Hello Rico,
I think it is my turn
1.) you can find the definition of the configuration of the GPIO’s under:
/sys/kernel/debug/omap_mux/
for example if you want to learn the current configuration of the gpmc_ad6 pin
you should look for:
cat /sys/kernel/debug/omap_mux/gpmc_ad6
to make it availible for output you should write
echo 7 > /sys/kernel/debug/omap_mux/gpmc_ad6
and then if you want to use it you should export that pin.
echo 38 > /sys/class/gpio/export
after you exported it you can make it output
echo “out” > /sys/class/gpio/gpio38/direction
or input
you can change the output value as low:
echo “0” > /sys/class/gpio/gpio38/value
or as high
you can find the manings of the numbers like 7 or 37 from the user guide of AM335X.
As I know, normally first configuration is made by bootloader. (like mux.h) After bootloader, kernel changes the configuration as in the
/sys/kernel/debug/omap_mux/ directory. Whatever you write here will be executed with kernel.
I think you should edit u-boot’s pin mux configurations and recompile it.
As I know there is no major pin config changes on revisions of Beaglebone.
Regards
2012/12/3 Rico <rico.cadetg@gmail.com>
Hello
I have some questions concerning the GPIOs of the beaglebone:
Is there somewhere a definition of the configuration of the GPIOs immediately at startup? (input / output / pullup / pulldown)
When using Angstrom, does the kernel changes this configuration during boot?
Is it possible to change the startup configuration of the GPIOs (before the kernel is loaded)?
If its not possible to change the startup configuration, does the current configuration remain the same for further revisions of the beaglebone?
Thanks a lot for any help!
Web: http://www.teknotel.com.tr
