Beaglebone sd card flash does not boot up
Dear forum
I used on one your prebuilt image from this link https://beagleboard.org/latest-images
i have use the one with sha256sum: da97d7794d834ee785265162635aedcca80fd6dc374593dd05473c0a25f0ac73
flashed on the sd card using the command given in bellow sudo dd if=/path/to/downloaded.img of=/dev/devicenod and then i remove power plug press the boot key(S2) and then plug the power plug
but the BBB does not seem to boot from sd card why?
REgards
