Hope it helped
