Does the beaglebone (AM335x) support UHS speeds (30 MB/s or more) for SD cards that are UHS compatible?
-PJ
-PJ
According to the AM335x Technical Reference Manual [1] page 3535, no.
AM335x supports SD v2.00 of the spec which does not include UHS modes of
operation.
[1]: http://www.ti.com/litv/pdf/spruh73f
-Andrew
Thanks Andrew for pointing me out that one!
-Prasant
SD cards that are UHS compatible?According to the AM335x Technical Reference Manual [1] page 3535, no.
operation.[1]: http://www.ti.com/litv/pdf/spruh73f
-Andrew
-Prasant
Some UHS cards are compatible, although not at UHS speeds as Andrew indicated.
- Grant
Technically, all SD and SDHC cards should be supported. So, all UHS
SDHC marked cards should be supported, just only operating with the SD
v2.00 spec interface (ie: no 1.8 V signaling or higher than 50 MHz
clock).
SDXC is another discussion.
-Andrew
