Beaglebone driver installation problem
Did you try Windows update? Worked for me.
I had an issue installing drivers on Windows 8. The drivers aren’t signed, and trying to install them just failed with no message. The trick for getting them installed was to boot in a special windows mode that allows unsigned driver installation. (Follow the steps in “Step 1” here. The rest of those instructions pertain to some other project. Once you get booted up after choosing option 7 in the boot menu, go ahead and run the driver installer there.)
As well, based on the original post, I’m going to assume that the drivers only want to install if the language is set to English. You might be able to manually install them, if you unpack the self extracting archive that is the driver installer program, and manually updating the drivers with the files that you extracted.
