Dear All,
I have problem to get full Ubuntu GUI desktop on Beaglebone with DVI cape. The details:
Myself: Newbie
BeagleBone: Rev A4
DVI-D Cape: Rev A
OS System: Ubuntu 11.10 oneiric
I followed this link http://elinux.org/BeagleBoardUbuntu to create the SD Image. I typed:
uname -a
and got this:
Linux omap 3.2.0-psp3 #1 Tue Feb 28 06:08:20 UTC 2012 armv7l armv7l armv7l GNU/Linux
I connect to the monitor with HDMI to DVI cable. Please see the pictures.
I can see the console, and type (with a keyboard connected). -
Then I followed this command, trying to get full GUI desktop:
sudo apt-get update
sudo apt-get install gdm xubuntu-desktop
I reboot, hoping that it will bring me to the GUI login
But it goes to console again. -
Then I tried to type:
startxfce4
I got errors:
ubuntu@omap:~$ sudo startxfce4
[sudo] password for ubuntu:
/usr/bin/startxfce4: Starting X server
X.Org X Server 1.10.4
Release Date: 2011-08-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.35-24-omap armv7l Ubuntu
Current Operating System: Linux omap 3.2.0-psp3 #1 Tue Feb 28 06:08:20 UTC 2012 armv7l
Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc ip=none
Build Date: 19 October 2011 06:22:31AM
xorg-server 2:1.10.4-1ubuntu4.2 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.22.2
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 9 13:22:18 2012
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(EE) Failed to load module “fbdev” (module does not exist, 0)
(EE) No devices detected.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at “/var/log/Xorg.0.log” for additional information.
ddxSigGiveUp: Closing log
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
Please, help! Any update I need? Or any commands? It said something like “fail to load module fbdev”, does it mean anything to you guys?
Why does it complain “no screen found”, but these texts are actually displayed on the screen connected.
My project needs to display images, so working on console is not enough. Please help! Thanks a lot in advance!
Best regards,
David
