I did the periodic upgrade of 12.04 and the next reboot I got hung tasks messages.
I installed a fresh ubuntu-12.04-r1-minimal-armhf.tar.xz with the same result, same on another install.
Perhaps someone can spot something that's not quite right.
SD/MMC found on device 0
reading uEnv.txt
723 bytes read
Importing environment from mmc ...
reading uImage
2616216 bytes read
reading uInitrd
2937130 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 80300000 ...
Image Name: 3.2.0-psp7
Data Size: 2616152 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 81600000 ...
Image Name: initramfs
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 2937066 Bytes = 2.8 MiB
Load Address: 00000000
Entry Point: 00000000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-psp7 (root@panda-a1-1gb) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu4) ) #1 Fri Apr 13 04:55:05 UTC 2012
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 VIDEO_DISPLAY root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc ip=none
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 248476k/248476k available, 13668k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0688000 (6656 kB)
[ 0.000000] .init : 0xc0688000 - 0xc06c6000 ( 248 kB)
[ 0.000000] .data : 0xc06c6000 - 0xc070d540 ( 286 kB)
[ 0.000000] .bss : 0xc070d564 - 0xc074edd8 ( 263 kB)
[ 0.000000] NR_IRQS:410 nr_irqs:410 410
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000152] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[ 0.058532] pid_max: default: 32768 minimum: 301
[ 0.058685] Security Framework initialized
[ 0.058746] AppArmor: AppArmor initialized
[ 0.058776] Mount-cache hash table entries: 512
[ 0.059173] Initializing cgroup subsys cpuacct
[ 0.059204] Initializing cgroup subsys memory
[ 0.059265] Initializing cgroup subsys devices
[ 0.059265] Initializing cgroup subsys freezer
[ 0.059265] Initializing cgroup subsys blkio
[ 0.059295] Initializing cgroup subsys perf_event
[ 0.059387] CPU: Testing write buffer coherency: ok
[ 0.060363] devtmpfs: initialized
[ 0.080017] omap_hwmod: gfx: failed to hardreset
[ 0.096313] omap_hwmod: pruss: failed to hardreset
[ 0.097015] print_constraints: dummy:
[ 0.097259] NET: Registered protocol family 16
[ 0.098358] OMAP GPIO hardware version 0.1
[ 0.099456] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.100616] omap_i2c.1: alias fck already exists
[ 0.100982] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.101135] omap2_mcspi.1: alias fck already exists
[ 0.101257] omap2_mcspi.2: alias fck already exists
[ 0.101318] omap_init_sham: platform not supported
[ 0.101348] omap_init_aes: platform not supported
[ 0.101409] edma.0: alias fck already exists
[ 0.101440] edma.0: alias fck already exists
[ 0.109039] bio: create slab <bio-0> at 0
[ 0.110351] SCSI subsystem initialized
[ 0.111175] usbcore: registered new interface driver usbfs
[ 0.111297] usbcore: registered new interface driver hub
[ 0.111450] usbcore: registered new device driver usb
[ 0.111755] registerd cppi-dma Intr @ IRQ 17
[ 0.111785] Cppi41 Init Done Qmgr-base(d083a000) dma-base(d0838000)
[ 0.111816] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.111968] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.112396] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.113128] tps65910 1-002d: could not be detected
[ 0.113616] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.114166] NetLabel: Initializing
[ 0.114166] NetLabel: domain hash size = 128
[ 0.114166] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.114227] NetLabel: unlabeled traffic allowed by default
[ 0.114288] Switching to clocksource gp timer
[ 0.114501] AppArmor: AppArmor Filesystem Enabled
[ 0.124420] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.124633] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.125518] musb-hdrc musb-hdrc.0: USB OTG mode controller at d081c000 using DMA, IRQ 18
[ 0.125793] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[ 0.126312] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.126403] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.126556] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.126556] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.126586] usb usb1: Product: MUSB HDRC host driver
[ 0.126586] usb usb1: Manufacturer: Linux 3.2.0-psp7 musb-hcd
[ 0.126586] usb usb1: SerialNumber: musb-hdrc.1
[ 0.127227] hub 1-0:1.0: USB hub found
[ 0.127258] hub 1-0:1.0: 1 port detected
[ 0.127716] musb-hdrc musb-hdrc.1: USB Host mode controller at d081e800 using DMA, IRQ 19
[ 0.128143] NET: Registered protocol family 2
[ 0.128448] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.129241] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.129425] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.129516] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.129516] TCP reno registered
[ 0.129547] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.129577] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.129882] NET: Registered protocol family 1
[ 0.130279] RPC: Registered named UNIX socket transport module.
[ 0.130279] RPC: Registered udp transport module.
[ 0.130279] RPC: Registered tcp transport module.
[ 0.130310] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.130523] Trying to unpack rootfs image as initramfs...
[ 0.383422] Freeing initrd memory: 2868K
[ 0.385406] audit: initializing netlink socket (disabled)
[ 0.385467] type=2000 audit(0.370:1): initialized
[ 0.542358] VFS: Disk quotas dquot_6.5.2
[ 0.542480] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.544036] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.544097] fuse init (API version 7.17)
[ 0.544799] Btrfs loaded
[ 0.544860] msgmni has been set to 490
[ 0.546051] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.546173] io scheduler noop registered
[ 0.546173] io scheduler deadline registered
[ 0.546264] io scheduler cfq registered (default)
[ 0.547302] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.548431] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 1.239868] console [ttyO0] enabled
[ 1.243957] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 1.251708] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 1.259399] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 1.267089] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 1.274749] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 1.289154] brd: module loaded
[ 1.296112] loop: module loaded
[ 1.299468] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.364776] No daughter card found
[ 1.368347] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.383514] Board name: A335BONE
[ 1.386901] Board version: 00A4
[ 1.390167] The board is a AM335x Beaglebone.
[ 1.395385] tps65217 1-0024: TPS65217 ID 0x7 version 1.0
[ 1.402709] print_constraints: DCDC1: 900 <--> 1800 mV at 1800 mV
[ 1.411010] print_constraints: DCDC2: 900 <--> 3300 mV at 1275 mV
[ 1.419281] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV
[ 1.427520] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[ 1.435760] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[ 1.443908] print_constraints: LDO3: 1800 <--> 3300 mV at 3300 mV
[ 1.452148] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[ 1.459045] omap_hsmmc.0: alias fck already exists
[ 1.464355] omap_i2c.3: alias fck already exists
[ 1.469512] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
[ 1.475921] _omap_mux_get_by_name: Could not find signal leds-gpio
[ 1.482604] w1-gpio connected to P8_6
[ 1.487060] at24 3-0054: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.544799] BeagleBone cape EEPROM: could not read eeprom at address 0x54
[ 1.551940] at24 3-0055: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.559265] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 1.604827] BeagleBone cape EEPROM: could not read eeprom at address 0x55
[ 1.611938] at24 3-0056: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.674804] BeagleBone cape EEPROM: could not read eeprom at address 0x56
[ 1.681915] at24 3-0057: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.706054] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608
[ 1.713043] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.720520] usb 1-1: Product: USB2.0 Hub
[ 1.725494] hub 1-1:1.0: USB hub found
[ 1.729675] hub 1-1:1.0: 4 ports detected
[ 1.744842] BeagleBone cape EEPROM: could not read eeprom at address 0x57
[ 1.751922] BeagleBone cape: exporting ADC pins to sysfs
[ 1.758666] CAN device driver interface
[ 1.762664] CAN bus driver for Bosch D_CAN controller 1.0
[ 1.814880] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 1.821319] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 1.834442] davinci_mdio.0: probed
[ 1.838104] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[ 1.846801] usbcore: registered new interface driver cdc_ether
[ 1.852966] usbcore: registered new interface driver rndis_host
[ 1.859191] cdc_ncm: 04-Aug-2011
[ 1.862640] usbcore: registered new interface driver cdc_ncm
[ 1.868621] Initializing USB Mass Storage driver...
[ 1.873840] usbcore: registered new interface driver usb-storage
[ 1.880126] USB Mass Storage support registered.
[ 1.885070] usbcore: registered new interface driver libusual
[ 1.891143] gadget: using random self ethernet address
[ 1.896636] gadget: using random host ethernet address
[ 1.902923] usb0: MAC aa:91:ab:a9:4f:44
[ 1.906982] usb0: HOST MAC aa:1d:94:a5:28:d9
[ 1.911468] gadget: Ethernet Gadget, version: Memorial Day 2008
[ 1.917755] gadget: g_ether ready
[ 1.921325] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 1.926940] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 1.934753] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.941864] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.949401] usb usb2: Product: MUSB HDRC host driver
[ 1.954559] usb usb2: Manufacturer: Linux 3.2.0-psp7 musb-hcd
[ 1.960571] usb usb2: SerialNumber: musb-hdrc.0
[ 1.966094] hub 2-0:1.0: USB hub found
[ 1.970031] hub 2-0:1.0: 1 port detected
[ 1.975036] mousedev: PS/2 mouse device common for all mice
[ 1.981781] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[ 1.988464] omap_rtc: already running
[ 1.992340] i2c /dev entries driver
[ 1.996398] Linux media interface: v0.10
[ 2.000610] lirc_dev: IR Remote Control driver registered, major 249
[ 2.007354] Driver for 1-wire Dallas network protocol.
[ 2.013885] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.021697] cpuidle: using governor ladder
[ 2.026153] cpuidle: using governor menu
[ 2.033905] usbcore: registered new interface driver snd-usb-6fire
[ 2.040893] ALSA device list:
[ 2.044006] No soundcards found.
[ 2.048614] TCP cubic registered
[ 2.052124] NET: Registered protocol family 10
[ 2.059387] NET: Registered protocol family 17
[ 2.064208] can: controller area network core (rev 20090105 abi 8)
[ 2.070831] NET: Registered protocol family 29
[ 2.075500] can: raw protocol (rev 20090105)
[ 2.079986] Registering the dns_resolver key type
[ 2.084991] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.092987] ThumbEE CPU extension supported.
[ 2.097503] mux: Failed to setup hwmod io irq -22
[ 2.103088] Power Management for AM33XX family
[ 2.112762] registered taskstats version 1
[ 2.117431] Detected MACID=d4:94:a1:3a:d2:5e
[ 2.124267] omap_rtc omap_rtc: setting system clock to 2012-05-15 20:30:50 UTC (1337113850)
[ 2.134246] Freeing init memory: 248K
[ 2.177124] mmc0: host does not support reading read-only switch. assuming write-enable.
Loading, please [ 2.194763] mmc0: new high speed SDHC card at address 1234
wait...
[ 2.210815] mmcblk0: mmc0:1234 SA16G 14.8 GiB
[ 2.223022] mmcblk0: p1 p2
[ 2.302307] udevd[69]: starting version 175
Begin: Loading essential drivers ... [ 2.333160] gadget: high-speed config #1: CDC Ethernet (ECM)
[ 2.405487] usb 1-1.1: new high-speed USB device number 3 using musb-hdrc
done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
[ 2.528961] usb 1-1.1: New USB device found, idVendor=17e9, idProduct=02a9
[ 2.536193] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.543823] usb 1-1.1: Product: LILLIPUT USB Monitor
[ 2.549011] usb 1-1.1: Manufacturer: DisplayLink
[ 2.553833] usb 1-1.1: SerialNumber: 70140297
[ 2.715515] usb 1-1.3: new high-speed USB device number 4 using musb-hdrc
[ 2.826965] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608
[ 2.834197] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.841857] usb 1-1.3: Product: USB2.0 Hub
[ 2.866088] hub 1-1.3:1.0: USB hub found
[ 2.875488] hub 1-1.3:1.0: 4 ports detected
[ 2.965698] usb 1-1.4: new full-speed USB device number 5 using musb-hdrc
[ 3.211486] usb 1-1.4: New USB device found, idVendor=041e, idProduct=3040
[ 3.218719] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.226348] usb 1-1.4: Product: SB Live! 24-bit External
[ 3.231903] usb 1-1.4: Manufacturer: Creative Technology
Begin: Running /scripts/local-premount ... hwclock: select() to /dev/rtc0 to wait for clock tick timed out: No such file or directory
done.
[ 8.970855] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Begin: Running /scripts/local-bottom ... done.
done.
Begin: Running /scripts/init-bottom ... done.
[ 240.535522] INFO: task init:1 blocked for more than 120 seconds.
[ 240.541809] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 240.549987] init D c04d2ab4 0 1 0 0x00000001
[ 240.556640] Backtrace:
[ 240.559204] [<c04d26c8>] (__schedule+0x0/0x43c) from [<c04d2c20>] (schedule+0x78/0x7c)
[ 240.567474] [<c04d2ba8>] (schedule+0x0/0x7c) from [<c04d2f60>] (schedule_timeout+0x20/0x16c)
[ 240.576293] [<c04d2f40>] (schedule_timeout+0x0/0x16c) from [<c04d2480>] (wait_for_common+0xc8/0x154)
[ 240.585845] r6:00000002 r5:cf837abc r4:7fffffff
[ 240.590667] [<c04d23b8>] (wait_for_common+0x0/0x154) from [<c04d2524>] (wait_for_completion+0x18/0x1c)
[ 240.600402] [<c04d250c>] (wait_for_completion+0x0/0x1c) from [<c004ba2c>] (flush_work+0x30/0x3c)
[ 240.609588] [<c004b9fc>] (flush_work+0x0/0x3c) from [<c02e61d4>] (tty_flush_to_ldisc+0x14/0x18)
[ 240.618682] [<c02e61c0>] (tty_flush_to_ldisc+0x0/0x18) from [<c02e1304>] (n_tty_poll+0x7c/0x180)
[ 240.627868] [<c02e1288>] (n_tty_poll+0x0/0x180) from [<c02de9f4>] (tty_poll+0x68/0x88)
[ 240.636108] r7:00000000 r6:cef057c0 r5:c141b400 r4:cf95b340
[ 240.642059] [<c02de98c>] (tty_poll+0x0/0x88) from [<c00cb748>] (do_select+0x2b8/0x460)
[ 240.650329] r7:00000000 r6:00000002 r5:00000200 r4:00000400
[ 240.656250] [<c00cb490>] (do_select+0x0/0x460) from [<c00cbb34>] (core_sys_select+0x244/0x308)
[ 240.665252] [<c00cb8f0>] (core_sys_select+0x0/0x308) from [<c00cbcd4>] (sys_select+0xdc/0x10c)
[ 240.674255] [<c00cbbf8>] (sys_select+0x0/0x10c) from [<c000d560>] (ret_fast_syscall+0x0/0x30)
[ 360.675506] INFO: task init:1 blocked for more than 120 seconds.
[ 360.681762] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 360.689941] init D c04d2ab4 0 1 0 0x00000001
[ 360.696594] Backtrace:
[ 360.699157] [<c04d26c8>] (__schedule+0x0/0x43c) from [<c04d2c20>] (schedule+0x78/0x7c)
[ 360.707427] [<c04d2ba8>] (schedule+0x0/0x7c) from [<c04d2f60>] (schedule_timeout+0x20/0x16c)
[ 360.716247] [<c04d2f40>] (schedule_timeout+0x0/0x16c) from [<c04d2480>] (wait_for_common+0xc8/0x154)
[ 360.725769] r6:00000002 r5:cf837abc r4:7fffffff
[ 360.730590] [<c04d23b8>] (wait_for_common+0x0/0x154) from [<c04d2524>] (wait_for_completion+0x18/0x1c)
[ 360.740325] [<c04d250c>] (wait_for_completion+0x0/0x1c) from [<c004ba2c>] (flush_work+0x30/0x3c)
[ 360.749511] [<c004b9fc>] (flush_work+0x0/0x3c) from [<c02e61d4>] (tty_flush_to_ldisc+0x14/0x18)
[ 360.758575] [<c02e61c0>] (tty_flush_to_ldisc+0x0/0x18) from [<c02e1304>] (n_tty_poll+0x7c/0x180)
[ 360.767761] [<c02e1288>] (n_tty_poll+0x0/0x180) from [<c02de9f4>] (tty_poll+0x68/0x88)
[ 360.776031] r7:00000000 r6:cef057c0 r5:c141b400 r4:cf95b340
[ 360.781951] [<c02de98c>] (tty_poll+0x0/0x88) from [<c00cb748>] (do_select+0x2b8/0x460)
[ 360.790222] r7:00000000 r6:00000002 r5:00000200 r4:00000400
[ 360.796173] [<c00cb490>] (do_select+0x0/0x460) from [<c00cbb34>] (core_sys_select+0x244/0x308)
[ 360.805145] [<c00cb8f0>] (core_sys_select+0x0/0x308) from [<c00cbcd4>] (sys_select+0xdc/0x10c)
[ 360.814147] [<c00cbbf8>] (sys_select+0x0/0x10c) from [<c000d560>] (ret_fast_syscall+0x0/0x30)
[ 480.815490] INFO: task init:1 blocked for more than 120 seconds.
[ 480.821777] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 480.829925] init D c04d2ab4 0 1 0 0x00000001
[ 480.836578] Backtrace:
[ 480.839141] [<c04d26c8>] (__schedule+0x0/0x43c) from [<c04d2c20>] (schedule+0x78/0x7c)
[ 480.847412] [<c04d2ba8>] (schedule+0x0/0x7c) from [<c04d2f60>] (schedule_timeout+0x20/0x16c)
[ 480.856231] [<c04d2f40>] (schedule_timeout+0x0/0x16c) from [<c04d2480>] (wait_for_common+0xc8/0x154)
[ 480.865753] r6:00000002 r5:cf837abc r4:7fffffff
[ 480.870574] [<c04d23b8>] (wait_for_common+0x0/0x154) from [<c04d2524>] (wait_for_completion+0x18/0x1c)
[ 480.880310] [<c04d250c>] (wait_for_completion+0x0/0x1c) from [<c004ba2c>] (flush_work+0x30/0x3c)
[ 480.889495] [<c004b9fc>] (flush_work+0x0/0x3c) from [<c02e61d4>] (tty_flush_to_ldisc+0x14/0x18)
[ 480.898590] [<c02e61c0>] (tty_flush_to_ldisc+0x0/0x18) from [<c02e1304>] (n_tty_poll+0x7c/0x180)
[ 480.907745] [<c02e1288>] (n_tty_poll+0x0/0x180) from [<c02de9f4>] (tty_poll+0x68/0x88)
[ 480.916015] r7:00000000 r6:cef057c0 r5:c141b400 r4:cf95b340
[ 480.921936] [<c02de98c>] (tty_poll+0x0/0x88) from [<c00cb748>] (do_select+0x2b8/0x460)
[ 480.930206] r7:00000000 r6:00000002 r5:00000200 r4:00000400
[ 480.936157] [<c00cb490>] (do_select+0x0/0x460) from [<c00cbb34>] (core_sys_select+0x244/0x308)
[ 480.945129] [<c00cb8f0>] (core_sys_select+0x0/0x308) from [<c00cbcd4>] (sys_select+0xdc/0x10c)
[ 480.954132] [<c00cbbf8>] (sys_select+0x0/0x10c) from [<c000d560>] (ret_fast_syscall+0x0/0x30)
[ 600.955474] INFO: task init:1 blocked for more than 120 seconds.
[ 600.961730] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 600.969909] init D c04d2ab4 0 1 0 0x00000001
[ 600.976562] Backtrace:
[ 600.979125] [<c04d26c8>] (__schedule+0x0/0x43c) from [<c04d2c20>] (schedule+0x78/0x7c)
[ 600.987396] [<c04d2ba8>] (schedule+0x0/0x7c) from [<c04d2f60>] (schedule_timeout+0x20/0x16c)
[ 600.996215] [<c04d2f40>] (schedule_timeout+0x0/0x16c) from [<c04d2480>] (wait_for_common+0xc8/0x154)
[ 601.005737] r6:00000002 r5:cf837abc r4:7fffffff
[ 601.010559] [<c04d23b8>] (wait_for_common+0x0/0x154) from [<c04d2524>] (wait_for_completion+0x18/0x1c)
[ 601.020294] [<c04d250c>] (wait_for_completion+0x0/0x1c) from [<c004ba2c>] (flush_work+0x30/0x3c)
[ 601.029479] [<c004b9fc>] (flush_work+0x0/0x3c) from [<c02e61d4>] (tty_flush_to_ldisc+0x14/0x18)
[ 601.038574] [<c02e61c0>] (tty_flush_to_ldisc+0x0/0x18) from [<c02e1304>] (n_tty_poll+0x7c/0x180)
[ 601.047729] [<c02e1288>] (n_tty_poll+0x0/0x180) from [<c02de9f4>] (tty_poll+0x68/0x88)
[ 601.055999] r7:00000000 r6:cef057c0 r5:c141b400 r4:cf95b340
[ 601.061920] [<c02de98c>] (tty_poll+0x0/0x88) from [<c00cb748>] (do_select+0x2b8/0x460)
[ 601.070190] r7:00000000 r6:00000002 r5:00000200 r4:00000400
[ 601.076110] [<c00cb490>] (do_select+0x0/0x460) from [<c00cbb34>] (core_sys_select+0x244/0x308)
[ 601.085113] [<c00cb8f0>] (core_sys_select+0x0/0x308) from [<c00cbcd4>] (sys_select+0xdc/0x10c)
[ 601.094116] [<c00cbbf8>] (sys_select+0x0/0x10c) from [<c000d560>] (ret_fast_syscall+0x0/0x30)
The Backtraces keep on repeating.
Regards
Sid.
