Hi guys, I need some help!
I’ve got a beagle bone revision 3 and I’m using Ubuntu 13.04 on my computer. I read the starting guide and I ran the mkudevrule.sh script from the official site, however, some issues still bothering me. Every time when I connect my board to the computer I’ve got the problem that disconnect FTDI USB device from ttyUSB. The research I’ve done pointed out that the problem would be the brltty application on Ubuntu, but I have removed it and the problem still here. Here is the output of the dmesg command.
[ 2113.057826] usb 2-1.1: new high-speed USB device number 11 using ehci-pci
[ 2113.150247] usb 2-1.1: New USB device found, idVendor=0424, idProduct=2412
[ 2113.150254] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2113.150635] hub 2-1.1:1.0: USB hub found
[ 2113.150697] hub 2-1.1:1.0: 2 ports detected
[ 2113.421841] usb 2-1.1.1: new high-speed USB device number 12 using ehci-pci
[ 2113.516468] usb 2-1.1.1: New USB device found, idVendor=0403, idProduct=a6d0
[ 2113.516478] usb 2-1.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2113.516483] usb 2-1.1.1: Product: BeagleBone
[ 2113.516488] usb 2-1.1.1: Manufacturer: FTDI
[ 2113.518194] usb 2-1.1.1: Ignoring serial port reserved for JTAG
[ 2113.519737] ftdi_sio 2-1.1.1:1.1: FTDI USB Serial Device converter detected
[ 2113.519802] usb 2-1.1.1: Detected FT2232H
[ 2113.519809] usb 2-1.1.1: Number of endpoints 2
[ 2113.519816] usb 2-1.1.1: Endpoint 1 MaxPacketSize 512
[ 2113.519822] usb 2-1.1.1: Endpoint 2 MaxPacketSize 512
[ 2113.519828] usb 2-1.1.1: Setting MaxPacketSize 512
[ 2113.520164] usb 2-1.1.1: FTDI USB Serial Device converter now attached to ttyUSB0
[ 2113.605545] usb 2-1.1.2: new high-speed USB device number 13 using ehci-pci
[ 2113.724993] usb 2-1.1.2: New USB device found, idVendor=0525, idProduct=a4a1
[ 2113.725003] usb 2-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2113.725009] usb 2-1.1.2: Product: Ethernet Gadget
[ 2113.725014] usb 2-1.1.2: Manufacturer: Linux 3.2.42-psp27 with musb-hdrc
[ 2113.726732] cdc_ether 2-1.1.2:1.0 usb0: register ‘cdc_ether’ at usb-0000:00:1d.0-1.1.2, CDC Ethernet Device, 02:4d:52:dd:f7:75
[ 2114.299364] ftdi_sio ttyUSB0: failed to get modem status: -71
[ 2114.307830] ftdi_sio ttyUSB0: failed to get modem status: -71
[ 2114.395206] usb 2-1.1: USB disconnect, device number 11
[ 2114.395213] usb 2-1.1.1: USB disconnect, device number 12
[ 2114.397185] ftdi_sio ttyUSB0: failed to get modem status: -71
[ 2114.397399] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 2114.397436] ftdi_sio 2-1.1.1:1.1: device disconnected
[ 2114.398741] usb 2-1.1.2: USB disconnect, device number 13
[ 2114.401202] cdc_ether 2-1.1.2:1.0 usb0: unregister ‘cdc_ether’ usb-0000:00:1d.0-1.1.2, CDC Ethernet Device
This is the only issue that I got, the board itself is booting correctly and It’s also got an IP address. If I can’t solve that problem I’m thinking about put a SSH server application directly on the micro-sd card, so I could use the Ethernet interface instead of the USB. But I’ll use this workaround as a last resource option.
