Again I’m really sorry, but this problem last too long. Because of it, I can’t play with the beaglebone. Which make me sad
I copied the folder /usr/lib from my beaglebone and I place it in my ubuntu machine to the folder /usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/usr/
I think that I’ve done everything correctly, but no … it doesn’t work … .
What is wrong with my compilation ? configuration ? I just need some tips, advise, a path to follow. Thx you !
And Yes, I will document later to to he community how to do a cross compilation with Gtk, it’s important to share our knowledge.
The result was a success, my simple hello world cross compilation project works.
But when I wanted to add GTk in my project, I couldn’t find the library gtk3 in the library, but I discovered that in the new release of the angstrom for beaglebone, the library was there. So I copied the folder /usr/lib & /usr/include here : /usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/
But if you know a better way to do it, I’m really open, I want to learn.
