Beaglebone project help: reaching lighttpd server from wifi
Hi, I already succesfully installed lighttpd, php and mysql on my Beaglebone Angstrom.
Is it possible to connect my beaglebone with a normal D-link home router DIR-600 and access to my web page on wifi?
I need to create a wifi “access point” to this website and access with many devices as smartphones, tablets,…
Thank you for your help.
your getting the 403 forbidden error in your browser? that means that some permissions are not set and fastCGI is not set correctly. try coping the example web page to another name that does not end in php. add a file called index.html and see if your browser will load that. if it does you have a config issue not a connection issue.
Ron
