can you post the code ? i’m tring to do the same thing on beaglebone and i have same problem.
i think my muxing is fine since i do :
echo 12 > /sys/kernel/debug/omap_mux/gpmc_advn_ale
that should be same as (IEN | MODE2)
thanks
thanks
Hi David, Yogev,
If you either of you happen to have code for enabling Timer4 I’d much appreciate taking a look. I have mux’d Timer4 to the expansion header and I’ve written ‘1’ to the TCLR ST bit, but so far no dice.
Many thanks,
Joseph
