I have a 3g usb modem (huawei e173) and want to use it on my beaglebone. For this purpose I have to to build the kernel with usb to serial module. However I could not do it even though I (really!) checked many sites. This is what I have done step by step:
Copied the Ångström specific scripts to initialize an OpenEmbedded environment:
git clone git://git.angstrom-distribution.org/setup-scripts
cd setup-scripts
git checkout origin/oe-core -b oe-core
However at the third step I got the error:
zero@ghostrider:~/setup-scripts$ git checkout origin/oe-core -b oe-core
fatal: git checkout: updating paths is incompatible with switching branches.
Did you intend to checkout ‘origin/oe-core’ which can not be resolved as commit?
I carried on: Downloaded all layers according to sources/layers.txt
Seems like I have installed all the layers required and also not required:
zero@ghostrider:~$ ls
bitbake meta-efikamx meta-nslu2 Music
Desktop meta-ettus meta-oe oe-core
Documents meta-handheld meta-openpandora Pictures
Downloads meta-intel meta-opie Public
examples.desktop meta-java meta-raspberrypi setup-scripts
meta-angstrom meta-kde meta-ti Templates
meta-browser meta-mono meta-xilinx Videos
When I did :
zero@ghostrider:~/setup-scripts$ ./oebb.sh config beaglebone
env: gawk: No such file or directory
Setup for beaglebone completed
What is that env:gawk error?
I keep gettin this error for example:
zero@ghostrider:~/setup-scripts$ MACHINE=beaglebone ./oebb.sh config beaglebone
zero@ghostrider:~/setup-scripts$ MACHINE=beaglebone ./oebb.sh update
I really did not understand what I am doing wrong and really do not have an idea what to do now. All I want is to recompile the kernel. : ) What should I do? (Did I have to download something like any other beaglebone img-script etc and put it to somewhere?) Could you please explain me step by step what should I do as if you are explaining to a 100 years old grandpa.
Thank you for your help.
Regards
