BeagleBone Rev.A6a constantly rebooting
Hi guys,
i have an issue with my BeagleBone Rev.A6a.
When I try to connect via USB
screen /dev/tty.usbserial-*******B 115200
I am going to see the login screen from Angstrom
.—O---.
.-. o o
__ | —’| ‘–.| .-’| | |
The Angstrom Distribution roon ttyO0
Angstrom v2012.05 - Kernel 3.2.34
roon login:
After a short period of time (around 30 seconds) the BeagleBone is rebooting
Anyone see why this happens?
Here is what it print out to me:
Sending SIGKILL to remaining processes…
Unmounting file systems.
Unmounted /sys/kernel/debug.
Unmounted /dev/mqueue.
Disabling swaps.
Detaching loop devices.
Detaching DM devices.
[ 57.085357] Restarting system.
U-Boot SPL 2011.09-00053-gb423c52 (Aug 10 2012 - 11:26:55)
Texas Instruments Revision detection unimplemented
No daughter card present
No AC power, disabling frequency switch
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00053-gb423c52 (Aug 10 2012 - 11:26:55)
I2C: ready
DRAM: 256 MiB
WARNING: Caches not enabled
NAND: HW ECC Hamming Code selected
No NAND device found!!!
0 MiB
Net: cpsw
SD/MMC found on device 0
reading uEnv.txt
33 bytes read
Loading file “/boot/uImage” from mmc device 0:2 xxa2
3489560 bytes read
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.2.34/beaglebone
Data Size: 3489496 Bytes = 3.3 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
XIP Kernel Image … OK
OK
Starting kernel …
systemd-fsck[54]: Angstrom-Cloud9-: clean, 91694/218592 files, 473628/873534 blocks
