thsi is somehow OT but on the other side: who to ask else if not
those which uses these boards...?
I want to use my beaglebone as a mobile device (hopefully my English
does not goes screwed up here: I dont mean anything like "mobile
phone" here...I mean something to carry with me...) also.
For this purpose I need a small but useable USB wire based keyboard (no
bluetooth based thingie or similiar, which only adds another pair of
batteries).
Since I am little of a keyboard nerd (I am using an old IBM model M),
I asked the guys at www.geekhack.org, but the recommended solutions
are keyboards which normal sized keys but less than 104 (no number
block, and more functions on a single key and a slightly different
layout.
I will use the keyboard for typing (programming) only, so the keys
[]{}\|<>()*^~ and such should be acessible easily (not via
FN-ALT-CTRL-SHIFT-META-ESC-somthing).
Most preferable is a mechanical keyboard (CHERRY MX Blue switches for
example), but then I am already with the normal sized key problem
described above.
Is there any keyboard, which is small in size, good useable, USB wire
based, with no fancy LED light show (look at the KBT pure or KBT
race!) and which works with the beaglebone ?
Thank you very much ina advance for any help!
Best regards,
mcc
