Beaglebone display Problem
I connected 4DLCD-43Touch to my new BBB, For about an hour it worked properly after that i tried to connect to monitor using hdmi which was working before also not working now. but i am able to access the board via ssh and its is getting mounted in my laptop too.
Please do help.
I have attached the screenshot below.
http://imageshack.com/a/img856/4058/k9wr.jpg
I would assume that the resolution setting for the LCD are not the same as the HDMI. There is only one port. LCD and HDMI share the same output pins from the processor.If the LCD works, then the HDMI will not work.
