Can some one give some support as to how to transfer data via the Ethernet port?
Is there some tutorial or sample code that I can use to study from it?
Thank you all!
Jack
Thank you all!
Jack
In Linux you can do:
ftp
wget
netcat
I need it to be more of a StarterWare type, where I do not need an OS.
scp once ssh is working.
"scp <remote_host:remote_file> <local_directory>"
"scp -dpr <remote_directory> <local_directory>"
"man scp" for details.
"man rsync" another alternative.
Regards
Sid.
“Do not need an OS” on which side of the connection? Do you mean the Beaglebone has no OS? Or the thing talking to the Beaglebone has no OS?
Beaglebone has no OS, because I’m using starterware
ssh, scp on Unix or on WinSCP on Windows communicates with ssh server and client running on Beaglebone.
Without a running OS on both sides, one side is just a piece of useless hardware.
What is running on your Windows or Unix/Linux box and what is running on the Beaglebone? - Angstrom, Ubuntu, Fedora, etc.
Regards
Sid.
Depends on how much you need to transfer. If you just need to pick up configuration data or something you could use TFTP, or maybe BOOTP. You’d at least need enough of a network stack to support UDP. From what I can tell from a quick scan, it looks like StarterWare might provide the minimum necessary. http://processors.wiki.ti.com/index.php/StarterWare_Ethernet_Design
I am running starterware. Which requires no OS.
