I am using the beaglebone and have effectively generated 3 types of SD card.
a) Angstrom OS as original but uses a fixed IP address, Samba installed + used Swot to share contents on a Windows network + USB stick read/write capabilities.
b) as (a) but uses Debian Wheezy distribution. (as detailed http://elinux.org/BeagleBoarddebian)
c) as (a) but uses Ubuntu distribution (as detailed http://elinux.org/BeagleBoardUbuntu)
Everything initially seems fine BUT after a time period of non-use (days), or perhaps just a time period, some odd things seem to happen - and this has now happened more than once so is not just chance!.
(b) seems to be fine, boots up as expected and places itself on the network etc…
Both (a) + © however refuse to boot as normal and enter an emergency mode - hence no network etc. Sometimes however © seems to boot better and sets up the expected network (you can see it when scanning) but NO open ports as expected!
(a)
U-Boot SPL 2011.09-00000-gf63b270-dirty (Apr 24 2012 - 09:51:01)
Texas Instruments Revision detection unimplemented
No AC power, disabling frequency switch
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00000-gf63b270-dirty (Apr 24 2012 - 09:51:01)
I2C: ready
DRAM: 256 MiB
No daughter card present
NAND: HW ECC Hamming Code selected
No NAND device found!!!
0 MiB
MMC: OMAP SD/MMC: 0
Net: cpsw
SD/MMC found on device 0
reading uEnv.txt
33 bytes read
Loading file “/boot/uImage” from mmc device 0:2 xxa2
3319064 bytes read
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.2.23/beaglebone
Data Size: 3319000 Bytes = 3.2 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
XIP Kernel Image … OK
OK
Starting kernel …
systemd-fsck[51]: Angstrom: clean, 50148/218592 files, 321822/873534 blocks
always starts but later depends upon whether network bit part working:
U-Boot SPL 2011.09-dirty (Feb 27 2012 - 10:01:37)
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-dirty (Feb 27 2012 - 10:01:37)
I2C: ready
DRAM: 256 MiB
0 MiB
MMC: OMAP SD/MMC: 0
I have tried going back into my history and it almost looks as if Swot might have something to do with things, but have yet to prove this + why is Debian OK but the other 2 not + why the long time delay before things go wrong?
Any ideas please?
