Just flashed bone-eMMC-flasher-debian-10.3-iot-armhf-2020-04-06-4gb.img to my Beaglebone Blue, and everything looks OK except that when I scan for Wifi networks, I get nothing.
Where I’m at:
- Boot board and connect via USB
- open terminal window
- start connmanctl
- scan wifi
- services
Now, the problem is that I don’t get anything in the services - not a jot. It worked when I first got the board, but since re-flashing the board it doesn’t.
Would appreciate any help.
@DirtFarmer please re-test with:
https://rcn-ee.net/rootfs/bb.org/testing/2021-09-01/buster-iot/
ps, ssh key generation will take a while, so WiFi/connmanctl won’t actually work for atleast the first minute or two after “first” bootup after flashing…
connmanctl> tether wifi disable
Error disabling wifi tethering: Already disabled
connmanctl> scan wifi
Scan completed for wifi
connmanctl> services
duinotech-17f312 wifi_38d269e0044f_6475696e6f746563682d313766333132_managed_none
WiFi-2BAC wifi_38d269e0044f_576946692d32424143_managed_psk
Living Room TV.b wifi_38d269e0044f_4c6976696e6720526f6f6d2054562e62_managed_none
Optus_6AB83E wifi_38d269e0044f_4f707475735f364142383345_managed_psk
Ashfield wifi_38d269e0044f_4173686669656c64_managed_psk
Aussie Broadband 8561 wifi_38d269e0044f_4175737369652042726f616462616e642038353631_managed_psk
Belong1AEDC2 wifi_38d269e0044f_42656c6f6e67314145444332_managed_psk
eufy RoboVac 35C-FAD9 wifi_38d269e0044f_6575667920526f626f566163203335432d46414439_managed_none
Loft speaker.o wifi_38d269e0044f_4c6f667420737065616b65722e6f_managed_none
TelstraBC0B49 wifi_38d269e0044f_54656c73747261424330423439_managed_psk
Fon WiFi wifi_38d269e0044f_466f6e2057694669_managed_none
Telstra Air wifi_38d269e0044f_54656c7374726120416972_managed_none
Telstra0E30 wifi_38d269e0044f_54656c7374726130453330_managed_psk
connmanctl> connect wifi_38wifi_38d269e0044f_576946692d32424143_managed_psk
Error /net/connman/service/wifi_38wifi_38d269e0044f_576946692d32424143_managed_psk: Method "Connect" with signature "" on interface "net.connman.Service" doesn't exist
Oh, and I’ve connected a 12V supply as well in order to eliminate any potential power issues from the USB.
Thanks @RobertCNelson. I flashed that image to the board, still getting similar results. The only difference now is:
After first booting the board, I do get networks when entering services.
Then after trying to connect to my network, nothing - I get an error and the list is empty again.
What am I doing wrong??
i doubt it’s this: (add agent on)
services
agent on
connect wifi_........
What does the version.sh script print out?
git:/opt/scripts/:[721f317b40aabe880c34e8e16311812eeb464ce4]
eeprom:[A335BNLTBLA21711EL000016]
model:[TI_AM335x_BeagleBone_Blue]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2021-09-01]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2019.04-g1da4564 (Aug 31 2021 - 14:32:40 +0000)]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2019.04-g1da4564]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblue.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0.bb.org-overlays]
kernel:[4.19.94-ti-r66]
nodejs:[v10.24.0]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay_pru=AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~buster+20210821]
pkg:[bb-customizations]:[1.20210810.1-0~buster+20210810]
pkg:[bb-usb-gadgets]:[1.20210816.0-0~buster+20210816]
pkg:[bb-wl18xx-firmware]:[1.20210901.0-0~buster+20210901]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.5-git20200715.0-0~buster+20200716]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input bluetooth netdev gpio admin tisdk weston-launch cloud9ide]
cmdline:[console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 16.469808] remoteproc remoteproc0: 4a334000.pru is available
[ 16.483292] remoteproc remoteproc1: 4a338000.pru is available
[ 60.623768] remoteproc remoteproc2: wkup_m3 is available
[ 61.172152] remoteproc remoteproc2: powering up wkup_m3
[ 61.172186] remoteproc remoteproc2: Booting fw image am335x-pm-firmware.elf, size 217148
[ 61.172473] remoteproc remoteproc2: remote processor wkup_m3 is now up
dmesg | grep pru
[ 16.469989] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[ 16.483495] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
dmesg | grep pinctrl-single
[ 0.951428] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
lsusb
END
@RobertCNelson Many thanks for your help, it’s much appreciated.
I’ve spent quite some time trying to get this working, and in the end I tried the image bone-eMMC-flasher-debian-10.10-iot-armhf-2021-07-09-4gb.img from /rootfs/bb.org/testing/2021-07-09/buster-iot. And that worked <great success!>
The only thing I’m wondering about is why the later images don’t do wifi so well.
Again, many thanks.
